Was doing a search for Lucent RFTGm-II-XO looking for alternates to the
$150 solution.
A 10 Mhz mod popped up.
http://telcodata.us/~myself/Lucent-RFTGm-Modification.pdf
Looks simple enough and I have not validated anything.
Regards
Paul
WB8TSL
Hi
Another alternative would be to AC couple into a NC7SZ125 (using a 0.1 uf cap and a pair of 100K resistors )and take the output off with a Tee filter (using two 1.5 uH coils and a 270 pf cap).
Bob
$150 solution.
Regards
Paul
WB8TSL
$150 solution.
Regards
Paul
WB8TSL
Paul, that has nothing to do with the current ebay offerings that have
generated so much traffic recently...
Dan
Hi
This is a branch thread that never got it’s title changed to drop the KS-24361 part of it. More or less it’s “compare the older KS boxes to the newer ones”.
Bob
$150 solution.
Regards
Paul
WB8TSL
Paul, that has nothing to do with the current ebay offerings that have generated so much traffic recently...
Dan
I just saw the picture of the units front panel and it looked the same.
Oh well.
Regards
Paul
WB8TSL
On Wed, Nov 19, 2014 at 7:08 PM, Bob Camp kb8tq@n1k.org wrote:
Hi
newer ones”.
Bob
$150 solution.
Regards
Paul
WB8TSL
Hi
Lucent has been putting GPS based Radio Frequency Timing Generators (RFTG) into cell sites for a long time. They all have the 15 MHz and pps outputs in common. Lucent also seems to like one paint color and an approximate size. For what ever reason (because they can?) the model numbers and internal designs change from time to time. For quite a while they really liked the idea of running Rb’s in cell sites. Looking at the latest batch of parts, that seems to have changed around 1999.
Lots of generations of very similar looking boxes with very different stuff inside each of them.
Bob
Oh well.
Regards
Paul
WB8TSL
Hi
newer ones”.
Bob
$150 solution.
Regards
Paul
WB8TSL
And I am the happy owner of 4 or 5 of the $25 RBs. Hey they are old but you
can recover them with the old heatgun trick. That said glowing things like
those do tend to wear out. I could see why they moved away from them.
On Wed, Nov 19, 2014 at 8:15 PM, Bob Camp kb8tq@n1k.org wrote:
Hi
Bob
Oh well.
Regards
Paul
WB8TSL
Hi
the
newer ones”.
Bob
the
$150 solution.
Regards
Paul
WB8TSL
Hi
So far, I have not found any of the Rb’s that came out of the KS boxes with troubles. The ones I got and pulled from boxes myself all have worked fine. The units that got pulled on the other side of an ocean, not so much. There have been a couple of them with issues. What ever they go through getting shipped overseas and salvaged, it’s not doing the parts any good. That’s one of the reasons getting the newer design KS boxes NIB has a lot of appeal. There are infant mortality reliability issues to deal with on new stuff. I’d rather have those issues than end of life and corrosion.
Bob
Hi
Bob
Oh well.
Regards
Paul
WB8TSL
Hi
the
newer ones”.
Bob
the
$150 solution.
Regards
Paul
WB8TSL
On the old telco RBs $25 they all worked, but were down on lamp life. So
the first one chosen ran for 3 years and then started blinking out.
Replaced it with another. That first one is the one I used the heat gun on
and is again operable with what appears could be good lamp life.
(Reasonable)
Regards
Paul
WB8TSL
On Thu, Nov 20, 2014 at 7:00 AM, Bob Camp kb8tq@n1k.org wrote:
Hi
Bob
you
like
Hi
(RFTG)
outputs
batch
Bob
Oh well.
Regards
Paul
WB8TSL
Hi
the
newer ones”.
Bob
the
$150 solution.
Regards
Paul
WB8TSL
have
Hi
So far, I have yet to have one of the Rb’s die (of the ones that worked when new to me). The magic “lamp voltage” on the Efratom versions clusters in two groups. That seems to be related to some sort of production change rather than better performance on the (slightly) newer parts.
Bob
(Reasonable)
Regards
Paul
WB8TSL
Hi
Bob
you
like
Hi
(RFTG)
outputs
batch
Bob
Oh well.
Regards
Paul
WB8TSL
Hi
the
newer ones”.
Bob
the
$150 solution.
Regards
Paul
WB8TSL
have
