time-nuts@lists.febo.com
DC distribution
BD
Bill Dailey
Fri, Oct 4, 2019 1:58 AM
Setting up a new workbench and am wondering what wisdom people can offer.  I am powering numerous synthesizers (5v), small receivers (5v), Upconverters (5v), larger receivers (12v), fury Gpsdo’s.. etc.  anyone use something neat and not real expensive for distributing 5v and 12v.  I am hoping for a long COTS pcb with fusing and maybe holes for plugs.
Any insights?
Bill
Bill Dailey
Negativity always wins the short game. But positivity wins the long game. - Gary Vaynerchuk
Don’t be easy to understand,
Be impossible to misunderstand
  • Steve Sims
Setting up a new workbench and am wondering what wisdom people can offer. I am powering numerous synthesizers (5v), small receivers (5v), Upconverters (5v), larger receivers (12v), fury Gpsdo’s.. etc. anyone use something neat and not real expensive for distributing 5v and 12v. I am hoping for a long COTS pcb with fusing and maybe holes for plugs. Any insights? Bill Bill Dailey Negativity always wins the short game. But positivity wins the long game. - Gary Vaynerchuk Don’t be easy to understand, Be impossible to misunderstand - Steve Sims
PK
Poul-Henning Kamp
Fri, Oct 4, 2019 6:05 AM
In message 36676B65-57B2-4B2D-94D6-326385CE5B83@gmail.com, Bill Dailey writes
I use http://www.westmountainradio.com/rigrunner.php
Poul-Henning Kamp      | UNIX since Zilog Zeus 3.20
phk@FreeBSD.ORG        | TCP/IP since RFC 956
FreeBSD committer      | BSD since 4.3-tahoe
Never attribute to malice what can adequately be explained by incompetence.
-------- In message <36676B65-57B2-4B2D-94D6-326385CE5B83@gmail.com>, Bill Dailey writes : I use http://www.westmountainradio.com/rigrunner.php -- Poul-Henning Kamp | UNIX since Zilog Zeus 3.20 phk@FreeBSD.ORG | TCP/IP since RFC 956 FreeBSD committer | BSD since 4.3-tahoe Never attribute to malice what can adequately be explained by incompetence.
JA
John Ackermann. N8UR
Fri, Oct 4, 2019 11:39 AM
I use lots and lots of Anderson PowerPoles and (mostly) West Mountain Radio distribution units.  I have different color codes for different voltages -- red/black for 12v, orange/black for 24v, green/black for 5v, etc.  Primary 12 and 24 volt sources are big AGM batteries across float chargers.
Any insights?
Bill
Bill Dailey
  • Steve Sims
time-nuts mailing list -- time-nuts@lists.febo.com
To unsubscribe, go to
http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com
I use lots and lots of Anderson PowerPoles and (mostly) West Mountain Radio distribution units.  I have different color codes for different voltages -- red/black for 12v, orange/black for 24v, green/black for 5v, etc.  Primary 12 and 24 volt sources are big AGM batteries across float chargers. On Oct 4, 2019, 2:03 AM, at 2:03 AM, Bill Dailey <docdailey@gmail.com> wrote: >Setting up a new workbench and am wondering what wisdom people can >offer. I am powering numerous synthesizers (5v), small receivers (5v), >Upconverters (5v), larger receivers (12v), fury Gpsdo’s.. etc. anyone >use something neat and not real expensive for distributing 5v and 12v. >I am hoping for a long COTS pcb with fusing and maybe holes for plugs. > > >Any insights? > >Bill > >Bill Dailey > >Negativity always wins the short game. But positivity wins the long >game. - Gary Vaynerchuk > >Don’t be easy to understand, >Be impossible to misunderstand >- Steve Sims >_______________________________________________ >time-nuts mailing list -- time-nuts@lists.febo.com >To unsubscribe, go to >http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >and follow the instructions there.
TS
Tim Shoppa
Fri, Oct 4, 2019 11:56 AM
I want to recommend Anderson Powerpoles for DC distribution too. A trillion times better than all the incompatible molexes. And those West Mountain Radio multi fused splitters are exactly what you want for splitters.
In addition to the WMR splitters, bare PCBs for building up your own are available too. There are also some nice non-Anderson DC distribution fuseblocks in the marine and automotive shops.
Black and red is the ham convention for 12V. If you want to run +5 or -48 (ex-telco equipment) around, you could adopt a different color convention and/or Polarizing pins conventions.
Tim N3QE
To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com
I want to recommend Anderson Powerpoles for DC distribution too. A trillion times better than all the incompatible molexes. And those West Mountain Radio multi fused splitters are exactly what you want for splitters. In addition to the WMR splitters, bare PCBs for building up your own are available too. There are also some nice non-Anderson DC distribution fuseblocks in the marine and automotive shops. Black and red is the ham convention for 12V. If you want to run +5 or -48 (ex-telco equipment) around, you could adopt a different color convention and/or Polarizing pins conventions. Tim N3QE > On Oct 4, 2019, at 2:05 AM, Poul-Henning Kamp <phk@phk.freebsd.dk> wrote: > > -------- > In message <36676B65-57B2-4B2D-94D6-326385CE5B83@gmail.com>, Bill Dailey writes > : > > I use http://www.westmountainradio.com/rigrunner.php > > > -- > Poul-Henning Kamp | UNIX since Zilog Zeus 3.20 > phk@FreeBSD.ORG | TCP/IP since RFC 956 > FreeBSD committer | BSD since 4.3-tahoe > Never attribute to malice what can adequately be explained by incompetence. > > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there.
J
jimlux
Fri, Oct 4, 2019 12:17 PM
There's a variety of things out there with PowerPole connectors of
varying sophistication.  You might check West Mountain Radio or
PowerWerx. Or the amateur radio community in general - someone has
probably published a dual row PCB design if you want to fab it yourself.
there's also power distribution strips that have rows of banana
jacks/binding posts with the standard 3/4" spacing to mate with dual
banana plugs
At work, pretty much everything prototype-like uses stackable double
banana plugs, usually with a reverse biased diode across the terminals
(so if you plug it in backwards, the power supply current limits or
folds back). We use a lot of coax to dual banana adapters (just because
nobody makes twisted pair banana jack to plug as an off the shelf item).
On 10/3/19 6:58 PM, Bill Dailey wrote: > Setting up a new workbench and am wondering what wisdom people can offer. I am powering numerous synthesizers (5v), small receivers (5v), Upconverters (5v), larger receivers (12v), fury Gpsdo’s.. etc. anyone use something neat and not real expensive for distributing 5v and 12v. I am hoping for a long COTS pcb with fusing and maybe holes for plugs. There's a variety of things out there with PowerPole connectors of varying sophistication. You might check West Mountain Radio or PowerWerx. Or the amateur radio community in general - someone has probably published a dual row PCB design if you want to fab it yourself. there's also power distribution strips that have rows of banana jacks/binding posts with the standard 3/4" spacing to mate with dual banana plugs At work, pretty much everything prototype-like uses stackable double banana plugs, usually with a reverse biased diode across the terminals (so if you plug it in backwards, the power supply current limits or folds back). We use a lot of coax to dual banana adapters (just because nobody makes twisted pair banana jack to plug as an off the shelf item).
PB
Paul Bicknell
Fri, Oct 4, 2019 12:32 PM
Hi I am standardising on 4 pin XLR connectors for 12 Volts as used in the TV
industry Perhaps you could use the 6 pin for 5 volts
I do not recommend the 2 pin as this is for 240 V ac
Or the 3 pin as you could take out a microphone
I am going to be Using military connectors for 24 V DC and 400 Hz
-----Original Message-----
From: time-nuts [mailto:time-nuts-bounces@lists.febo.com] On Behalf Of John
Ackermann. N8UR
Sent: 04 October 2019 12:40
To: David Van Horn via time-nuts
Subject: Re: [time-nuts] DC distribution
Any insights?
Bill
Bill Dailey
  • Steve Sims
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2016.0.8048 / Virus Database: 4793/15886 - Release Date: 08/14/18
Internal Virus Database is out of date.
Hi I am standardising on 4 pin XLR connectors for 12 Volts as used in the TV industry Perhaps you could use the 6 pin for 5 volts I do not recommend the 2 pin as this is for 240 V ac Or the 3 pin as you could take out a microphone I am going to be Using military connectors for 24 V DC and 400 Hz -----Original Message----- From: time-nuts [mailto:time-nuts-bounces@lists.febo.com] On Behalf Of John Ackermann. N8UR Sent: 04 October 2019 12:40 To: David Van Horn via time-nuts Subject: Re: [time-nuts] DC distribution I use lots and lots of Anderson PowerPoles and (mostly) West Mountain Radio distribution units.  I have different color codes for different voltages -- red/black for 12v, orange/black for 24v, green/black for 5v, etc.  Primary 12 and 24 volt sources are big AGM batteries across float chargers. On Oct 4, 2019, 2:03 AM, at 2:03 AM, Bill Dailey <docdailey@gmail.com> wrote: >Setting up a new workbench and am wondering what wisdom people can >offer. I am powering numerous synthesizers (5v), small receivers (5v), >Upconverters (5v), larger receivers (12v), fury Gpsdo’s.. etc. anyone >use something neat and not real expensive for distributing 5v and 12v. >I am hoping for a long COTS pcb with fusing and maybe holes for plugs. > > >Any insights? > >Bill > >Bill Dailey > >Negativity always wins the short game. But positivity wins the long >game. - Gary Vaynerchuk > >Don’t be easy to understand, >Be impossible to misunderstand >- Steve Sims >_______________________________________________ >time-nuts mailing list -- time-nuts@lists.febo.com >To unsubscribe, go to >http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >and follow the instructions there. _______________________________________________ time-nuts mailing list -- time-nuts@lists.febo.com To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com and follow the instructions there. ----- No virus found in this message. Checked by AVG - www.avg.com Version: 2016.0.8048 / Virus Database: 4793/15886 - Release Date: 08/14/18 Internal Virus Database is out of date.
BD
Bill Dailey
Fri, Oct 4, 2019 12:53 PM
Yes.  I am using 12v agm.  Good wmr for the connectors also?
Bill Dailey
  • Steve Sims
Any insights?
Bill
Bill Dailey
  • Steve Sims
Yes. I am using 12v agm. Good wmr for the connectors also? Bill Dailey Negativity always wins the short game. But positivity wins the long game. - Gary Vaynerchuk Don’t be easy to understand, Be impossible to misunderstand - Steve Sims > On Oct 4, 2019, at 7:17 AM, John Ackermann. N8UR <jra@febo.com> wrote: > > I use lots and lots of Anderson PowerPoles and (mostly) West Mountain Radio distribution units. I have different color codes for different voltages -- red/black for 12v, orange/black for 24v, green/black for 5v, etc. Primary 12 and 24 volt sources are big AGM batteries across float chargers. > >> On Oct 4, 2019, 2:03 AM, at 2:03 AM, Bill Dailey <docdailey@gmail.com> wrote: >> Setting up a new workbench and am wondering what wisdom people can >> offer. I am powering numerous synthesizers (5v), small receivers (5v), >> Upconverters (5v), larger receivers (12v), fury Gpsdo’s.. etc. anyone >> use something neat and not real expensive for distributing 5v and 12v. >> I am hoping for a long COTS pcb with fusing and maybe holes for plugs. >> >> >> Any insights? >> >> Bill >> >> Bill Dailey >> >> Negativity always wins the short game. But positivity wins the long >> game. - Gary Vaynerchuk >> >> Don’t be easy to understand, >> Be impossible to misunderstand >> - Steve Sims >> _______________________________________________ >> time-nuts mailing list -- time-nuts@lists.febo.com >> To unsubscribe, go to >> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >> and follow the instructions there. > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there.
W
W7SLS
Fri, Oct 4, 2019 1:47 PM
Anderson Power Poles  / West Mountain Radio <— agree.  fantastic
avail 15A, 30 A, 45A, … 175A, and more
Blue Sea Systems marine products are great also
example: ammeters with shunt in positive rail
My .02
Scott W7SLS
Tim N3QE
Anderson Power Poles / West Mountain Radio <— agree. fantastic avail 15A, 30 A, 45A, … 175A, and more Blue Sea Systems marine products are great also example: ammeters with shunt in positive rail My .02 Scott W7SLS > On Oct 4, 2019, at 4:56 AM, Tim Shoppa <tshoppa@gmail.com> wrote: > > I want to recommend Anderson Powerpoles for DC distribution too. A trillion times better than all the incompatible molexes. And those West Mountain Radio multi fused splitters are exactly what you want for splitters. > > In addition to the WMR splitters, bare PCBs for building up your own are available too. There are also some nice non-Anderson DC distribution fuseblocks in the marine and automotive shops. > > Black and red is the ham convention for 12V. If you want to run +5 or -48 (ex-telco equipment) around, you could adopt a different color convention and/or Polarizing pins conventions. > > Tim N3QE > >> On Oct 4, 2019, at 2:05 AM, Poul-Henning Kamp <phk@phk.freebsd.dk> wrote: >> >> -------- >> In message <36676B65-57B2-4B2D-94D6-326385CE5B83@gmail.com>, Bill Dailey writes >> : >> >> I use http://www.westmountainradio.com/rigrunner.php >> >> >> -- >> Poul-Henning Kamp | UNIX since Zilog Zeus 3.20 >> phk@FreeBSD.ORG | TCP/IP since RFC 956 >> FreeBSD committer | BSD since 4.3-tahoe >> Never attribute to malice what can adequately be explained by incompetence. >> >> _______________________________________________ >> time-nuts mailing list -- time-nuts@lists.febo.com >> To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >> and follow the instructions there. > > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there.
JA
Fri, Oct 4, 2019 3:41 PM
West Mountain is a good source for all things PowerPole, but there are a bunch of other vendors as well.  And do youself a favor -- spend $30 on the three size 15/30/45 amp crimping tool.  It saves much aggravation.  But if you're using thin wire, soldering after crimping is a good precaution.
On Oct 4, 2019, 10:03 AM, at 10:03 AM, Bill Dailey docdailey@gmail.com wrote:
Bill Dailey
  • Steve Sims
(5v),
anyone
12v.
plugs.
Any insights?
Bill
Bill Dailey
  • Steve Sims
West Mountain is a good source for all things PowerPole, but there are a bunch of other vendors as well.  And do youself a favor -- spend $30 on the three size 15/30/45 amp crimping tool.  It saves much aggravation.  But if you're using thin wire, soldering after crimping is a good precaution. On Oct 4, 2019, 10:03 AM, at 10:03 AM, Bill Dailey <docdailey@gmail.com> wrote: >Yes. I am using 12v agm. Good wmr for the connectors also? > >Bill Dailey > >Negativity always wins the short game. But positivity wins the long >game. - Gary Vaynerchuk > >Don’t be easy to understand, >Be impossible to misunderstand >- Steve Sims > >> On Oct 4, 2019, at 7:17 AM, John Ackermann. N8UR <jra@febo.com> >wrote: >> >> I use lots and lots of Anderson PowerPoles and (mostly) West >Mountain Radio distribution units. I have different color codes for >different voltages -- red/black for 12v, orange/black for 24v, >green/black for 5v, etc. Primary 12 and 24 volt sources are big AGM >batteries across float chargers. >> >>> On Oct 4, 2019, 2:03 AM, at 2:03 AM, Bill Dailey ><docdailey@gmail.com> wrote: >>> Setting up a new workbench and am wondering what wisdom people can >>> offer. I am powering numerous synthesizers (5v), small receivers >(5v), >>> Upconverters (5v), larger receivers (12v), fury Gpsdo’s.. etc. >anyone >>> use something neat and not real expensive for distributing 5v and >12v. >>> I am hoping for a long COTS pcb with fusing and maybe holes for >plugs. >>> >>> >>> Any insights? >>> >>> Bill >>> >>> Bill Dailey >>> >>> Negativity always wins the short game. But positivity wins the long >>> game. - Gary Vaynerchuk >>> >>> Don’t be easy to understand, >>> Be impossible to misunderstand >>> - Steve Sims >>> _______________________________________________ >>> time-nuts mailing list -- time-nuts@lists.febo.com >>> To unsubscribe, go to >>> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >>> and follow the instructions there. >> _______________________________________________ >> time-nuts mailing list -- time-nuts@lists.febo.com >> To unsubscribe, go to >http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >> and follow the instructions there. >_______________________________________________ >time-nuts mailing list -- time-nuts@lists.febo.com >To unsubscribe, go to >http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >and follow the instructions there.
TK
Taka Kamiya
Fri, Oct 4, 2019 4:01 PM
Mine is very simple....
USB connector for 5VBarrel connector 5.5/2.1mm for 12VTerminal strip for 24V
None of them are high power devices.
(Mr.) Taka Kamiya
KB4EMF / ex JF2DKG
On Friday, October 4, 2019, 2:03:55 AM EDT, Bill Dailey <docdailey@gmail.com> wrote:
Any insights?
Bill
Bill Dailey
  • Steve Sims
Mine is very simple.... USB connector for 5VBarrel connector 5.5/2.1mm for 12VTerminal strip for 24V None of them are high power devices. --------------------------------------- (Mr.) Taka Kamiya KB4EMF / ex JF2DKG On Friday, October 4, 2019, 2:03:55 AM EDT, Bill Dailey <docdailey@gmail.com> wrote: Setting up a new workbench and am wondering what wisdom people can offer.  I am powering numerous synthesizers (5v), small receivers (5v), Upconverters (5v), larger receivers (12v), fury Gpsdo’s.. etc.  anyone use something neat and not real expensive for distributing 5v and 12v.  I am hoping for a long COTS pcb with fusing and maybe holes for plugs.  Any insights? Bill Bill Dailey Negativity always wins the short game. But positivity wins the long game. - Gary Vaynerchuk Don’t be easy to understand, Be impossible to misunderstand - Steve Sims _______________________________________________ time-nuts mailing list -- time-nuts@lists.febo.com To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com and follow the instructions there.
PL
Peter Laws
Fri, Oct 4, 2019 7:13 PM
Our club has this tool and I approve this message!
Interestingly, there is a subset of the model railroading community
that builds modular layouts.  The N-scale group (N-Trak) has adopted
Power-Poles as their standard after decades of using Cinch connectors.
PowerPoles have their limits but in these applications (time nuttery,
amateur radio, model railroads) they are pretty darn convenient.  And
a crimper makes it more so.
I also have the little pick tool that Anderson sells that makes it
easy to "convince" reluctant contacts to seat properly in the plastic
shell and make it easier to remove the contact if you need to.  Saves
wear on my "jewelers screwdrivers".
Peter Laws | N5UWY | plaws plaws net | Travel by Train!
On Fri, Oct 4, 2019 at 2:01 PM John Ackermann. N8UR <jra@febo.com> wrote: > > West Mountain is a good source for all things PowerPole, but there are a bunch of other vendors as well. And do youself a favor -- spend $30 on the three size 15/30/45 amp crimping tool. It saves much aggravation. But if you're using thin wire, soldering after crimping is a good precaution. Our club has this tool and I approve this message! Interestingly, there is a subset of the model railroading community that builds modular layouts. The N-scale group (N-Trak) has adopted Power-Poles as their standard after decades of using Cinch connectors. PowerPoles have their limits but in these applications (time nuttery, amateur radio, model railroads) they are pretty darn convenient. And a crimper makes it more so. I also have the little pick tool that Anderson sells that makes it easy to "convince" reluctant contacts to seat properly in the plastic shell and make it easier to remove the contact if you need to. Saves wear on my "jewelers screwdrivers". -- Peter Laws | N5UWY | plaws plaws net | Travel by Train!
M
MLewis
Fri, Oct 4, 2019 7:17 PM
With audio signals, a soldered crimp is one of the worst possible
connections. I wouldn't think it would be different for anything else,
but may go undetected until failure. If you've used the correct size of
crimp and used a proper crimping tool, then you've got the proper
pressure for a solid reliable connection. If you then solder, the heat
expands the crimp lessening the crimp pressure, and when it cools it's
no longer at the correct crimp pressure (often the wire will pull right
out), and with iffy wicking of solder. The worst of both methods
combined in one.
Where the wire is too thin for the crimp I have available, I've cut a
piece of a correct thickness wire/cable, inserted that into the crimp
along with the signal wire/cable, so it's crimped between them. I don't
know if that is the best way of handling that, but it's worked for me.
With audio signals, a soldered crimp is one of the worst possible connections. I wouldn't think it would be different for anything else, but may go undetected until failure. If you've used the correct size of crimp and used a proper crimping tool, then you've got the proper pressure for a solid reliable connection. If you then solder, the heat expands the crimp lessening the crimp pressure, and when it cools it's no longer at the correct crimp pressure (often the wire will pull right out), and with iffy wicking of solder. The worst of both methods combined in one. Where the wire is too thin for the crimp I have available, I've cut a piece of a correct thickness wire/cable, inserted that into the crimp along with the signal wire/cable, so it's crimped between them. I don't know if that is the best way of handling that, but it's worked for me. On 04/10/2019 11:41 AM, John Ackermann. N8UR wrote: > West Mountain is a good source for all things PowerPole, but there are a bunch of other vendors as well. And do youself a favor -- spend $30 on the three size 15/30/45 amp crimping tool. It saves much aggravation. But if you're using thin wire, soldering after crimping is a good precaution. >
W
W7SLS
Fri, Oct 4, 2019 7:18 PM
Good advice.  Another way is to put in an extra wire (or fold over the thin wire) so as to “fill up” the power pole before you crimp it.
Scott
W7SLS
Bill Dailey
  • Steve Sims
(5v),
anyone
12v.
plugs.
Any insights?
Bill
Bill Dailey
  • Steve Sims
>> But if you're using thin wire, soldering after crimping is a good precaution Good advice. Another way is to put in an extra wire (or fold over the thin wire) so as to “fill up” the power pole before you crimp it. Scott W7SLS > On Oct 4, 2019, at 8:41 AM, John Ackermann. N8UR <jra@febo.com> wrote: > > West Mountain is a good source for all things PowerPole, but there are a bunch of other vendors as well. And do youself a favor -- spend $30 on the three size 15/30/45 amp crimping tool. It saves much aggravation. But if you're using thin wire, soldering after crimping is a good precaution. > > On Oct 4, 2019, 10:03 AM, at 10:03 AM, Bill Dailey <docdailey@gmail.com> wrote: >> Yes. I am using 12v agm. Good wmr for the connectors also? >> >> Bill Dailey >> >> Negativity always wins the short game. But positivity wins the long >> game. - Gary Vaynerchuk >> >> Don’t be easy to understand, >> Be impossible to misunderstand >> - Steve Sims >> >>> On Oct 4, 2019, at 7:17 AM, John Ackermann. N8UR <jra@febo.com> >> wrote: >>> >>> I use lots and lots of Anderson PowerPoles and (mostly) West >> Mountain Radio distribution units. I have different color codes for >> different voltages -- red/black for 12v, orange/black for 24v, >> green/black for 5v, etc. Primary 12 and 24 volt sources are big AGM >> batteries across float chargers. >>> >>>> On Oct 4, 2019, 2:03 AM, at 2:03 AM, Bill Dailey >> <docdailey@gmail.com> wrote: >>>> Setting up a new workbench and am wondering what wisdom people can >>>> offer. I am powering numerous synthesizers (5v), small receivers >> (5v), >>>> Upconverters (5v), larger receivers (12v), fury Gpsdo’s.. etc. >> anyone >>>> use something neat and not real expensive for distributing 5v and >> 12v. >>>> I am hoping for a long COTS pcb with fusing and maybe holes for >> plugs. >>>> >>>> >>>> Any insights? >>>> >>>> Bill >>>> >>>> Bill Dailey >>>> >>>> Negativity always wins the short game. But positivity wins the long >>>> game. - Gary Vaynerchuk >>>> >>>> Don’t be easy to understand, >>>> Be impossible to misunderstand >>>> - Steve Sims >>>> _______________________________________________ >>>> time-nuts mailing list -- time-nuts@lists.febo.com >>>> To unsubscribe, go to >>>> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >>>> and follow the instructions there. >>> _______________________________________________ >>> time-nuts mailing list -- time-nuts@lists.febo.com >>> To unsubscribe, go to >> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >>> and follow the instructions there. >> _______________________________________________ >> time-nuts mailing list -- time-nuts@lists.febo.com >> To unsubscribe, go to >> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >> and follow the instructions there. > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there.
DJ
Didier Juges
Fri, Oct 4, 2019 7:23 PM
That's what I do too. I do use Power Pole for my ham stuff that draws high
current but for all the <2A 12V stuff the 5.1mm barrel connector with
positive center is hard to beat because I have so many power sources and
equipment already wired for it. I am not ready to rewire all the off the
shelf equipment that came with one of those.
Power Pole are convenient for batteries though because you can use the
connector to charge the battery or use it as a source.
Didier KO4BB
On Fri, Oct 4, 2019, 2:01 PM Taka Kamiya via time-nuts <
24V
(Mr.) Taka Kamiya
KB4EMF / ex JF2DKG
Any insights?
Bill
Bill Dailey
  • Gary Vaynerchuk
  • Steve Sims
That's what I do too. I do use Power Pole for my ham stuff that draws high current but for all the <2A 12V stuff the 5.1mm barrel connector with positive center is hard to beat because I have so many power sources and equipment already wired for it. I am not ready to rewire all the off the shelf equipment that came with one of those. Power Pole are convenient for batteries though because you can use the connector to charge the battery or use it as a source. Didier KO4BB On Fri, Oct 4, 2019, 2:01 PM Taka Kamiya via time-nuts < time-nuts@lists.febo.com> wrote: > Mine is very simple.... > USB connector for 5VBarrel connector 5.5/2.1mm for 12VTerminal strip for > 24V > None of them are high power devices. > > --------------------------------------- > (Mr.) Taka Kamiya > KB4EMF / ex JF2DKG > > > On Friday, October 4, 2019, 2:03:55 AM EDT, Bill Dailey < > docdailey@gmail.com> wrote: > > Setting up a new workbench and am wondering what wisdom people can > offer. I am powering numerous synthesizers (5v), small receivers (5v), > Upconverters (5v), larger receivers (12v), fury Gpsdo’s.. etc. anyone use > something neat and not real expensive for distributing 5v and 12v. I am > hoping for a long COTS pcb with fusing and maybe holes for plugs. > > Any insights? > > Bill > > Bill Dailey > > Negativity always wins the short game. But positivity wins the long game. > - Gary Vaynerchuk > > Don’t be easy to understand, > Be impossible to misunderstand > - Steve Sims > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to > http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there. > > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to > http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there. >
PK
Poul-Henning Kamp
Fri, Oct 4, 2019 7:51 PM
In message 119811778.3750152.1570204871728@mail.yahoo.com, Taka Kamiya via ti
me-nuts writes:
Yes, I forgot to mention that too:
I have very few 5V devices, but I power them all using USB cables
and an "Industrial[1] USB Hub" which takes 10-30V input power.
As long as you don't plug the hub's upstream ("B") port into a
computer the noise-level seems fine.
Poul-Henning
[1]  = Metal case with mounting holes instead of oddly shaped plastic
-------- In message <119811778.3750152.1570204871728@mail.yahoo.com>, Taka Kamiya via ti me-nuts writes: >Mine is very simple.... >USB connector for 5VBarrel connector 5.5/2.1mm for 12VTerminal strip for 24V >None of them are high power devices. Yes, I forgot to mention that too: I have very few 5V devices, but I power them all using USB cables and an "Industrial[1] USB Hub" which takes 10-30V input power. As long as you don't plug the hub's upstream ("B") port into a computer the noise-level seems fine. Poul-Henning [1] = Metal case with mounting holes instead of oddly shaped plastic -- Poul-Henning Kamp | UNIX since Zilog Zeus 3.20 phk@FreeBSD.ORG | TCP/IP since RFC 956 FreeBSD committer | BSD since 4.3-tahoe Never attribute to malice what can adequately be explained by incompetence.
W-
W7SLS - Scott Scheirman
Fri, Oct 4, 2019 8:13 PM
Perhaps piling on, but be sure to adopt the “ARES standard” (same as rig runner) for your 12 v power poles ( so you don’t blow up your or their equipment, when a friend visits
S
Sent from my iPhone
Didier KO4BB
24V
(Mr.) Taka Kamiya
KB4EMF / ex JF2DKG
Any insights?
Bill
Bill Dailey
  • Gary Vaynerchuk
  • Steve Sims
Perhaps piling on, but be sure to adopt the “ARES standard” (same as rig runner) for your 12 v power poles ( so you don’t blow up your or their equipment, when a friend visits S Sent from my iPhone > On Oct 4, 2019, at 1:06 PM, Didier Juges <shalimr9@gmail.com> wrote: > > That's what I do too. I do use Power Pole for my ham stuff that draws high > current but for all the <2A 12V stuff the 5.1mm barrel connector with > positive center is hard to beat because I have so many power sources and > equipment already wired for it. I am not ready to rewire all the off the > shelf equipment that came with one of those. > > Power Pole are convenient for batteries though because you can use the > connector to charge the battery or use it as a source. > > Didier KO4BB > >> On Fri, Oct 4, 2019, 2:01 PM Taka Kamiya via time-nuts < >> time-nuts@lists.febo.com> wrote: >> >> Mine is very simple.... >> USB connector for 5VBarrel connector 5.5/2.1mm for 12VTerminal strip for >> 24V >> None of them are high power devices. >> >> --------------------------------------- >> (Mr.) Taka Kamiya >> KB4EMF / ex JF2DKG >> >> >> On Friday, October 4, 2019, 2:03:55 AM EDT, Bill Dailey < >> docdailey@gmail.com> wrote: >> >> Setting up a new workbench and am wondering what wisdom people can >> offer. I am powering numerous synthesizers (5v), small receivers (5v), >> Upconverters (5v), larger receivers (12v), fury Gpsdo’s.. etc. anyone use >> something neat and not real expensive for distributing 5v and 12v. I am >> hoping for a long COTS pcb with fusing and maybe holes for plugs. >> >> Any insights? >> >> Bill >> >> Bill Dailey >> >> Negativity always wins the short game. But positivity wins the long game. >> - Gary Vaynerchuk >> >> Don’t be easy to understand, >> Be impossible to misunderstand >> - Steve Sims >> _______________________________________________ >> time-nuts mailing list -- time-nuts@lists.febo.com >> To unsubscribe, go to >> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >> and follow the instructions there. >> >> _______________________________________________ >> time-nuts mailing list -- time-nuts@lists.febo.com >> To unsubscribe, go to >> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >> and follow the instructions there. >> > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there.
PK
Poul-Henning Kamp
Fri, Oct 4, 2019 8:41 PM
In message 5D979AC0.80304@rogers.com, MLewis writes:
connections.
Dabbling in audio-homoepathy are we ?
No, don't bother responding unless you have a reference to peer-reviewed
scientific documentation for you claim.
-------- In message <5D979AC0.80304@rogers.com>, MLewis writes: >With audio signals, a soldered crimp is one of the worst possible >connections. Dabbling in audio-homoepathy are we ? No, don't bother responding unless you have a reference to peer-reviewed scientific documentation for you claim. -- Poul-Henning Kamp | UNIX since Zilog Zeus 3.20 phk@FreeBSD.ORG | TCP/IP since RFC 956 FreeBSD committer | BSD since 4.3-tahoe Never attribute to malice what can adequately be explained by incompetence.
J
jimlux
Fri, Oct 4, 2019 8:53 PM
+++10 -- the right crimping tool is a godsend.  There's also a little
tool that helps remove the contact.
https://powerwerx.com/ is another source that's done well for me.. Lots
of inexpensive distribution stuff without fancyness (basically big
clusters of connectors).
They also have watt/current/voltage meters that plug-in inline that
handle a wide range of voltages (5-60V). however "Only current from
source to load can be measured. Drawing current in reverse will cause
damage to the meter."
They also sell the west mountain gear.
Bill Dailey
  • Steve Sims
(5v),
anyone
12v.
plugs.
Any insights?
Bill
Bill Dailey
  • Steve Sims
On 10/4/19 8:41 AM, John Ackermann. N8UR wrote: > West Mountain is a good source for all things PowerPole, but there are a bunch of other vendors as well.  And do youself a favor -- spend $30 on the three size 15/30/45 amp crimping tool. +++10 -- the right crimping tool is a godsend. There's also a little tool that helps remove the contact. https://powerwerx.com/ is another source that's done well for me.. Lots of inexpensive distribution stuff without fancyness (basically big clusters of connectors). They also have watt/current/voltage meters that plug-in inline that handle a wide range of voltages (5-60V). however "Only current from source to load can be measured. Drawing current in reverse will cause damage to the meter." They also sell the west mountain gear. It saves much aggravation.  But if you're using thin wire, soldering after crimping is a good precaution. > > On Oct 4, 2019, 10:03 AM, at 10:03 AM, Bill Dailey <docdailey@gmail.com> wrote: >> Yes. I am using 12v agm. Good wmr for the connectors also? >> >> Bill Dailey >> >> Negativity always wins the short game. But positivity wins the long >> game. - Gary Vaynerchuk >> >> Don’t be easy to understand, >> Be impossible to misunderstand >> - Steve Sims >> >>> On Oct 4, 2019, at 7:17 AM, John Ackermann. N8UR <jra@febo.com> >> wrote: >>> >>> I use lots and lots of Anderson PowerPoles and (mostly) West >> Mountain Radio distribution units. I have different color codes for >> different voltages -- red/black for 12v, orange/black for 24v, >> green/black for 5v, etc. Primary 12 and 24 volt sources are big AGM >> batteries across float chargers. >>> >>>> On Oct 4, 2019, 2:03 AM, at 2:03 AM, Bill Dailey >> <docdailey@gmail.com> wrote: >>>> Setting up a new workbench and am wondering what wisdom people can >>>> offer. I am powering numerous synthesizers (5v), small receivers >> (5v), >>>> Upconverters (5v), larger receivers (12v), fury Gpsdo’s.. etc. >> anyone >>>> use something neat and not real expensive for distributing 5v and >> 12v. >>>> I am hoping for a long COTS pcb with fusing and maybe holes for >> plugs. >>>> >>>> >>>> Any insights? >>>> >>>> Bill >>>> >>>> Bill Dailey >>>> >>>> Negativity always wins the short game. But positivity wins the long >>>> game. - Gary Vaynerchuk >>>> >>>> Don’t be easy to understand, >>>> Be impossible to misunderstand >>>> - Steve Sims >>>> _______________________________________________ >>>> time-nuts mailing list -- time-nuts@lists.febo.com >>>> To unsubscribe, go to >>>> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >>>> and follow the instructions there. >>> _______________________________________________ >>> time-nuts mailing list -- time-nuts@lists.febo.com >>> To unsubscribe, go to >> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >>> and follow the instructions there. >> _______________________________________________ >> time-nuts mailing list -- time-nuts@lists.febo.com >> To unsubscribe, go to >> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >> and follow the instructions there. > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there. >
J
jimlux
Fri, Oct 4, 2019 8:57 PM
combined in one.
I agree on not soldering - soldering makes for a stress concentration at
the end of the strands.  With a crimped connector, wiggling the wire
bends all the strands differently. And the solder does change the
"springyness" of the crimping.
With the right crimp tool, and the willingness to throw away marginal
crimps.
If you were to pot the wire into the connector, that would probably
solve the brittle solder problem. But that's yet another assembly step
to squirt the epoxy in.
On 10/4/19 12:17 PM, MLewis wrote: > With audio signals, a soldered crimp is one of the worst possible > connections. I wouldn't think it would be different for anything else, > but may go undetected until failure. If you've used the correct size of > crimp and used a proper crimping tool, then you've got the proper > pressure for a solid reliable connection. If you then solder, the heat > expands the crimp lessening the crimp pressure, and when it cools it's > no longer at the correct crimp pressure (often the wire will pull right > out), and with iffy wicking of solder. The worst of both methods > combined in one. > > Where the wire is too thin for the crimp I have available, I've cut a > piece of a correct thickness wire/cable, inserted that into the crimp > along with the signal wire/cable, so it's crimped between them. I don't > know if that is the best way of handling that, but it's worked for me. > I agree on not soldering - soldering makes for a stress concentration at the end of the strands. With a crimped connector, wiggling the wire bends all the strands differently. And the solder does change the "springyness" of the crimping. With the right crimp tool, and the willingness to throw away marginal crimps. If you were to pot the wire into the connector, that would probably solve the brittle solder problem. But that's yet another assembly step to squirt the epoxy in.
JA
John Ackermann N8UR
Fri, Oct 4, 2019 9:07 PM
The idea of using a short piece of thicker wire is a good one.  Thanks
for that!
combined in one.
The idea of using a short piece of thicker wire is a good one. Thanks for that! On 10/4/19 3:17 PM, MLewis wrote: > With audio signals, a soldered crimp is one of the worst possible > connections. I wouldn't think it would be different for anything else, > but may go undetected until failure. If you've used the correct size of > crimp and used a proper crimping tool, then you've got the proper > pressure for a solid reliable connection. If you then solder, the heat > expands the crimp lessening the crimp pressure, and when it cools it's > no longer at the correct crimp pressure (often the wire will pull right > out), and with iffy wicking of solder. The worst of both methods > combined in one. > > Where the wire is too thin for the crimp I have available, I've cut a > piece of a correct thickness wire/cable, inserted that into the crimp > along with the signal wire/cable, so it's crimped between them. I don't > know if that is the best way of handling that, but it's worked for me. > > On 04/10/2019 11:41 AM, John Ackermann. N8UR wrote: >> West Mountain is a good source for all things PowerPole, but there are >> a bunch of other vendors as well.  And do youself a favor -- spend $30 >> on the three size 15/30/45 amp crimping tool.  It saves much >> aggravation.  But if you're using thin wire, soldering after crimping >> is a good precaution. >> > > > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to > http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there.
TK
Taka Kamiya
I used to use power pole, too but they don't lock firmly enough for my liking.  So I don't use them anymore.  It would be perfect if there is an option to add positive locking mechanism of some kind.
(Mr.) Taka Kamiya
KB4EMF / ex JF2DKG
On Friday, October 4, 2019, 4:06:50 PM EDT, Didier Juges <shalimr9@gmail.com> wrote:
Didier KO4BB
24V
(Mr.) Taka Kamiya
KB4EMF / ex JF2DKG
Any insights?
Bill
Bill Dailey
  • Gary Vaynerchuk
  • Steve Sims
I used to use power pole, too but they don't lock firmly enough for my liking.  So I don't use them anymore.  It would be perfect if there is an option to add positive locking mechanism of some kind. --------------------------------------- (Mr.) Taka Kamiya KB4EMF / ex JF2DKG On Friday, October 4, 2019, 4:06:50 PM EDT, Didier Juges <shalimr9@gmail.com> wrote: That's what I do too. I do use Power Pole for my ham stuff that draws high current but for all the <2A 12V stuff the 5.1mm barrel connector with positive center is hard to beat because I have so many power sources and equipment already wired for it. I am not ready to rewire all the off the shelf equipment that came with one of those. Power Pole are convenient for batteries though because you can use the connector to charge the battery or use it as a source. Didier KO4BB On Fri, Oct 4, 2019, 2:01 PM Taka Kamiya via time-nuts < time-nuts@lists.febo.com> wrote: > Mine is very simple.... > USB connector for 5VBarrel connector 5.5/2.1mm for 12VTerminal strip for > 24V > None of them are high power devices. > > --------------------------------------- > (Mr.) Taka Kamiya > KB4EMF / ex JF2DKG > > >    On Friday, October 4, 2019, 2:03:55 AM EDT, Bill Dailey < > docdailey@gmail.com> wrote: > >  Setting up a new workbench and am wondering what wisdom people can > offer.  I am powering numerous synthesizers (5v), small receivers (5v), > Upconverters (5v), larger receivers (12v), fury Gpsdo’s.. etc.  anyone use > something neat and not real expensive for distributing 5v and 12v.  I am > hoping for a long COTS pcb with fusing and maybe holes for plugs. > > Any insights? > > Bill > > Bill Dailey > > Negativity always wins the short game. But positivity wins the long game. > - Gary Vaynerchuk > > Don’t be easy to understand, > Be impossible to misunderstand > - Steve Sims > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to > http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there. > > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to > http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there. > _______________________________________________ time-nuts mailing list -- time-nuts@lists.febo.com To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com and follow the instructions there.
BD
Bill Dailey
Fri, Oct 4, 2019 10:10 PM
Thanks to all.  I know what to do now.  Appreciated. I am finally getting to the point where I can start playing again.  Work and life has been exceptionally busy.  I am excited to build a new bench right.
Anderson it is, powerwerx and or west mountain and stick to standards.  I will search for the industrial usb hub for 5V.
Bill Dailey
  • Steve Sims
for that!
combined in one.
Thanks to all. I know what to do now. Appreciated. I am finally getting to the point where I can start playing again. Work and life has been exceptionally busy. I am excited to build a new bench right. Anderson it is, powerwerx and or west mountain and stick to standards. I will search for the industrial usb hub for 5V. Bill Dailey Negativity always wins the short game. But positivity wins the long game. - Gary Vaynerchuk Don’t be easy to understand, Be impossible to misunderstand - Steve Sims > On Oct 4, 2019, at 5:01 PM, John Ackermann N8UR <jra@febo.com> wrote: > > The idea of using a short piece of thicker wire is a good one. Thanks > for that! > >> On 10/4/19 3:17 PM, MLewis wrote: >> With audio signals, a soldered crimp is one of the worst possible >> connections. I wouldn't think it would be different for anything else, >> but may go undetected until failure. If you've used the correct size of >> crimp and used a proper crimping tool, then you've got the proper >> pressure for a solid reliable connection. If you then solder, the heat >> expands the crimp lessening the crimp pressure, and when it cools it's >> no longer at the correct crimp pressure (often the wire will pull right >> out), and with iffy wicking of solder. The worst of both methods >> combined in one. >> >> Where the wire is too thin for the crimp I have available, I've cut a >> piece of a correct thickness wire/cable, inserted that into the crimp >> along with the signal wire/cable, so it's crimped between them. I don't >> know if that is the best way of handling that, but it's worked for me. >> >>> On 04/10/2019 11:41 AM, John Ackermann. N8UR wrote: >>> West Mountain is a good source for all things PowerPole, but there are >>> a bunch of other vendors as well. And do youself a favor -- spend $30 >>> on the three size 15/30/45 amp crimping tool. It saves much >>> aggravation. But if you're using thin wire, soldering after crimping >>> is a good precaution. >>> >> >> >> _______________________________________________ >> time-nuts mailing list -- time-nuts@lists.febo.com >> To unsubscribe, go to >> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >> and follow the instructions there. > > > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there.
MF
Martin Flynn
Fri, Oct 4, 2019 10:15 PM
Wire Ferrules are the best way to use thin wire in a powerpole
http://www.ferrulesdirect.com/electrical/NonInsFerr2620.htm
for that!
combined in one.
Wire Ferrules are the best way to use thin wire in a powerpole http://www.ferrulesdirect.com/electrical/NonInsFerr2620.htm On 10/4/2019 5:07 PM, John Ackermann N8UR wrote: > The idea of using a short piece of thicker wire is a good one. Thanks > for that! > > On 10/4/19 3:17 PM, MLewis wrote: >> With audio signals, a soldered crimp is one of the worst possible >> connections. I wouldn't think it would be different for anything else, >> but may go undetected until failure. If you've used the correct size of >> crimp and used a proper crimping tool, then you've got the proper >> pressure for a solid reliable connection. If you then solder, the heat >> expands the crimp lessening the crimp pressure, and when it cools it's >> no longer at the correct crimp pressure (often the wire will pull right >> out), and with iffy wicking of solder. The worst of both methods >> combined in one. >> >> Where the wire is too thin for the crimp I have available, I've cut a >> piece of a correct thickness wire/cable, inserted that into the crimp >> along with the signal wire/cable, so it's crimped between them. I don't >> know if that is the best way of handling that, but it's worked for me. >> >> On 04/10/2019 11:41 AM, John Ackermann. N8UR wrote: >>> West Mountain is a good source for all things PowerPole, but there are >>> a bunch of other vendors as well.  And do youself a favor -- spend $30 >>> on the three size 15/30/45 amp crimping tool.  It saves much >>> aggravation.  But if you're using thin wire, soldering after crimping >>> is a good precaution. >>> >> >> _______________________________________________ >> time-nuts mailing list -- time-nuts@lists.febo.com >> To unsubscribe, go to >> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >> and follow the instructions there. > > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there.
PB
Paul Bicknell
Fri, Oct 4, 2019 10:21 PM
Hi where the wire is too thin for the crimp
I actually strip the wire to long and fold it half
One reason to crimp is so there is not a hard line for a fracture
IE a point for the cable to brake
By soldering the joint you actually introduce a potential fracture point
It's all my time playing with aircraft and destructive testing
Sorry it was suppose to be non destructive testing but things brake at times
Paul
Ackermann N8UR
Sent: 04 October 2019 22:08
To: time-nuts@lists.febo.com
for that!
combined in one.
Hi where the wire is too thin for the crimp I actually strip the wire to long and fold it half One reason to crimp is so there is not a hard line for a fracture IE a point for the cable to brake By soldering the joint you actually introduce a potential fracture point It's all my time playing with aircraft and destructive testing Sorry it was suppose to be non destructive testing but things brake at times Paul -----Original Message----- From: time-nuts [mailto:time-nuts-bounces@lists.febo.com] On Behalf Of John Ackermann N8UR Sent: 04 October 2019 22:08 To: time-nuts@lists.febo.com Subject: Re: [time-nuts] DC distribution The idea of using a short piece of thicker wire is a good one. Thanks for that! On 10/4/19 3:17 PM, MLewis wrote: > With audio signals, a soldered crimp is one of the worst possible > connections. I wouldn't think it would be different for anything else, > but may go undetected until failure. If you've used the correct size of > crimp and used a proper crimping tool, then you've got the proper > pressure for a solid reliable connection. If you then solder, the heat > expands the crimp lessening the crimp pressure, and when it cools it's > no longer at the correct crimp pressure (often the wire will pull right > out), and with iffy wicking of solder. The worst of both methods > combined in one. > > Where the wire is too thin for the crimp I have available, I've cut a > piece of a correct thickness wire/cable, inserted that into the crimp > along with the signal wire/cable, so it's crimped between them. I don't > know if that is the best way of handling that, but it's worked for me. > > On 04/10/2019 11:41 AM, John Ackermann. N8UR wrote: >> West Mountain is a good source for all things PowerPole, but there are >> a bunch of other vendors as well.  And do youself a favor -- spend $30 >> on the three size 15/30/45 amp crimping tool.  It saves much >> aggravation.  But if you're using thin wire, soldering after crimping >> is a good precaution. >> > > > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to > http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there. _______________________________________________ time-nuts mailing list -- time-nuts@lists.febo.com To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com and follow the instructions there. ----- No virus found in this message. Checked by AVG - www.avg.com Version: 2016.0.8048 / Virus Database: 4793/15886 - Release Date: 08/14/18 Internal Virus Database is out of date.
D
djl
Fri, Oct 4, 2019 10:30 PM
Long ago and far away, I did read that a large(60% or so) of failures in
ww2 style equipment was due to wire breakage right at the terminal, that
is solder wicking into stranded wire. The very careful wire wrap through
holes or around terminals did nothing.  Power pole connectors do not
have crimped insulation. Spade lug and rings very often do. Strain
relief is a must, especially in presence of higher frequecy vibration.
These facts are around, just cannot recall where.
Don
connections.
peer-reviewed
Dr. Don Latham  AJ7LL
PO Box 404, Frenchtown, MT, 59834
VOX: 406-626-4304
Long ago and far away, I did read that a large(60% or so) of failures in ww2 style equipment was due to wire breakage right at the terminal, that is solder wicking into stranded wire. The very careful wire wrap through holes or around terminals did nothing. Power pole connectors do not have crimped insulation. Spade lug and rings very often do. Strain relief is a must, especially in presence of higher frequecy vibration. These facts are around, just cannot recall where. Don On 2019-10-04 14:41, Poul-Henning Kamp wrote: > -------- > In message <5D979AC0.80304@rogers.com>, MLewis writes: > >> With audio signals, a soldered crimp is one of the worst possible >> connections. > > Dabbling in audio-homoepathy are we ? > > No, don't bother responding unless you have a reference to > peer-reviewed > scientific documentation for you claim. -- Dr. Don Latham AJ7LL PO Box 404, Frenchtown, MT, 59834 VOX: 406-626-4304
M
MLewis
Fri, Oct 4, 2019 10:43 PM
It works, but note that folding the conductor over to fill the crimp
fails NASA's workmanship standards. I'd expect that trick with the
thicker wire would too.
for that!
combined in one.
It works, but note that folding the conductor over to fill the crimp fails NASA's workmanship standards. I'd expect that trick with the thicker wire would too. On 04/10/2019 5:07 PM, John Ackermann N8UR wrote: > The idea of using a short piece of thicker wire is a good one. Thanks > for that! > > On 10/4/19 3:17 PM, MLewis wrote: >> With audio signals, a soldered crimp is one of the worst possible >> connections. I wouldn't think it would be different for anything else, >> but may go undetected until failure. If you've used the correct size of >> crimp and used a proper crimping tool, then you've got the proper >> pressure for a solid reliable connection. If you then solder, the heat >> expands the crimp lessening the crimp pressure, and when it cools it's >> no longer at the correct crimp pressure (often the wire will pull right >> out), and with iffy wicking of solder. The worst of both methods >> combined in one. >> >> Where the wire is too thin for the crimp I have available, I've cut a >> piece of a correct thickness wire/cable, inserted that into the crimp >> along with the signal wire/cable, so it's crimped between them. I don't >> know if that is the best way of handling that, but it's worked for me. >> >> On 04/10/2019 11:41 AM, John Ackermann. N8UR wrote: >>> West Mountain is a good source for all things PowerPole, but there are >>> a bunch of other vendors as well. And do youself a favor -- spend $30 >>> on the three size 15/30/45 amp crimping tool. It saves much >>> aggravation. But if you're using thin wire, soldering after crimping >>> is a good precaution. >>> >> >> _______________________________________________ >> time-nuts mailing list -- time-nuts@lists.febo.com >> To unsubscribe, go to >> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >> and follow the instructions there. > > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there.
W-
Fri, Oct 4, 2019 11:25 PM
Many ways to lock them
Insert a small 3”? tie wrap from one hole to the other, or use those twist ties that usb and power cables ship with, or use the locking mechanisms from WMR, and/or ...
Good luck whatever you decide is right for your situation
Scott
Sent from my iPhone
On Oct 4, 2019, at 4:04 PM, Taka Kamiya via time-nuts time-nuts@lists.febo.com wrote:
(Mr.) Taka Kamiya
KB4EMF / ex JF2DKG
Didier KO4BB
24V
(Mr.) Taka Kamiya
KB4EMF / ex JF2DKG
Any insights?
Bill
Bill Dailey
  • Gary Vaynerchuk
  • Steve Sims
Many ways to lock them Insert a small 3”? tie wrap from one hole to the other, or use those twist ties that usb and power cables ship with, or use the locking mechanisms from WMR, and/or ... Good luck whatever you decide is right for your situation Scott Sent from my iPhone > On Oct 4, 2019, at 4:04 PM, Taka Kamiya via time-nuts <time-nuts@lists.febo.com> wrote: > > I used to use power pole, too but they don't lock firmly enough for my liking. So I don't use them anymore. It would be perfect if there is an option to add positive locking mechanism of some kind. > > --------------------------------------- > (Mr.) Taka Kamiya > KB4EMF / ex JF2DKG > > > On Friday, October 4, 2019, 4:06:50 PM EDT, Didier Juges <shalimr9@gmail.com> wrote: > > That's what I do too. I do use Power Pole for my ham stuff that draws high > current but for all the <2A 12V stuff the 5.1mm barrel connector with > positive center is hard to beat because I have so many power sources and > equipment already wired for it. I am not ready to rewire all the off the > shelf equipment that came with one of those. > > Power Pole are convenient for batteries though because you can use the > connector to charge the battery or use it as a source. > > Didier KO4BB > >> On Fri, Oct 4, 2019, 2:01 PM Taka Kamiya via time-nuts < >> time-nuts@lists.febo.com> wrote: >> >> Mine is very simple.... >> USB connector for 5VBarrel connector 5.5/2.1mm for 12VTerminal strip for >> 24V >> None of them are high power devices. >> >> --------------------------------------- >> (Mr.) Taka Kamiya >> KB4EMF / ex JF2DKG >> >> >> On Friday, October 4, 2019, 2:03:55 AM EDT, Bill Dailey < >> docdailey@gmail.com> wrote: >> >> Setting up a new workbench and am wondering what wisdom people can >> offer. I am powering numerous synthesizers (5v), small receivers (5v), >> Upconverters (5v), larger receivers (12v), fury Gpsdo’s.. etc. anyone use >> something neat and not real expensive for distributing 5v and 12v. I am >> hoping for a long COTS pcb with fusing and maybe holes for plugs. >> >> Any insights? >> >> Bill >> >> Bill Dailey >> >> Negativity always wins the short game. But positivity wins the long game. >> - Gary Vaynerchuk >> >> Don’t be easy to understand, >> Be impossible to misunderstand >> - Steve Sims >> _______________________________________________ >> time-nuts mailing list -- time-nuts@lists.febo.com >> To unsubscribe, go to >> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >> and follow the instructions there. >> >> _______________________________________________ >> time-nuts mailing list -- time-nuts@lists.febo.com >> To unsubscribe, go to >> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >> and follow the instructions there. >> > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there. > > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there.
BD
Bill Dailey
Fri, Oct 4, 2019 11:38 PM
There are locks you can get.  I saw them on Mountain West today.
Bill Dailey
  • Steve Sims
On Oct 4, 2019, at 6:04 PM, Taka Kamiya via time-nuts time-nuts@lists.febo.com wrote:
(Mr.) Taka Kamiya
KB4EMF / ex JF2DKG
Didier KO4BB
24V
(Mr.) Taka Kamiya
KB4EMF / ex JF2DKG
Any insights?
Bill
Bill Dailey
  • Gary Vaynerchuk
  • Steve Sims
There are locks you can get. I saw them on Mountain West today. Bill Dailey Negativity always wins the short game. But positivity wins the long game. - Gary Vaynerchuk Don’t be easy to understand, Be impossible to misunderstand - Steve Sims > On Oct 4, 2019, at 6:04 PM, Taka Kamiya via time-nuts <time-nuts@lists.febo.com> wrote: > > I used to use power pole, too but they don't lock firmly enough for my liking. So I don't use them anymore. It would be perfect if there is an option to add positive locking mechanism of some kind. > > --------------------------------------- > (Mr.) Taka Kamiya > KB4EMF / ex JF2DKG > > > On Friday, October 4, 2019, 4:06:50 PM EDT, Didier Juges <shalimr9@gmail.com> wrote: > > That's what I do too. I do use Power Pole for my ham stuff that draws high > current but for all the <2A 12V stuff the 5.1mm barrel connector with > positive center is hard to beat because I have so many power sources and > equipment already wired for it. I am not ready to rewire all the off the > shelf equipment that came with one of those. > > Power Pole are convenient for batteries though because you can use the > connector to charge the battery or use it as a source. > > Didier KO4BB > >> On Fri, Oct 4, 2019, 2:01 PM Taka Kamiya via time-nuts < >> time-nuts@lists.febo.com> wrote: >> >> Mine is very simple.... >> USB connector for 5VBarrel connector 5.5/2.1mm for 12VTerminal strip for >> 24V >> None of them are high power devices. >> >> --------------------------------------- >> (Mr.) Taka Kamiya >> KB4EMF / ex JF2DKG >> >> >> On Friday, October 4, 2019, 2:03:55 AM EDT, Bill Dailey < >> docdailey@gmail.com> wrote: >> >> Setting up a new workbench and am wondering what wisdom people can >> offer. I am powering numerous synthesizers (5v), small receivers (5v), >> Upconverters (5v), larger receivers (12v), fury Gpsdo’s.. etc. anyone use >> something neat and not real expensive for distributing 5v and 12v. I am >> hoping for a long COTS pcb with fusing and maybe holes for plugs. >> >> Any insights? >> >> Bill >> >> Bill Dailey >> >> Negativity always wins the short game. But positivity wins the long game. >> - Gary Vaynerchuk >> >> Don’t be easy to understand, >> Be impossible to misunderstand >> - Steve Sims >> _______________________________________________ >> time-nuts mailing list -- time-nuts@lists.febo.com >> To unsubscribe, go to >> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >> and follow the instructions there. >> >> _______________________________________________ >> time-nuts mailing list -- time-nuts@lists.febo.com >> To unsubscribe, go to >> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >> and follow the instructions there. >> > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there. > > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there.
SM
Scott McGrath
Sat, Oct 5, 2019 12:49 AM
+1 for powerpole connectors and purchasing a proper ratcheting crimper for the powerpoles.  AND being willing to discard marginal crimps.
Content by Scott
Typos by Siri
Bill Dailey
  • Steve Sims
(Mr.) Taka Kamiya
KB4EMF / ex JF2DKG
On Friday, October 4, 2019, 4:06:50 PM EDT, Didier Juges shalimr9@gmail.com wrote:
Didier KO4BB
24V
(Mr.) Taka Kamiya
KB4EMF / ex JF2DKG
Any insights?
Bill
Bill Dailey
  • Gary Vaynerchuk
  • Steve Sims
+1 for powerpole connectors and purchasing a proper ratcheting crimper for the powerpoles. AND being willing to discard marginal crimps. Content by Scott Typos by Siri On Oct 4, 2019, at 5:38 PM, Bill Dailey <docdailey@gmail.com> wrote: There are locks you can get. I saw them on Mountain West today. Bill Dailey Negativity always wins the short game. But positivity wins the long game. - Gary Vaynerchuk Don’t be easy to understand, Be impossible to misunderstand - Steve Sims > On Oct 4, 2019, at 6:04 PM, Taka Kamiya via time-nuts <time-nuts@lists.febo.com> wrote: > > I used to use power pole, too but they don't lock firmly enough for my liking. So I don't use them anymore. It would be perfect if there is an option to add positive locking mechanism of some kind. > > --------------------------------------- > (Mr.) Taka Kamiya > KB4EMF / ex JF2DKG > > > On Friday, October 4, 2019, 4:06:50 PM EDT, Didier Juges <shalimr9@gmail.com> wrote: > > That's what I do too. I do use Power Pole for my ham stuff that draws high > current but for all the <2A 12V stuff the 5.1mm barrel connector with > positive center is hard to beat because I have so many power sources and > equipment already wired for it. I am not ready to rewire all the off the > shelf equipment that came with one of those. > > Power Pole are convenient for batteries though because you can use the > connector to charge the battery or use it as a source. > > Didier KO4BB > >> On Fri, Oct 4, 2019, 2:01 PM Taka Kamiya via time-nuts < >> time-nuts@lists.febo.com> wrote: >> >> Mine is very simple.... >> USB connector for 5VBarrel connector 5.5/2.1mm for 12VTerminal strip for >> 24V >> None of them are high power devices. >> >> --------------------------------------- >> (Mr.) Taka Kamiya >> KB4EMF / ex JF2DKG >> >> >> On Friday, October 4, 2019, 2:03:55 AM EDT, Bill Dailey < >> docdailey@gmail.com> wrote: >> >> Setting up a new workbench and am wondering what wisdom people can >> offer. I am powering numerous synthesizers (5v), small receivers (5v), >> Upconverters (5v), larger receivers (12v), fury Gpsdo’s.. etc. anyone use >> something neat and not real expensive for distributing 5v and 12v. I am >> hoping for a long COTS pcb with fusing and maybe holes for plugs. >> >> Any insights? >> >> Bill >> >> Bill Dailey >> >> Negativity always wins the short game. But positivity wins the long game. >> - Gary Vaynerchuk >> >> Don’t be easy to understand, >> Be impossible to misunderstand >> - Steve Sims >> _______________________________________________ >> time-nuts mailing list -- time-nuts@lists.febo.com >> To unsubscribe, go to >> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >> and follow the instructions there. >> >> _______________________________________________ >> time-nuts mailing list -- time-nuts@lists.febo.com >> To unsubscribe, go to >> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >> and follow the instructions there. >> > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there. > > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there. _______________________________________________ time-nuts mailing list -- time-nuts@lists.febo.com To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com and follow the instructions there.
JA
John Ackermann N8UR
Sat, Oct 5, 2019 12:58 AM
Not a perfect solution, but for semi-permanent connections you can run a small tie-wrap lengthwise so the ends pass through the space between where the wires on each end split and the body.  Cinch it tight and the connectors won't come apart without cutting the tie wrap.
On Oct 4, 2019, 7:04 PM, at 7:04 PM, Taka Kamiya via time-nuts time-nuts@lists.febo.com wrote:
(Mr.) Taka Kamiya
KB4EMF / ex JF2DKG
high
and
the
Didier KO4BB
for
24V
(Mr.) Taka Kamiya
KB4EMF / ex JF2DKG
(5v),
anyone use
am
Any insights?
Bill
Bill Dailey
game.
  • Gary Vaynerchuk
  • Steve Sims
Not a perfect solution, but for semi-permanent connections you can run a small tie-wrap lengthwise so the ends pass through the space between where the wires on each end split and the body.  Cinch it tight and the connectors won't come apart without cutting the tie wrap. On Oct 4, 2019, 7:04 PM, at 7:04 PM, Taka Kamiya via time-nuts <time-nuts@lists.febo.com> wrote: >I used to use power pole, too but they don't lock firmly enough for my >liking.  So I don't use them anymore.  It would be perfect if there is >an option to add positive locking mechanism of some kind. > >--------------------------------------- >(Mr.) Taka Kamiya >KB4EMF / ex JF2DKG > > >On Friday, October 4, 2019, 4:06:50 PM EDT, Didier Juges ><shalimr9@gmail.com> wrote: > >That's what I do too. I do use Power Pole for my ham stuff that draws >high >current but for all the <2A 12V stuff the 5.1mm barrel connector with >positive center is hard to beat because I have so many power sources >and >equipment already wired for it. I am not ready to rewire all the off >the >shelf equipment that came with one of those. > >Power Pole are convenient for batteries though because you can use the >connector to charge the battery or use it as a source. > >Didier KO4BB > >On Fri, Oct 4, 2019, 2:01 PM Taka Kamiya via time-nuts < >time-nuts@lists.febo.com> wrote: > >> Mine is very simple.... >> USB connector for 5VBarrel connector 5.5/2.1mm for 12VTerminal strip >for >> 24V >> None of them are high power devices. >> >> --------------------------------------- >> (Mr.) Taka Kamiya >> KB4EMF / ex JF2DKG >> >> >>    On Friday, October 4, 2019, 2:03:55 AM EDT, Bill Dailey < >> docdailey@gmail.com> wrote: >> >>  Setting up a new workbench and am wondering what wisdom people can >> offer.  I am powering numerous synthesizers (5v), small receivers >(5v), >> Upconverters (5v), larger receivers (12v), fury Gpsdo’s.. etc.  >anyone use >> something neat and not real expensive for distributing 5v and 12v.  I >am >> hoping for a long COTS pcb with fusing and maybe holes for plugs. >> >> Any insights? >> >> Bill >> >> Bill Dailey >> >> Negativity always wins the short game. But positivity wins the long >game. >> - Gary Vaynerchuk >> >> Don’t be easy to understand, >> Be impossible to misunderstand >> - Steve Sims >> _______________________________________________ >> time-nuts mailing list -- time-nuts@lists.febo.com >> To unsubscribe, go to >> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >> and follow the instructions there. >> >> _______________________________________________ >> time-nuts mailing list -- time-nuts@lists.febo.com >> To unsubscribe, go to >> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >> and follow the instructions there. >> >_______________________________________________ >time-nuts mailing list -- time-nuts@lists.febo.com >To unsubscribe, go to >http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >and follow the instructions there. > >_______________________________________________ >time-nuts mailing list -- time-nuts@lists.febo.com >To unsubscribe, go to >http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >and follow the instructions there.
AG
Adrian Godwin
Sat, Oct 5, 2019 11:24 AM
I used powerpoles on a project and tried to use a crimping tool I had to
hand. Amphenol, I think. It appeared to be the right size but ended up
bending the terminal badly where it changes from circular to flat. The
results were unreliable and I ended up soldering (though adding sleeving,
which together with the natural bend-restriction on the shell has mostly
avoided stiffening the wire where it's most vulnerable).
I know some crimp terminal are very fussy about the tool used but it's
usually the miniature ones like JST. Does the powerpole terminal need a
powerpole-specific crimp tool ? I note that the West Mountain tool seems to
be branded by themselves rather than Anderson, but I can't tell if it's
generic or made to their specs.
(Mr.) Taka Kamiya
KB4EMF / ex JF2DKG
high
and
the
Didier KO4BB
for
24V
(Mr.) Taka Kamiya
KB4EMF / ex JF2DKG
(5v),
anyone use
am
Any insights?
Bill
Bill Dailey
game.
  • Gary Vaynerchuk
  • Steve Sims
I used powerpoles on a project and tried to use a crimping tool I had to hand. Amphenol, I think. It appeared to be the right size but ended up bending the terminal badly where it changes from circular to flat. The results were unreliable and I ended up soldering (though adding sleeving, which together with the natural bend-restriction on the shell has mostly avoided stiffening the wire where it's most vulnerable). I know some crimp terminal are very fussy about the tool used but it's usually the miniature ones like JST. Does the powerpole terminal need a powerpole-specific crimp tool ? I note that the West Mountain tool seems to be branded by themselves rather than Anderson, but I can't tell if it's generic or made to their specs. On Sat, Oct 5, 2019 at 2:00 AM John Ackermann N8UR <jra@febo.com> wrote: > Not a perfect solution, but for semi-permanent connections you can run a > small tie-wrap lengthwise so the ends pass through the space between where > the wires on each end split and the body. Cinch it tight and the > connectors won't come apart without cutting the tie wrap. > > On Oct 4, 2019, 7:04 PM, at 7:04 PM, Taka Kamiya via time-nuts < > time-nuts@lists.febo.com> wrote: > >I used to use power pole, too but they don't lock firmly enough for my > >liking. So I don't use them anymore. It would be perfect if there is > >an option to add positive locking mechanism of some kind. > > > >--------------------------------------- > >(Mr.) Taka Kamiya > >KB4EMF / ex JF2DKG > > > > > >On Friday, October 4, 2019, 4:06:50 PM EDT, Didier Juges > ><shalimr9@gmail.com> wrote: > > > >That's what I do too. I do use Power Pole for my ham stuff that draws > >high > >current but for all the <2A 12V stuff the 5.1mm barrel connector with > >positive center is hard to beat because I have so many power sources > >and > >equipment already wired for it. I am not ready to rewire all the off > >the > >shelf equipment that came with one of those. > > > >Power Pole are convenient for batteries though because you can use the > >connector to charge the battery or use it as a source. > > > >Didier KO4BB > > > >On Fri, Oct 4, 2019, 2:01 PM Taka Kamiya via time-nuts < > >time-nuts@lists.febo.com> wrote: > > > >> Mine is very simple.... > >> USB connector for 5VBarrel connector 5.5/2.1mm for 12VTerminal strip > >for > >> 24V > >> None of them are high power devices. > >> > >> --------------------------------------- > >> (Mr.) Taka Kamiya > >> KB4EMF / ex JF2DKG > >> > >> > >> On Friday, October 4, 2019, 2:03:55 AM EDT, Bill Dailey < > >> docdailey@gmail.com> wrote: > >> > >> Setting up a new workbench and am wondering what wisdom people can > >> offer. I am powering numerous synthesizers (5v), small receivers > >(5v), > >> Upconverters (5v), larger receivers (12v), fury Gpsdo’s.. etc. > >anyone use > >> something neat and not real expensive for distributing 5v and 12v. I > >am > >> hoping for a long COTS pcb with fusing and maybe holes for plugs. > >> > >> Any insights? > >> > >> Bill > >> > >> Bill Dailey > >> > >> Negativity always wins the short game. But positivity wins the long > >game. > >> - Gary Vaynerchuk > >> > >> Don’t be easy to understand, > >> Be impossible to misunderstand > >> - Steve Sims > >> _______________________________________________ > >> time-nuts mailing list -- time-nuts@lists.febo.com > >> To unsubscribe, go to > >> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > >> and follow the instructions there. > >> > >> _______________________________________________ > >> time-nuts mailing list -- time-nuts@lists.febo.com > >> To unsubscribe, go to > >> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > >> and follow the instructions there. > >> > >_______________________________________________ > >time-nuts mailing list -- time-nuts@lists.febo.com > >To unsubscribe, go to > >http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > >and follow the instructions there. > > > >_______________________________________________ > >time-nuts mailing list -- time-nuts@lists.febo.com > >To unsubscribe, go to > >http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > >and follow the instructions there. > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to > http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there. >
J
jimlux
Sat, Oct 5, 2019 12:49 PM
connections.
well..
https://nepp.nasa.gov/files/27631/NSTD87394A.pdf
doesn't give why, and doesn't explicitly say "don't crimp and solder"
but does basically say "crimp crimp connectors and solder solder connectors"
TE "Crimp Theory Fundamentals; Advanced" - explanation of what makes a
good crimp, doesn't discuss solder
https://www.youtube.com/watch?v=bAO9eCS65jw
There are actually splices designed to be crimped and soldered - but I
suspect their applicability is for specific applications.
On Monday, I will try to find one of the connector reliability people
for some references.  One challenge is that these practices ("don't
solder crimped connectors") have been around for a long time (at least
70 years), so there may not be recent published information on it.
(recent papers I found on solder joint reliability are all about PWB
connections - esp BGA, CGA, etc.)
And, to be honest, materials have changed.
There is great resistance to changing any assembly and workmanship
standard - nobody wants to be the person who says "we don't need to do
that anymore" and then a disaster happens, and one of the potential
causes is "you didn't do that"
It is entirely possible that the original rationale and explanation is
no longer valid.
There is no question that in a vibration environment, solder is
deprecated (it's hard, brittle, work hardens, etc), not to mention all
the issues with RoHS.  That said they do use solder joints in high
reliability systems - just with attention to the support of the wire.
https://www.tandfonline.com/doi/full/10.1080/14686996.2019.1640072
https://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/20100029736.pdf
On 10/4/19 1:41 PM, Poul-Henning Kamp wrote: > -------- > In message <5D979AC0.80304@rogers.com>, MLewis writes: > >> With audio signals, a soldered crimp is one of the worst possible >> connections. > > Dabbling in audio-homoepathy are we ? > > No, don't bother responding unless you have a reference to peer-reviewed > scientific documentation for you claim. > well.. https://nepp.nasa.gov/files/27631/NSTD87394A.pdf doesn't give why, and doesn't explicitly say "don't crimp and solder" but does basically say "crimp crimp connectors and solder solder connectors" TE "Crimp Theory Fundamentals; Advanced" - explanation of what makes a good crimp, doesn't discuss solder https://www.youtube.com/watch?v=bAO9eCS65jw There are actually splices designed to be crimped and soldered - but I suspect their applicability is for specific applications. On Monday, I will try to find one of the connector reliability people for some references. One challenge is that these practices ("don't solder crimped connectors") have been around for a long time (at least 70 years), so there may not be recent published information on it. (recent papers I found on solder joint reliability are all about PWB connections - esp BGA, CGA, etc.) And, to be honest, materials have changed. There is *great* resistance to changing any assembly and workmanship standard - nobody wants to be the person who says "we don't need to do *that* anymore" and then a disaster happens, and one of the potential causes is "you didn't do *that*" It is entirely possible that the original rationale and explanation is no longer valid. There is no question that in a vibration environment, solder is deprecated (it's hard, brittle, work hardens, etc), not to mention all the issues with RoHS. That said they do use solder joints in high reliability systems - just with attention to the support of the wire. https://www.tandfonline.com/doi/full/10.1080/14686996.2019.1640072 https://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/20100029736.pdf
PK
Poul-Henning Kamp
Sat, Oct 5, 2019 5:29 PM
connections.
well..
But it doesn't say anything about "with audio signals" at all,
which is the part that triggers my bullshit filter...
-------- In message <9e07d884-3d64-1b3a-f753-233cac34710d@earthlink.net>, jimlux writes: >On 10/4/19 1:41 PM, Poul-Henning Kamp wrote: >> -------- >> In message <5D979AC0.80304@rogers.com>, MLewis writes: >> >>> With audio signals, a soldered crimp is one of the worst possible >>> connections. >> >> Dabbling in audio-homoepathy are we ? >> >> No, don't bother responding unless you have a reference to peer-reviewed >> scientific documentation for you claim. > >well.. >https://nepp.nasa.gov/files/27631/NSTD87394A.pdf > >doesn't give why, and doesn't explicitly say "don't crimp and solder" >but does basically say "crimp crimp connectors and solder solder connectors" But it doesn't say anything about "with audio signals" at all, which is the part that triggers my bullshit filter... -- Poul-Henning Kamp | UNIX since Zilog Zeus 3.20 phk@FreeBSD.ORG | TCP/IP since RFC 956 FreeBSD committer | BSD since 4.3-tahoe Never attribute to malice what can adequately be explained by incompetence.
JA
John Ackermann N8UR
Sat, Oct 5, 2019 5:45 PM
One thing the PowerPole tool does is provide a little cavity for the
blade to go, so it keeps the depth of the crimp and also the angle where
they should be.
(Mr.) Taka Kamiya
KB4EMF / ex JF2DKG
high
and
the
Didier KO4BB
for
24V
(Mr.) Taka Kamiya
KB4EMF / ex JF2DKG
(5v),
anyone use
am
Any insights?
Bill
Bill Dailey
game.
  • Gary Vaynerchuk
  • Steve Sims
One thing the PowerPole tool does is provide a little cavity for the blade to go, so it keeps the depth of the crimp and also the angle where they should be. On 10/5/19 7:24 AM, Adrian Godwin wrote: > I used powerpoles on a project and tried to use a crimping tool I had to > hand. Amphenol, I think. It appeared to be the right size but ended up > bending the terminal badly where it changes from circular to flat. The > results were unreliable and I ended up soldering (though adding sleeving, > which together with the natural bend-restriction on the shell has mostly > avoided stiffening the wire where it's most vulnerable). > > I know some crimp terminal are very fussy about the tool used but it's > usually the miniature ones like JST. Does the powerpole terminal need a > powerpole-specific crimp tool ? I note that the West Mountain tool seems to > be branded by themselves rather than Anderson, but I can't tell if it's > generic or made to their specs. > > On Sat, Oct 5, 2019 at 2:00 AM John Ackermann N8UR <jra@febo.com> wrote: > >> Not a perfect solution, but for semi-permanent connections you can run a >> small tie-wrap lengthwise so the ends pass through the space between where >> the wires on each end split and the body. Cinch it tight and the >> connectors won't come apart without cutting the tie wrap. >> >> On Oct 4, 2019, 7:04 PM, at 7:04 PM, Taka Kamiya via time-nuts < >> time-nuts@lists.febo.com> wrote: >>> I used to use power pole, too but they don't lock firmly enough for my >>> liking. So I don't use them anymore. It would be perfect if there is >>> an option to add positive locking mechanism of some kind. >>> >>> --------------------------------------- >>> (Mr.) Taka Kamiya >>> KB4EMF / ex JF2DKG >>> >>> >>> On Friday, October 4, 2019, 4:06:50 PM EDT, Didier Juges >>> <shalimr9@gmail.com> wrote: >>> >>> That's what I do too. I do use Power Pole for my ham stuff that draws >>> high >>> current but for all the <2A 12V stuff the 5.1mm barrel connector with >>> positive center is hard to beat because I have so many power sources >>> and >>> equipment already wired for it. I am not ready to rewire all the off >>> the >>> shelf equipment that came with one of those. >>> >>> Power Pole are convenient for batteries though because you can use the >>> connector to charge the battery or use it as a source. >>> >>> Didier KO4BB >>> >>> On Fri, Oct 4, 2019, 2:01 PM Taka Kamiya via time-nuts < >>> time-nuts@lists.febo.com> wrote: >>> >>>> Mine is very simple.... >>>> USB connector for 5VBarrel connector 5.5/2.1mm for 12VTerminal strip >>> for >>>> 24V >>>> None of them are high power devices. >>>> >>>> --------------------------------------- >>>> (Mr.) Taka Kamiya >>>> KB4EMF / ex JF2DKG >>>> >>>> >>>> On Friday, October 4, 2019, 2:03:55 AM EDT, Bill Dailey < >>>> docdailey@gmail.com> wrote: >>>> >>>> Setting up a new workbench and am wondering what wisdom people can >>>> offer. I am powering numerous synthesizers (5v), small receivers >>> (5v), >>>> Upconverters (5v), larger receivers (12v), fury Gpsdo’s.. etc. >>> anyone use >>>> something neat and not real expensive for distributing 5v and 12v. I >>> am >>>> hoping for a long COTS pcb with fusing and maybe holes for plugs. >>>> >>>> Any insights? >>>> >>>> Bill >>>> >>>> Bill Dailey >>>> >>>> Negativity always wins the short game. But positivity wins the long >>> game. >>>> - Gary Vaynerchuk >>>> >>>> Don’t be easy to understand, >>>> Be impossible to misunderstand >>>> - Steve Sims >>>> _______________________________________________ >>>> time-nuts mailing list -- time-nuts@lists.febo.com >>>> To unsubscribe, go to >>>> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >>>> and follow the instructions there. >>>> >>>> _______________________________________________ >>>> time-nuts mailing list -- time-nuts@lists.febo.com >>>> To unsubscribe, go to >>>> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >>>> and follow the instructions there. >>>> >>> _______________________________________________ >>> time-nuts mailing list -- time-nuts@lists.febo.com >>> To unsubscribe, go to >>> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >>> and follow the instructions there. >>> >>> _______________________________________________ >>> time-nuts mailing list -- time-nuts@lists.febo.com >>> To unsubscribe, go to >>> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >>> and follow the instructions there. >> _______________________________________________ >> time-nuts mailing list -- time-nuts@lists.febo.com >> To unsubscribe, go to >> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >> and follow the instructions there. >> > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there. >
W-
Sat, Oct 5, 2019 6:03 PM
The Tri-Crimp (purchased from WMR of Powerwerx) has worked for me for hundreds of crimps (of the 15-30-45 amp power poles)
The WMR crimper for AWG 6 and 8 works well for the 75 A connectors
Crimping the larger (e.g. 175 Amp) Power Poles is “interesting”, in that readily available (sub US$ 150) crimpers seem to be metric.  Sometimes it takes a couple of crimps with different dies (sizes) to get it right
Good luck
S
Sent from my iPhone
(Mr.) Taka Kamiya
KB4EMF / ex JF2DKG
high
and
the
Didier KO4BB
for
24V
(Mr.) Taka Kamiya
KB4EMF / ex JF2DKG
(5v),
anyone use
am
Any insights?
Bill
Bill Dailey
game.
  • Gary Vaynerchuk
  • Steve Sims
The Tri-Crimp (purchased from WMR of Powerwerx) has worked for me for hundreds of crimps (of the 15-30-45 amp power poles) The WMR crimper for AWG 6 and 8 works well for the 75 A connectors Crimping the larger (e.g. 175 Amp) Power Poles is “interesting”, in that readily available (sub US$ 150) crimpers seem to be metric. Sometimes it takes a couple of crimps with different dies (sizes) to get it right Good luck S Sent from my iPhone > On Oct 5, 2019, at 10:16 AM, Adrian Godwin <artgodwin@gmail.com> wrote: > > I used powerpoles on a project and tried to use a crimping tool I had to > hand. Amphenol, I think. It appeared to be the right size but ended up > bending the terminal badly where it changes from circular to flat. The > results were unreliable and I ended up soldering (though adding sleeving, > which together with the natural bend-restriction on the shell has mostly > avoided stiffening the wire where it's most vulnerable). > > I know some crimp terminal are very fussy about the tool used but it's > usually the miniature ones like JST. Does the powerpole terminal need a > powerpole-specific crimp tool ? I note that the West Mountain tool seems to > be branded by themselves rather than Anderson, but I can't tell if it's > generic or made to their specs. > >> On Sat, Oct 5, 2019 at 2:00 AM John Ackermann N8UR <jra@febo.com> wrote: >> >> Not a perfect solution, but for semi-permanent connections you can run a >> small tie-wrap lengthwise so the ends pass through the space between where >> the wires on each end split and the body. Cinch it tight and the >> connectors won't come apart without cutting the tie wrap. >> >>> On Oct 4, 2019, 7:04 PM, at 7:04 PM, Taka Kamiya via time-nuts < >>> time-nuts@lists.febo.com> wrote: >>> I used to use power pole, too but they don't lock firmly enough for my >>> liking. So I don't use them anymore. It would be perfect if there is >>> an option to add positive locking mechanism of some kind. >>> >>> --------------------------------------- >>> (Mr.) Taka Kamiya >>> KB4EMF / ex JF2DKG >>> >>> >>> On Friday, October 4, 2019, 4:06:50 PM EDT, Didier Juges >>> <shalimr9@gmail.com> wrote: >>> >>> That's what I do too. I do use Power Pole for my ham stuff that draws >>> high >>> current but for all the <2A 12V stuff the 5.1mm barrel connector with >>> positive center is hard to beat because I have so many power sources >>> and >>> equipment already wired for it. I am not ready to rewire all the off >>> the >>> shelf equipment that came with one of those. >>> >>> Power Pole are convenient for batteries though because you can use the >>> connector to charge the battery or use it as a source. >>> >>> Didier KO4BB >>> >>> On Fri, Oct 4, 2019, 2:01 PM Taka Kamiya via time-nuts < >>> time-nuts@lists.febo.com> wrote: >>> >>>> Mine is very simple.... >>>> USB connector for 5VBarrel connector 5.5/2.1mm for 12VTerminal strip >>> for >>>> 24V >>>> None of them are high power devices. >>>> >>>> --------------------------------------- >>>> (Mr.) Taka Kamiya >>>> KB4EMF / ex JF2DKG >>>> >>>> >>>> On Friday, October 4, 2019, 2:03:55 AM EDT, Bill Dailey < >>>> docdailey@gmail.com> wrote: >>>> >>>> Setting up a new workbench and am wondering what wisdom people can >>>> offer. I am powering numerous synthesizers (5v), small receivers >>> (5v), >>>> Upconverters (5v), larger receivers (12v), fury Gpsdo’s.. etc. >>> anyone use >>>> something neat and not real expensive for distributing 5v and 12v. I >>> am >>>> hoping for a long COTS pcb with fusing and maybe holes for plugs. >>>> >>>> Any insights? >>>> >>>> Bill >>>> >>>> Bill Dailey >>>> >>>> Negativity always wins the short game. But positivity wins the long >>> game. >>>> - Gary Vaynerchuk >>>> >>>> Don’t be easy to understand, >>>> Be impossible to misunderstand >>>> - Steve Sims >>>> _______________________________________________ >>>> time-nuts mailing list -- time-nuts@lists.febo.com >>>> To unsubscribe, go to >>>> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >>>> and follow the instructions there. >>>> >>>> _______________________________________________ >>>> time-nuts mailing list -- time-nuts@lists.febo.com >>>> To unsubscribe, go to >>>> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >>>> and follow the instructions there. >>>> >>> _______________________________________________ >>> time-nuts mailing list -- time-nuts@lists.febo.com >>> To unsubscribe, go to >>> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >>> and follow the instructions there. >>> >>> _______________________________________________ >>> time-nuts mailing list -- time-nuts@lists.febo.com >>> To unsubscribe, go to >>> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >>> and follow the instructions there. >> _______________________________________________ >> time-nuts mailing list -- time-nuts@lists.febo.com >> To unsubscribe, go to >> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >> and follow the instructions there. >> > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there.
W
Wes
Sat, Oct 5, 2019 6:10 PM
On 10/4/2019 12:17 PM, MLewis wrote:
With audio signals, a soldered crimp is one of the worst possible connections.
 Please explain.
On 10/4/2019 12:17 PM, MLewis wrote: > With audio signals, a soldered crimp is one of the worst possible connections.  Please explain.
MS
Mark Spencer
Sat, Oct 5, 2019 6:23 PM
I seem to recall being involved in a project where a PEng called for certain connectors to be soldered and crimped.  I expect there were specific reasons why that was specified for that particular project.  My memory is a bit hazy about the specific details of the connectors.
Re power poles..  I'm not a huge fan of them for my hobby used but I seem to recall commenting re this a few years ago and won't take up any more bandwidth re this.  I do own some equipment that uses them, and  a number of friends of mine seem quite happy with them for amateur radio use.
All the best
Mark S
mark@alignedsolutions.com
604 762 4099
In message 5D979AC0.80304@rogers.com, MLewis writes:
connections.
well..
There is great resistance to changing any assembly and workmanship standard - nobody wants to be the person who says "we don't need to do that anymore" and then a disaster happens, and one of the potential causes is "you didn't do that"
I seem to recall being involved in a project where a PEng called for certain connectors to be soldered and crimped. I expect there were specific reasons why that was specified for that particular project. My memory is a bit hazy about the specific details of the connectors. Re power poles.. I'm not a huge fan of them for my hobby used but I seem to recall commenting re this a few years ago and won't take up any more bandwidth re this. I do own some equipment that uses them, and a number of friends of mine seem quite happy with them for amateur radio use. All the best Mark S mark@alignedsolutions.com 604 762 4099 >> On Oct 5, 2019, at 5:49 AM, jimlux <jimlux@earthlink.net> wrote: >> >> On 10/4/19 1:41 PM, Poul-Henning Kamp wrote: >> -------- >> In message <5D979AC0.80304@rogers.com>, MLewis writes: >>> With audio signals, a soldered crimp is one of the worst possible >>> connections. >> Dabbling in audio-homoepathy are we ? >> No, don't bother responding unless you have a reference to peer-reviewed >> scientific documentation for you claim. > > > well.. > https://nepp.nasa.gov/files/27631/NSTD87394A.pdf > > doesn't give why, and doesn't explicitly say "don't crimp and solder" but does basically say "crimp crimp connectors and solder solder connectors" > > TE "Crimp Theory Fundamentals; Advanced" - explanation of what makes a good crimp, doesn't discuss solder > https://www.youtube.com/watch?v=bAO9eCS65jw > > There are actually splices designed to be crimped and soldered - but I suspect their applicability is for specific applications. > > > On Monday, I will try to find one of the connector reliability people for some references. One challenge is that these practices ("don't solder crimped connectors") have been around for a long time (at least 70 years), so there may not be recent published information on it. (recent papers I found on solder joint reliability are all about PWB connections - esp BGA, CGA, etc.) > > And, to be honest, materials have changed. > > There is *great* resistance to changing any assembly and workmanship standard - nobody wants to be the person who says "we don't need to do *that* anymore" and then a disaster happens, and one of the potential causes is "you didn't do *that*" > > It is entirely possible that the original rationale and explanation is no longer valid. > > There is no question that in a vibration environment, solder is deprecated (it's hard, brittle, work hardens, etc), not to mention all the issues with RoHS. That said they do use solder joints in high reliability systems - just with attention to the support of the wire. > > https://www.tandfonline.com/doi/full/10.1080/14686996.2019.1640072 > https://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/20100029736.pdf > > > > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there. >
WH
William H. Fite
Sat, Oct 5, 2019 6:54 PM
A solid crimp is, I believe, generally held to be more than a solder joint
but this is in no way specific to audio cables.
connections.
well..
CGA, etc.)
longer valid.
Homo sum humani a me nihil alienum puto.
A solid crimp is, I believe, generally held to be more than a solder joint but this is in no way specific to audio cables. On Saturday, October 5, 2019, jimlux <jimlux@earthlink.net> wrote: > On 10/4/19 1:41 PM, Poul-Henning Kamp wrote: > >> -------- >> In message <5D979AC0.80304@rogers.com>, MLewis writes: >> >> With audio signals, a soldered crimp is one of the worst possible >>> connections. >>> >> >> Dabbling in audio-homoepathy are we ? >> >> No, don't bother responding unless you have a reference to peer-reviewed >> scientific documentation for you claim. >> >> > > well.. > https://nepp.nasa.gov/files/27631/NSTD87394A.pdf > > doesn't give why, and doesn't explicitly say "don't crimp and solder" but > does basically say "crimp crimp connectors and solder solder connectors" > > TE "Crimp Theory Fundamentals; Advanced" - explanation of what makes a > good crimp, doesn't discuss solder > https://www.youtube.com/watch?v=bAO9eCS65jw > > There are actually splices designed to be crimped and soldered - but I > suspect their applicability is for specific applications. > > > On Monday, I will try to find one of the connector reliability people for > some references. One challenge is that these practices ("don't solder > crimped connectors") have been around for a long time (at least 70 years), > so there may not be recent published information on it. (recent papers I > found on solder joint reliability are all about PWB connections - esp BGA, > CGA, etc.) > > And, to be honest, materials have changed. > > There is *great* resistance to changing any assembly and workmanship > standard - nobody wants to be the person who says "we don't need to do > *that* anymore" and then a disaster happens, and one of the potential > causes is "you didn't do *that*" > > It is entirely possible that the original rationale and explanation is no > longer valid. > > There is no question that in a vibration environment, solder is deprecated > (it's hard, brittle, work hardens, etc), not to mention all the issues with > RoHS. That said they do use solder joints in high reliability systems - > just with attention to the support of the wire. > > https://www.tandfonline.com/doi/full/10.1080/14686996.2019.1640072 > https://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/20100029736.pdf > > > > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to http://lists.febo.com/mailman/ > listinfo/time-nuts_lists.febo.com > and follow the instructions there. > -- Homo sum humani a me nihil alienum puto.
TV
Tom Van Baak
Sat, Oct 5, 2019 8:20 PM
Yes, this PowerPole thread has gone on and on. I realize that not all of
you are interested, but IMHO it is very on-topic for time-nuts. Many of
us have non-trivial home or mobile labs and practical issues of DC power
are relevant and welcome. I've been using PowerPole connectors for
everything and even I learned a lot from the thread. So thanks for the
contributions.
We've had a couple of threads last week that stressed the list, created
exceptions, caused a backlog of postings and a decline in S/N. When
posting please try to keep the content highly technical and informative.
There were times last week where it looked more like twitter than a
technical forum.
Questions or suggestions about list administrative issues should go to
time-nuts-owner@lists.febo.com
Thanks,
/tvb
Moderator, http://leapsecond.com/time-nuts.htm
Yes, this PowerPole thread has gone on and on. I realize that not all of you are interested, but IMHO it is very on-topic for time-nuts. Many of us have non-trivial home or mobile labs and practical issues of DC power are relevant and welcome. I've been using PowerPole connectors for everything and even I learned a lot from the thread. So thanks for the contributions. We've had a couple of threads last week that stressed the list, created exceptions, caused a backlog of postings and a decline in S/N. When posting please try to keep the content highly technical and informative. There were times last week where it looked more like twitter than a technical forum. Questions or suggestions about list administrative issues should go to time-nuts-owner@lists.febo.com Thanks, /tvb Moderator, http://leapsecond.com/time-nuts.htm
BK
Bob kb8tq
Sat, Oct 5, 2019 8:33 PM
Hi
The biggest “issue” I’ve seen with Power Poles is that after being mated for 20 to 30
years they start to loose the spring force that holds them together.
Bob
they should be.
(Mr.) Taka Kamiya
KB4EMF / ex JF2DKG
high
and
the
Didier KO4BB
for
24V
(Mr.) Taka Kamiya
KB4EMF / ex JF2DKG
(5v),
anyone use
am
Any insights?
Bill
Bill Dailey
game.
  • Gary Vaynerchuk
  • Steve Sims
Hi The biggest “issue” I’ve seen with Power Poles is that after being mated for 20 to 30 years they start to loose the spring force that holds them together. Bob > On Oct 5, 2019, at 11:45 AM, John Ackermann N8UR <jra@febo.com> wrote: > > One thing the PowerPole tool does is provide a little cavity for the > blade to go, so it keeps the depth of the crimp and also the angle where > they should be. > > On 10/5/19 7:24 AM, Adrian Godwin wrote: >> I used powerpoles on a project and tried to use a crimping tool I had to >> hand. Amphenol, I think. It appeared to be the right size but ended up >> bending the terminal badly where it changes from circular to flat. The >> results were unreliable and I ended up soldering (though adding sleeving, >> which together with the natural bend-restriction on the shell has mostly >> avoided stiffening the wire where it's most vulnerable). >> >> I know some crimp terminal are very fussy about the tool used but it's >> usually the miniature ones like JST. Does the powerpole terminal need a >> powerpole-specific crimp tool ? I note that the West Mountain tool seems to >> be branded by themselves rather than Anderson, but I can't tell if it's >> generic or made to their specs. >> >> On Sat, Oct 5, 2019 at 2:00 AM John Ackermann N8UR <jra@febo.com> wrote: >> >>> Not a perfect solution, but for semi-permanent connections you can run a >>> small tie-wrap lengthwise so the ends pass through the space between where >>> the wires on each end split and the body. Cinch it tight and the >>> connectors won't come apart without cutting the tie wrap. >>> >>> On Oct 4, 2019, 7:04 PM, at 7:04 PM, Taka Kamiya via time-nuts < >>> time-nuts@lists.febo.com> wrote: >>>> I used to use power pole, too but they don't lock firmly enough for my >>>> liking. So I don't use them anymore. It would be perfect if there is >>>> an option to add positive locking mechanism of some kind. >>>> >>>> --------------------------------------- >>>> (Mr.) Taka Kamiya >>>> KB4EMF / ex JF2DKG >>>> >>>> >>>> On Friday, October 4, 2019, 4:06:50 PM EDT, Didier Juges >>>> <shalimr9@gmail.com> wrote: >>>> >>>> That's what I do too. I do use Power Pole for my ham stuff that draws >>>> high >>>> current but for all the <2A 12V stuff the 5.1mm barrel connector with >>>> positive center is hard to beat because I have so many power sources >>>> and >>>> equipment already wired for it. I am not ready to rewire all the off >>>> the >>>> shelf equipment that came with one of those. >>>> >>>> Power Pole are convenient for batteries though because you can use the >>>> connector to charge the battery or use it as a source. >>>> >>>> Didier KO4BB >>>> >>>> On Fri, Oct 4, 2019, 2:01 PM Taka Kamiya via time-nuts < >>>> time-nuts@lists.febo.com> wrote: >>>> >>>>> Mine is very simple.... >>>>> USB connector for 5VBarrel connector 5.5/2.1mm for 12VTerminal strip >>>> for >>>>> 24V >>>>> None of them are high power devices. >>>>> >>>>> --------------------------------------- >>>>> (Mr.) Taka Kamiya >>>>> KB4EMF / ex JF2DKG >>>>> >>>>> >>>>> On Friday, October 4, 2019, 2:03:55 AM EDT, Bill Dailey < >>>>> docdailey@gmail.com> wrote: >>>>> >>>>> Setting up a new workbench and am wondering what wisdom people can >>>>> offer. I am powering numerous synthesizers (5v), small receivers >>>> (5v), >>>>> Upconverters (5v), larger receivers (12v), fury Gpsdo’s.. etc. >>>> anyone use >>>>> something neat and not real expensive for distributing 5v and 12v. I >>>> am >>>>> hoping for a long COTS pcb with fusing and maybe holes for plugs. >>>>> >>>>> Any insights? >>>>> >>>>> Bill >>>>> >>>>> Bill Dailey >>>>> >>>>> Negativity always wins the short game. But positivity wins the long >>>> game. >>>>> - Gary Vaynerchuk >>>>> >>>>> Don’t be easy to understand, >>>>> Be impossible to misunderstand >>>>> - Steve Sims >>>>> _______________________________________________ >>>>> time-nuts mailing list -- time-nuts@lists.febo.com >>>>> To unsubscribe, go to >>>>> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >>>>> and follow the instructions there. >>>>> >>>>> _______________________________________________ >>>>> time-nuts mailing list -- time-nuts@lists.febo.com >>>>> To unsubscribe, go to >>>>> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >>>>> and follow the instructions there. >>>>> >>>> _______________________________________________ >>>> time-nuts mailing list -- time-nuts@lists.febo.com >>>> To unsubscribe, go to >>>> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >>>> and follow the instructions there. >>>> >>>> _______________________________________________ >>>> time-nuts mailing list -- time-nuts@lists.febo.com >>>> To unsubscribe, go to >>>> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >>>> and follow the instructions there. >>> _______________________________________________ >>> time-nuts mailing list -- time-nuts@lists.febo.com >>> To unsubscribe, go to >>> http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >>> and follow the instructions there. >>> >> _______________________________________________ >> time-nuts mailing list -- time-nuts@lists.febo.com >> To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >> and follow the instructions there. >> > > > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there.
