trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
boat lettering
GJ
Gil Johnson
Mon, May 12, 2008 1:09 AM
Bob, don't blame boat manufaturers for how a boat's name is displayed.  It's
not their responsibility and the USCG has specific requirements for font size
and a restriction not to use fancy fonts.  BTW, side nameboards aren't
required and don't eliminate the requirement for transom boat name and hailing
port display requirements.
Gil
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.
Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Bob, don't blame boat manufaturers for how a boat's name is displayed. It's not their responsibility and the USCG has specific requirements for font size and a restriction not to use fancy fonts. BTW, side nameboards aren't required and don't eliminate the requirement for transom boat name and hailing port display requirements. Gil _____________________________________________________________________________ _______ Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
SW
Sean Welsh
Mon, May 12, 2008 1:47 AM
Gil Johnson wrote:
...  BTW, side nameboards aren't
The way I read the statue, there is no requirement for the name/port to
be specifically on the transom for recreational boats, only "marked
together on some clearly visible exterior part of the hull."  So, yes,
side name display would, indeed, "eliminate" the (non-existent)
requirement for "transom ... display", so long as the name and hailing
port so displayed on the side(s) meets all other requirements (e.g. 4"
lettering).
Non-recreational (commercial) documentation is a different story altogether.
FWIW.
-Sean
http://OurOdyssey.BlogSpot.com
Gil Johnson wrote: > ... BTW, side nameboards aren't > required and don't eliminate the requirement for transom boat name and hailing > port display requirements. > The way I read the statue, there is no requirement for the name/port to be specifically on the transom for recreational boats, only "marked together on some clearly visible exterior part of the hull." So, yes, side name display would, indeed, "eliminate" the (non-existent) requirement for "transom ... display", so long as the name and hailing port so displayed on the side(s) meets all other requirements (e.g. 4" lettering). Non-recreational (commercial) documentation is a different story altogether. FWIW. -Sean http://OurOdyssey.BlogSpot.com
