time-nuts@lists.febo.com
Re: [time-nuts] Lucent KS-24361, HP/Symmetricom Z3809A, Z3810A, Z3811A, Z3812...
G
GandalfG8@aol.com
Sat, Nov 1, 2014 5:14 PM
I've confirmed from the model number that the GPS module on these is indeed
an Oncore UT+.
There's a Synergy engineering note available regarding Oncore battery
backup, and one place a copy can be found is here...
http://f6fgz.free.fr/Fichiers/GPS/Backup_Battery_Considerations.pdf
If so desired, it would be possible to retrospectively convert  the UT+ on
the Z3811A to take the usual rechargeable battery but the  precautions
mentioned in the engineering note would need to be  implemented.
I'm running file checks on my archives right now so can't confirm  exactly
what's involved, but I think there's one zero  ohm SMD chip to be removed at
least, and fitting a battery can of  course bring its own issues.
If anyone's interested, I've just uploaded some detailed photos  of the of
RFTG-U Ref-1 circuit board to Didier's manuals site.
Probably far more detail there than even the nuttiest of us might consider
to be sane or healthy but I've got it apart anyway so what the  heck....
and they might come in very useful if it decides to self  destruct whilst
I'm poking it about on the bench:-)
Regards
Nigel
GM8PZR
In a message dated 01/11/2014 06:20:00 GMT Standard Time, bob@evoria.net
writes:
Hi Bob  et al,
I don't understand the direction this question about the supercap  has
taken.  It's connected to pin 1 of the GPS receiver.  It looks  to be a UT+, so
that's the battery backup power.  According to my UT+  manual the current
draw on this pin is between 5uA (at 2.5V) and 100uA (at  5V)?  How many hours
will a .022F supercap keep at least 2.5V at that  sort of discharge rate?
Unless the cap has gone bad, it seems more  likely that Bob's comment about
it doing a fast survey and then doing a slower  one in the background
probably has merit.  In fact, my unit goes through  its survey mode pretty quickly
on power up.  So do those current/voltage  figures imply several hours on
the cap?
Bob
To: Discussion of precise time and  frequency measurement
time-nuts@febo.com
Sent: Friday, October 31,  2014 9:22 PM
Subject: Re: [time-nuts] Lucent KS-24361, HP/Symmetricom  Z3809A, Z3810A,
Z3811A, Z3812A GPSDO system
Hi
I  sort of doubt that a GPS aux supply is quite that low current. I have
seen  some RTC’s that won’t last a month on a coin cell. My recollection is
that the  Oncore backup is closer to that category than the “many years on a
cap”  group.
Bob
On Oct 31, 2014, at 9:26 PM, Brooke Clarke  brooke@pacific.net wrote:
Hi Bob:
When HP came out with the 300 series Rocky Mountain Basic computers they
were  fitted with a super cap to power the RTC.
I will keep time for some  months.
http://www.prc68.com/I/HPIB.shtml#300
Mail_Attachment --
Have Fun,
Brooke Clarke
http://www.PRC68.com
http://www.end2partygovernment.com/2012Issues.html
http://www.prc68.com/I/DietNutrition.html
Bob Camp wrote:
Hi
The ultra cap is a pretty small one (physical  small). You might be able
to find a larger (more farads) one that would fit in  the same space. It’s
not going to help for a hours and hours sort of outage.  It might get you
from dying in 15 minutes to dying in a half hour.
Bob
time-nuts mailing list  -- time-nuts@febo.com
To unsubscribe, go to
and follow the  instructions there.
I've confirmed from the model number that the GPS module on these is indeed an Oncore UT+. There's a Synergy engineering note available regarding Oncore battery backup, and one place a copy can be found is here... http://f6fgz.free.fr/Fichiers/GPS/Backup_Battery_Considerations.pdf If so desired, it would be possible to retrospectively convert the UT+ on the Z3811A to take the usual rechargeable battery but the precautions mentioned in the engineering note would need to be implemented. I'm running file checks on my archives right now so can't confirm exactly what's involved, but I think there's one zero ohm SMD chip to be removed at least, and fitting a battery can of course bring its own issues. If anyone's interested, I've just uploaded some detailed photos of the of RFTG-U Ref-1 circuit board to Didier's manuals site. Probably far more detail there than even the nuttiest of us might consider to be sane or healthy but I've got it apart anyway so what the heck.... and they might come in very useful if it decides to self destruct whilst I'm poking it about on the bench:-) Regards Nigel GM8PZR In a message dated 01/11/2014 06:20:00 GMT Standard Time, bob@evoria.net writes: Hi Bob et al, I don't understand the direction this question about the supercap has taken. It's connected to pin 1 of the GPS receiver. It looks to be a UT+, so that's the battery backup power. According to my UT+ manual the current draw on this pin is between 5uA (at 2.5V) and 100uA (at 5V)? How many hours will a .022F supercap keep at least 2.5V at that sort of discharge rate? Unless the cap has gone bad, it seems more likely that Bob's comment about it doing a fast survey and then doing a slower one in the background probably has merit. In fact, my unit goes through its survey mode pretty quickly on power up. So do those current/voltage figures imply several hours on the cap? Bob From: Bob Camp <kb8tq@n1k.org> To: Discussion of precise time and frequency measurement <time-nuts@febo.com> Sent: Friday, October 31, 2014 9:22 PM Subject: Re: [time-nuts] Lucent KS-24361, HP/Symmetricom Z3809A, Z3810A, Z3811A, Z3812A GPSDO system Hi I sort of doubt that a GPS aux supply is quite that low current. I have seen some RTC’s that won’t last a month on a coin cell. My recollection is that the Oncore backup is closer to that category than the “many years on a cap” group. Bob > On Oct 31, 2014, at 9:26 PM, Brooke Clarke <brooke@pacific.net> wrote: > > Hi Bob: > > When HP came out with the 300 series Rocky Mountain Basic computers they were fitted with a super cap to power the RTC. > I will keep time for some months. > http://www.prc68.com/I/HPIB.shtml#300 > > Mail_Attachment -- > Have Fun, > > Brooke Clarke > http://www.PRC68.com > http://www.end2partygovernment.com/2012Issues.html > http://www.prc68.com/I/DietNutrition.html > Bob Camp wrote: >> Hi >> >> The ultra cap is a pretty small one (physical small). You might be able to find a larger (more farads) one that would fit in the same space. It’s not going to help for a hours and hours sort of outage. It might get you from dying in 15 minutes to dying in a half hour. >> >> Bob _______________________________________________ time-nuts mailing list -- time-nuts@febo.com To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts and follow the instructions there.
