Broken support of generic NMEA compatible GPSes
PK
Piotr Krysik
Tue, Dec 4, 2012 2:29 PM
Hi,
At the beginning of method update_cached_sensors(...) of class
gps_ctrl_impl there is a condition:
if(not gps_detected() || (gps_type != GPS_TYPE_JACKSON_LABS)) {
UHD_MSG(error) << "get_stat(): unsupported GPS or no GPS detected";
return std::string();
Even if constructor of the class detects that the gps_type is a
GPS_TYPE_GENERIC_NMEA it's impossible that the device will be supported
properly because of this single condition.
I would suggest following correction:
diff --git a/host/lib/usrp/gps_ctrl.cpp b/host/lib/usrp/gps_ctrl.cpp
index 917f115..8f7731f 100644
--- a/host/lib/usrp/gps_ctrl.cpp
+++ b/host/lib/usrp/gps_ctrl.cpp
@@ -63,7 +64,7 @@ private:
std::string update_cached_sensors(const std::string sensor) {
  • if(not gps_detected() || (gps_type != GPS_TYPE_JACKSON_LABS)) {
  • if(not gps_detected()) {
Piotr Krysik
pkrysik@elka.pw.edu.pl
Hi, At the beginning of method update_cached_sensors(...) of class gps_ctrl_impl there is a condition: if(not gps_detected() || (gps_type != GPS_TYPE_JACKSON_LABS)) { UHD_MSG(error) << "get_stat(): unsupported GPS or no GPS detected"; return std::string(); } Even if constructor of the class detects that the gps_type is a GPS_TYPE_GENERIC_NMEA it's impossible that the device will be supported properly because of this single condition. I would suggest following correction: diff --git a/host/lib/usrp/gps_ctrl.cpp b/host/lib/usrp/gps_ctrl.cpp index 917f115..8f7731f 100644 --- a/host/lib/usrp/gps_ctrl.cpp +++ b/host/lib/usrp/gps_ctrl.cpp @@ -63,7 +64,7 @@ private: } std::string update_cached_sensors(const std::string sensor) { - if(not gps_detected() || (gps_type != GPS_TYPE_JACKSON_LABS)) { + if(not gps_detected()) { UHD_MSG(error) << "get_stat(): unsupported GPS or no GPS detected"; return std::string(); } -- Piotr Krysik pkrysik@elka.pw.edu.pl
