trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
Fw: Fuel filtering - what do the commercial vessels use?
LN
Larry N. Brown
Thu, Jul 6, 2006 12:48 PM
I second Reid's observation, having used GCF filters on my '78 MT 34. The
old tanks had some kind of crud in them before I installed the F-1. When
you'd pull out a roll of bounties, the top third would look bad; you could
see how far the stuff had migrated. Over a period of time, it cleaned up the
tanks.
When I repowered Cigano, I had new tanks built with separate suction and
return for engines and fuel polishing. Engine suction is about 3/4" from
bottom; transfer/polishing is at 1/4". I have a spring timer on the Walbro
and the fuel is polished with an F-1. Mains and genset each have 2 Racor
500's with vacuum gauges so I can switch filters underway without having to
open the system.
My Floscan fuel flow system expressly requires 30m primary filtration. No
2's or 10's.
No connection with the Gulf Coast Filters but I polish my fuel at the dock
or underway with the F-1 and use an O-1 bypass filter on each main and
genset. Their construction is industrial grade.
Regards.
Larry
Cigano, 47' Prairie Sundeck
Lying Covington, LA
know that there are tugs and commercial boats, not
to mention long distance
trucks and busses, that run their engines 20,000
hours or more between major
overhauls. That's about 100 years of pleasure
boating. What kind of fuel
filtration system do they use?
According to the company press release, the North Carolina Ferry System
and
Texas National Guard Abrams tanks use Gulf Coast Filters; also many
trucking
companies (website below).
I have no affiliation with GCF; just a satisfied customer who has seen how
efficient my own F-1 filter has been in polishing the fuel in my 23 year
old
boat.
http://www.gulfcoastfilters.com/
Reid Gantt
Atlantic 30
"Vouivre"
docked at Sneads Ferry NC
http://lists.samurai.com/mailman/listinfo/trawlers-and-trawlering
To unsubscribe send email to
trawlers-and-trawlering-request@lists.samurai.com with the word
UNSUBSCRIBE and nothing else in the subject or body of the message.
Trawlers & Trawlering and T&T are trademarks of Water World
Productions. Unauthorized use is prohibited.
I second Reid's observation, having used GCF filters on my '78 MT 34. The old tanks had some kind of crud in them before I installed the F-1. When you'd pull out a roll of bounties, the top third would look bad; you could see how far the stuff had migrated. Over a period of time, it cleaned up the tanks. When I repowered Cigano, I had new tanks built with separate suction and return for engines and fuel polishing. Engine suction is about 3/4" from bottom; transfer/polishing is at 1/4". I have a spring timer on the Walbro and the fuel is polished with an F-1. Mains and genset each have 2 Racor 500's with vacuum gauges so I can switch filters underway without having to open the system. My Floscan fuel flow system expressly requires 30m primary filtration. No 2's or 10's. No connection with the Gulf Coast Filters but I polish my fuel at the dock or underway with the F-1 and use an O-1 bypass filter on each main and genset. Their construction is industrial grade. Regards. Larry Cigano, 47' Prairie Sundeck Lying Covington, LA >> know that there are tugs and commercial boats, not >> to mention long distance >> >trucks and busses, that run their engines 20,000 >> hours or more between major >> >overhauls. That's about 100 years of pleasure >> boating. What kind of fuel >> >filtration system do they use? > > According to the company press release, the North Carolina Ferry System > and > Texas National Guard Abrams tanks use Gulf Coast Filters; also many > trucking > companies (website below). > > I have no affiliation with GCF; just a satisfied customer who has seen how > efficient my own F-1 filter has been in polishing the fuel in my 23 year > old > boat. > > http://www.gulfcoastfilters.com/ > > Reid Gantt > Atlantic 30 > "Vouivre" > docked at Sneads Ferry NC > _______________________________________________ > http://lists.samurai.com/mailman/listinfo/trawlers-and-trawlering > > To unsubscribe send email to > trawlers-and-trawlering-request@lists.samurai.com with the word > UNSUBSCRIBE and nothing else in the subject or body of the message. > > Trawlers & Trawlering and T&T are trademarks of Water World > Productions. Unauthorized use is prohibited.
