In a message dated 5/30/2007 05:38:40 Pacific Daylight Time,
pvince@theiet.org writes:
interference from an off-frequency signal. I hadn't bothered to lock
the counter to an external reference, and on measuring a Rubidium
source against its internal oscillator, got a reading about 1.4 x
10^-9 high, which matched perfectly this 70-second period Locking
the counter to an external reference, this beating went away.
Hi Peter,
I was using the same PRS10 also as the counters' reference. Maybe not a good
idea? I will try again with the internal ref, and my Cs as a ref.
Glad you did see this as well, and fixed it!
bye,
Said
************************************** See what's free at http://www.aol.com.
Hi Said,
My hp53310 shows the same artifacts if the input frequency is nearly
the reference frequency. If I use the reference as input frequency
the noise is lower. When I adjust the time/div to more than 2 times
the frame flyback time, I can see a disturbance at the fylback
interval with an amplitude of a few hundred ps. The behaviour is with
both internal and external reference. The hp53310 is the modulation
domain analyzer which forms the basis of the 53131/53132.
Henk
lock
Hi Peter,
not a good
bye,
www.aol.com.
time-nuts mailing list
time-nuts@febo.com
