Hi all,
I am using PJSUA as client application for ICE and not able to get TCP as
transport in ice candidate , its getting UDP like this
a=candidate:Ra2c3735 1* UDP* 16777215 10.44.55.53 49794 typ relay raddr
10.44.54.86 rport 4037
I have tried the command as:
./pjsua-x86_64-unknown-linux-gnu --use-turn --use-ice --turn-tcp
--turn-srv=10.44.55.53;transport=tcp
While for server application I used
*./pjsua-x86_64-unknown-linux-gnu --use-turn --turn-tcp *
Also I am not getting any packet related to tcp on server application as
seen on wireshark. Is anything wrong here??
I have turn server for relaying purpose. Can anyone help me in knowing if
there is support of TCP for ICE??
I got this link but its quite old
http://permalink.gmane.org/gmane.comp.voip.pjsip/11146
Regards
Ashish
TCP to turn relay definitely works using pjsua, at least it did years
ago when I tested it. Try blocking the UDP ports and see if ICE
negotiates TCP. - Bill
On 11/14/2014 7:29 AM, ashish khowal wrote:
Hi all,
as transport in ice candidate , its getting UDP like this
a=candidate:Ra2c3735 1UDP 16777215 10.44.55.53 49794 typ relay raddr
as seen on wireshark. Is anything wrong here??
if there is support of TCP for ICE??
Regards
Ashish
Visit our blog: http://blog.pjsip.org
pjsip mailing list
pjsip@lists.pjsip.org
http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org
Hi Bill,
Can you please let me know how you did it. as I tried your suggestion in
the initially but with no luck. It will be great if you let me know the
exact commands you used for the same on client -server.
Also I tried Registration with TCP but its causing issue.
Regards
Ashish
On Fri, Nov 14, 2014 at 8:25 PM, Bill Gardner billg@wavearts.com wrote:
TCP to turn relay definitely works using pjsua, at least it did years ago
when I tested it. Try blocking the UDP ports and see if ICE negotiates TCP.
Hi all,
Regards
Ashish
pjsip mailing listpjsip@lists.pjsip.orghttp://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org
pjsip mailing list
Regards
Ashish
I can't remember if enabling TCP forces TCP. I think it uses TCP only when UDP is blocked. I was suggesting using firewall rules to block UDP.
Sent from my iPhone
On Nov 15, 2014, at 12:39 AM, ashish khowal aashishkhowal@gmail.com wrote:
Hi Bill,
Can you please let me know how you did it. as I tried your suggestion in the initially but with no luck. It will be great if you let me know the exact commands you used for the same on client -server.
Regards
Ashish
TCP to turn relay definitely works using pjsua, at least it did years ago when I tested it. Try blocking the UDP ports and see if ICE negotiates TCP. - Bill
Hi all,
I am using PJSUA as client application for ICE and not able to get TCP as transport in ice candidate , its getting UDP like this
a=candidate:Ra2c3735 1 UDP 16777215 10.44.55.53 49794 typ relay raddr 10.44.54.86 rport 4037
./pjsua-x86_64-unknown-linux-gnu --use-turn --use-ice --turn-tcp --turn-srv=10.44.55.53;transport=tcp
Also I am not getting any packet related to tcp on server application as seen on wireshark. Is anything wrong here??
I have turn server for relaying purpose. Can anyone help me in knowing if there is support of TCP for ICE??
Regards
Ashish
pjsip mailing list
pjsip mailing list
Regards
Ashish
pjsip mailing list
