A past post thought it might interest some.
T&T: Day Tanks / Re : Invader no 1
Something I have liked that came with the boat. Invader has a day tank
mounted on the wheel house roof. It is a rectangular box that runs across
the roof, holds around 25 imp gallons. The tank is baffled. There are four
lines that run off / in to it.
One that feeds the tank from the DD return centre on top. Tank is vented and
has a fill cap on top as well.
Two lines run from each end of the tank. These lines pull from the tank
close to the top of the tank. They cross over and feed the main saddle tanks
opposite sides in the boat. Circulating the fuel and ballasting the boat as
you cruise along.
The other line running out of the tank has a T in line in the boat. From
there one line has a filter on it and feeds the furnace. The other line can
provide fuel to the DD. The gravity feed for the furnace is nice. There are
valves fixed to all the lines.
Proved so far to be very simple and effective for my needs.
Willy
Invader no 1
39 Kishi conversion
