Support HpW-Works.com wrote:
Bruce,
There's no evidence of a cross power spectrum function in this suite.
One needs to be able to average at least 10,000 cross power spectra for some
applications.
In the PSD (power density)& PSP (power spectrum) there are cross power and cross
power complex average implemented (selectable using the spectrum channel mixer)!
Additional to this you may apply / add averaging of the resulting spectrum or use
additional peak hold.
Average of 10'000 cross points is a large count and often seen on 1-4k sample size.
Better in my opinion is to use a higher sample size 32k-64k and then less averaging
is required.
The equivalent phase noise (measured in dBc/Hz) is essentially
independent of the sample size.
So increasing the sample size isnt particularly useful for reducing the
phase noise floor.
The increased frequency resolution achieved by increasing the sample
size is only useful for measuring spurs.
In the direct digital method of measuring phase noise a few terasamples
(a few gigasamples at baseband) need to be processed to achieve a
sufficiently low instrument noise floor.
However with a sound card plus a mixer a somewhat lower number of
samples should suffice since there is no carrier.
Just download the evaluation version with fully feature set.
HpW
Bruce,
for some
applications.
power and cross
channel mixer)!
spectrum or use
1-4k sample size.
less averaging
is required.
the phase noise floor.
terasamples (a few gigasamples at baseband) need to be processed to
achieve a sufficiently low instrument noise floor.
HpW
A HP/Agilent VEE based solution would be much more flexible. There is a
sound card driver available.
I just didn't get deep enough into digital signal processing before the
3562A came...
Adrian
time-nuts mailing list -- time-nuts@febo.com
To unsubscribe, go to
Hi Bruce,
The equivalent phase noise (measured in dBc/Hz) is essentially independent of
the sample size.
The dBc/Hz normalization is based on this (also the sample rate). While the sample
rate & sample size = FFT Bin size (resolution or filter band width) is used to get
the required correction factor of the spectrum to get the dBc / (1Hz) Y scaling
back.
So increasing the sample size isnt particularly useful for reducing the phase
noise floor.
By theory, yes... but we use a sound card with a lot of flicker noise on the lower
end, also we have the 10...20Hz low freq. cutoff due the usage of a servo / single
5V power. Also the raising noise below 100Hz (ADC serve & noise on the ADC power /
input circuit) limits the performance.
In my simple test increase of the sample size reduced the noise floor in better way
than just using sample size with 1-2K and large averaging cycles.
Keep in mind, Bin resolution is sample rate / sample size:
Example:
However with a sound card plus a mixer a somewhat lower number of samples
Ideally the input circuit & ADC of the 3562A would be nice but with much larger RAM
buffer and ASIO interface O:)
Hanspeter
From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] On Behalf
Of Bruce Griffiths
Sent: Dienstag, 27. November 2012 12:31
To: Discussion of precise time and frequency measurement
Subject: Re: [time-nuts] Best phase detector / mixer for 100MHz?
Bruce,
for some applications.
power and cross power complex average implemented (selectable using the
spectrum or use additional peak hold.
sample size.
less averaging is required.
the sample size.
noise floor.
The increased frequency resolution achieved by increasing the sample size is
In the direct digital method of measuring phase noise a few terasamples (a few
gigasamples at baseband) need to be processed to achieve a sufficiently low
HpW
time-nuts mailing list -- time-nuts@febo.com To unsubscribe, go to
Hi Bruce,
the sample size.
rate& sample size = FFT Bin size (resolution or filter band width) is used to get
back.
noise floor.
5V power. Also the raising noise below 100Hz (ADC serve& noise on the ADC power /
Example:
Your sample sizes are far too small to be particularly useful in
measuring phase noise down to offsets of 1-10Hz or so,
Phase noise is highly coloured at such offsets necessitating the use of
bin sizes substantially smaller than the lowest offset frequency of
interest.
However decreasing the bin size beyond a small fraction of the lowest
frequency of interest is counter productive in that one forgoes the
effect of averaging to reduce the variance of the noise signal power
within each bin.
There is a NIST paper on the effect of equivalent filter bandwidth on
the accuracy of coloured noise measurements.
Indeed one can break the frequency range into a set of bands, the higher
frequency bands having larger bin sizes and greater averaging and hence
(lower bin noise signal power variance) than the lower frequency bands.
However for the purposes of spur identification using as small a bin
size as possible can be useful.
Ideally the input circuit& ADC of the 3562A would be nice but with much larger RAM
Hanspeter
Using a high end PC should allow real time signal processing with
200ksps or greater, this is certainly the case for some external USB
instruments.
Would be nice to use something like the ADS1278.
http://www.ti.com/product/ads1278
Lots of channels to cross correlate, and very little flicker noise.
On Nov 28, 2012, at 9:29 AM, Support HpW-Works.com support@hpw-works.com wrote:
Hi Bruce,
the sample size.
back.
noise floor.
Example:
Hanspeter
Of Bruce Griffiths
Bruce,
sample size.
the sample size.
noise floor.
HpW
To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts
