I had originally planned to just give an update to my continued observations
in connection with bypass oil filters and synthetic oil. Long time members
will remember the original work that began in October of 1998 - my, my,
could it possibly be that long ago. Well maybe they won't remember the
actual work, but they will remember that I wrote about this subject back
then. When the project first began, it did not include tests of synthetic
oil. That became an object of the test beginning in February of 2000.
The flood of e-mail I have received about these subjects has convinced me
that a brief restatement of these tests could be useful. For those who want
all the original work, they are in the archives. If you don't have an
interest in this subject, just delete these posts.
HOW IT STARTED
In the summer of 1998, there was a thread on TWL that discussed bypass oil
filters. At the time, I had never heard of such filters and didn't have a
clue about how such filters worked. I had a conversation with a respected
engine mechanic who told me that a fishing boat captain had installed such a
filter and later removed it because it didn't work. At that point, CaptnWil
made a mistake that he will not soon make again. Without verifying the
story with the source - the fishing boat captain - CaptnWil reported the
conversation.
Gulf Coast Filters manufactured the bypass oil filter in question, and in
due course, Charlie Sims, president of that corporation, called me on the
phone to discuss the situation. His claims were shocking to me, and I asked
for some real data to back them up. I told him that I was from an
engineering background, and he should be careful what he sent since I would
look at the data from an engineering point of view and report what I found -
good or bad.
I was surprised to find that none of the data I got was "sales literature."
It consisted of engineering data from Shell Oil Company, The US Military,
and such other technical sources. I learned that the North Carolina Ferry
System used GCF bypass oil filters on all their ferries. Since the ferry
maintenance headquarters was close by, I visited with its leader, asked
questions, and observed the ferry installations.
I phoned Charlie to tell him that I found all was in order in an engineering
sense and that I would report my findings to TWL. He asked, if in addition
to reporting what I had read and discussed with the ferry people, would I
consider testing the filter itself. I accepted with the caution that I
would report the results of the test - good or bad, and if they were bad, he
might not like that. I declared that if that gave him a problem, we should
just drop the whole issue right there. The equipment was at my door within
a week and installed on AfterSail a week after that.
WHAT A BYPASS OIL FILTER DOES
The oil filter world for internal combustion engines is divided into two
groups, Full Flow, and Bypass.
It is intended that all the oil pumped by the oil pump pass through the Full
Flow filter. The only time that isn't intended to do so is when the
pressure drop across the full flow oil filter is too high. That condition
is created at engine startup and when the filter gets clogged. The design
of the full flow filter is based on the truth that dirty oil is better than
no oil. That means that the filtering element must be carefully designed so
that it takes out as much crud as possible, but still allow full oil flow at
all times. Because of that design restriction, oil filter elements do not
normally remove particles less than about 20 microns. Remember that it is
intended that all the oil that gets to the engine goes through the full flow
oil filter.
The Bypass Oil Filter receives oil from the oil pump, filters it, and
returns it to the crankcase - it bypasses the engine. At first blush, that
seems a very stupid thing to do, but have faith, it will become very clear
as we go along.
Because none of the oil that leaves the bypass oil filter goes directly to
the engine, but back to the crankcase, it has no restriction on how small a
particle it can safely filter. If it gets clogged up, the system is right
back where it started before installing the bypass oil filter - no
catastrophic harm will come from this condition. The result of this is that
the bypass oil filter can, and does, safely filter particles of sub-micron
size. About 10% of the oil is normally directed through the bypass oil
filter.
WHAT ARE THE CLAIMS
All of my tests were done on bypass oil filters produced by Gulf Coast
Filters, but there are many different manufacturers of these filters. They
all work on the same general principle, but most have different kinds of
filter media.
The claim for the bypass oil filter is that the better filtering will reduce
the wear in the engine, allow extended oil drains, and increase engine life.
It follows, if that is true, that there will be less cost to the owner, less
used oil to dispose of, and an improved the environment.
The sole purpose of CaptnWil's tests was to make an independent judgment for
his own benefit about the validity of those claims. I share the results
with you for what ever purpose you desire. I have nothing to sell and no
financial interest in anything I report on to TWL. It is desirable to have
good engineering data from other sources, but if they were true, I should be
able to corroborate their findings.
ABOUT THE TESTS
It was decided that the tests would be in the form of taking oil samples on
the engines involved and having independent laboratory analyses done on
those samples. There will be more about the value of laboratory analysis a
little later, but for now, just consider it to be one of the most valuable
tools available to any engine owner.
Over the course of time, seven engines were involved in these tests, and
four continue to be part of this "work in progress." I owned, or have
owned, all of the engines in this test series. There were five diesel
engines and two gasoline engines involved. Of the remaining four, two are
diesel.
I was very fortunate to discover a portable oil analyzer (Lubri-Sensor) in
the early stages of these tests. It was determined that the portable oil
analyzer - POA as CaptnWil coined a name for it - produced very accurate
results. In addition to laboratory analysis, it is the perfect instrument
to conduct the tests on such a large number (to me) of engines at frequent
intervals. There'll be more about the POA a little later, but it produces
results at least as sensitive and useful as the formal laboratory analysis.
The tests were made my CaptnWil alone, and all conclusions are his alone.
The information that follows will be on the equipment and oil I used.
Results from different bypass filters and different oils may vary. CaptnWil
only offers data and opinions on products he has actually tested. That
should not be taken to mean that there is any bias against other filters
and/or oil. It just means I haven't tested them so I can offer no opinion
about them. The oils in the tests were Shell Rotella T 15W-40, Mobil Delcac
1 5W-40 and Mobil 1 0W-30 synthetic oils.
WHAT THE POA READINGS MEAN
This little blurb will give you a feel for what the POA readings mean. The
table will be included in each segment so you can keep score.
The POA measures the difference in the electrical capacitance of a sample of
used oil as compared to a sample of new oil of the same brand and specs. It
reports its findings on a scale of 0 to 12. 0 (zero) is the value of new
oil from a newly opened container. New oil is saved in an airtight
container for future use.
The readings increase as any contaminates are introduced into the oil. The
meaning of the readings is different for petroleum based oils and full
synthetic oils. It is undetermined for blends. It could be worked out for
a blend, but would have to be done on an individual oil basis. Here's what
the reading mean:
POA READING ACTION REQUIRED
Petroleum Full
Based Synthetic
2.5 3.5 Change Bypass Element
3.6 5.0 Get Laboratory Analysis
4.6 8.0 Change Oil
The difference in the readings for petroleum based oil and synthetic stock
is because these oil stocks have different electrical characteristics. The
action recommended at the different levels was determined by matching the
readings with the recommendations of laboratory analysis on the same
samples. All of the readings I have ever taken match directly with
Next time, we'll detail some actual results.
CaptnWil
