trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
TWL: reviving dead batteries
F
fjflinn@accessbee.com
Sat, Feb 17, 2001 12:06 AM
Thanks for all the help . As a follow-up, I checked on the batteries
yesterday and they were charged to 12 volts but when subjected to a load
test, all 4 batteries failed fairly quickly. So now I am in the process of
replacing them as many of you suggested. I needed the battery charger
anyway. Thanks
Thanks for all the help . As a follow-up, I checked on the batteries yesterday and they were charged to 12 volts but when subjected to a load test, all 4 batteries failed fairly quickly. So now I am in the process of replacing them as many of you suggested. I needed the battery charger anyway. Thanks
S
scaramouche@tvo.org
Sat, Feb 17, 2001 5:23 PM
load
process of
anyway. Thanks
Just before you do that, read the following from the Trawler List.
Perhaps you already know of it though.
  1. There is a product called Battery Equaliser on the market.  You
    add one
    ounce per cell to your batteries and it will de-sulfate the plates.
    Takes
    about 3 to 5 charge/discharge cycles for it to do its job.  Results :
    It
    works, I have two banks of batteries, one is quite old (7 or 8 years)
    and
    since adding this product batteries take higher charge, hold the
    charge
    longer and take less time to recharge.  Great stuff in my opinion.
    You can
    contact them at:  Battery Equaliser USA LLC  phone is (888) 851-4331.
    They
    also have a web site at www.batteryequaliser.com.
    //www.batteryequaliser.com/The site is quite complete
    and gives more than you really want to know.  I reccomend the product
    because
    I have and am using it and it works as advertised.
from "SobreElMar@aol.com"
fjflinn@accessbee.com writes: >Thanks for all the help . As a follow-up, I checked on the batteries >yesterday and they were charged to 12 volts but when subjected to a >load >test, all 4 batteries failed fairly quickly. So now I am in the >process of >replacing them as many of you suggested. I needed the battery charger >anyway. Thanks Just before you do that, read the following from the Trawler List. Perhaps you already know of it though. 1. There is a product called Battery Equaliser on the market. You add one ounce per cell to your batteries and it will de-sulfate the plates. Takes about 3 to 5 charge/discharge cycles for it to do its job. Results : It works, I have two banks of batteries, one is quite old (7 or 8 years) and since adding this product batteries take higher charge, hold the charge longer and take less time to recharge. Great stuff in my opinion. You can contact them at: Battery Equaliser USA LLC phone is (888) 851-4331. They also have a web site at www.batteryequaliser.com. //www.batteryequaliser.com/The site is quite complete and gives more than you really want to know. I reccomend the product because I have and am using it and it works as advertised. from "SobreElMar@aol.com"
