DM
Demian Martin
Mon, Nov 26, 2012 6:11 PM
I asked Wenzel about mixers for phase noise measurement and they directed me
to Marki Microwave as what they use:
http://www.markimicrowave.com/2770/Mixers.aspx I have not obtained or
tested any myself but it's a pretty solid recommendation I think.
I got this guy to add cross correlation to his FFT software suite:
http://www.hpw-works.com/ however I have not built hardware to try it. He
has a 30 day trial and its not expensive for what it is, $300. I would use
it with an ESI Juli@ card http://www.esi-audio.com/products/julia/ ($150 or
less on eBay or elsewhere) since you can be pretty sure it won't do
something to mess with the measurement and it runs at 192 KHz sample rate
quite well. Around $450 for a cross correlation analyzer. Or you can go
shopping for an old FFT with the capability and potential service nightmare.
Thanks a lot guys for all the input!
The nist articles was a very interesting read. I have ordered the
minicircuits ZRPD-1 and will try to build the 2N2222A mixer to to see how
far that will take it. I probably also will build a low noise jfet preamp
to see if that will reduce the noise. But I probably have to go to build
myself a crosscorrelation system to be able to <-180dBc with confidence.
there any cheap way into cross correlation measurement, using high quality
soundcard for example? Or do I have to buy one of these big old expensive
dual FFT analyzers?
/Anders
Is
> dual FFT analyzers?
> /Anders
JL
Jim Lux
Tue, Nov 27, 2012 3:22 AM
Isn't Marki making the old WJ mixers? That seems to be what someone
told me a few years ago: they basically have all the tooling and
designs, etc.
designs, etc.
RK
Rick Karlquist
Tue, Nov 27, 2012 5:12 AM
directed me
designs, etc.
That's interesting, because MaCom Technology Solutions seems to
be making WJ models as well. A few years back, there was another
company (I think the name started with an S) that seemed to have
inherited the WJ line. The company currently called WJ has
nothing to do with these mixers at all.
Rick
>> directed me
> designs, etc.
Rick
B
bg@lysator.liu.se
Tue, Nov 27, 2012 6:44 AM
directed me
designs, etc.
Rick
Did you see this information from Mini Circuits on WJ mixer replacements?
http://217.34.103.131/pdfs/Surface-Mount%20Mixers%20Are%20WJ%20Replacements.pdf
Björn
>>> directed me
>> designs, etc.
> Rick
Björn
BG
Bruce Griffiths
Tue, Nov 27, 2012 9:53 AM
There's no evidence of a cross power spectrum function in this suite.
One needs to be able to average at least 10,000 cross power spectra for
some applications.
some applications.
A
Adrian
Tue, Nov 27, 2012 10:15 AM
directed me
it. He
for some applications.
Here is one that does cross spectrum and more: http://www.sigview.com/
A while ago I tried it with a Xonar Essence XT sound card and the
results looked quite promising.
Then I got a 3562A to get to 100 kHz (don't follow me there! These can
be challenging to fix if not impossible. PAL's and other unobtainable
'field programmables' appear to die faster than anything else in that
boxes. Finally, I needed three of them to get one working unit...)
Adrian
>> directed me
>> it. He
> Bruce
Adrian
> _______________________________________________
> time-nuts mailing list -- time-nuts@febo.com
> To unsubscribe, go to
> https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts
> and follow the instructions there.
BG
Bruce Griffiths
Tue, Nov 27, 2012 10:33 AM
directed me
it. He
Adrian
Tried that as well, how does one get a log y scale on the cross spectrum
plot?
>>> directed me
>>> it. He
>> Bruce
> Adrian
plot?
A
Adrian
Tue, Nov 27, 2012 10:52 AM
directed me
it. He
can be challenging to fix if not impossible. PAL's and other
unobtainable 'field programmables' appear to die faster than anything
else in that boxes. Finally, I needed three of them to get one
working unit...)
Adrian
spectrum plot?
With Sigview? I'm sorry my trial version has long expired and even after
installing the latest version it's now requiring a license key...
Adrian
>>>> directed me
>>>> it. He
>>> Bruce
>> working unit...)
>> Adrian
> spectrum plot?
> Bruce
Adrian
SH
Support HpW-Works.com
Tue, Nov 27, 2012 11:06 AM
One needs to be able to average at least 10,000 cross power spectra for some
applications.
In the PSD (power density) & PSP (power spectrum) there are cross power and cross
power complex average implemented (selectable using the spectrum channel mixer)!
Additional to this you may apply / add averaging of the resulting spectrum or use
additional peak hold.
Average of 10'000 cross points is a large count and often seen on 1-4k sample size.
Better in my opinion is to use a higher sample size 32k-64k and then less averaging
is required.
Just download the evaluation version with fully feature set.
HpW
Bruce,
>> applications.
is required.
HpW
BG
Bruce Griffiths
Tue, Nov 27, 2012 11:08 AM
directed me
obtained or
try it. He
anything else in that boxes. Finally, I needed three of them to get
Adrian
spectrum plot?
after installing the latest version it's now requiring a license key...
Adrian
The help file states that the cross power spectrum is the product of the
individual spectra - this is only correct if the individual spectra are
real.
>>>>> directed me
>>>>> obtained or
>>>>> try it. He
>>>> Bruce
>>> Adrian
>> spectrum plot?
>> Bruce
> Adrian
real.
