Fwd: USRP N210 - Error: RuntimeError: operation borked with code 12, contact support@ettus.com
PR
Pradeep Reddy
Sun, Mar 24, 2013 11:13 AM
Hi,
I am using USRP N210 on ubuntu 12.04. I have  installed the latest stable
uhd drivers and fw+fpga images in safe mode . After that, any thing I do is
giving the following error:
for example:
pradeep@pradeep-MacBookPro:/usr/share/uhd/utils$ uhd_usrp_probe
linux; GNU C++ version 4.6.3; Boost_104601; UHD_003.005.001-49-stable
-- Opening a USRP2/N-Series device...
-- Current recv frame size: 1472 bytes
-- Current send frame size: 1472 bytes
support@ettus.support@ettus.com
com
I am using an N210 and uhd_find_devices shows the following:
-- UHD Device 0
Device Address:
type: usrp2
addr: 192.168.10.1
name:
serial:
Does anybody know the reason for this error?
Thanks,
Pradeep
Thanks,
Pradeep
Hi, I am using USRP N210 on ubuntu 12.04. I have installed the latest stable uhd drivers and fw+fpga images in safe mode . After that, any thing I do is giving the following error: for example: pradeep@pradeep-MacBookPro:/usr/share/uhd/utils$ *uhd_usrp_probe* linux; GNU C++ version 4.6.3; Boost_104601; UHD_003.005.001-49-stable -- Opening a USRP2/N-Series device... -- Current recv frame size: 1472 bytes -- Current send frame size: 1472 bytes *Error: RuntimeError: operation borked with code 12, contact support@ettus.<support@ettus.com> com* * * I am using an N210 and *uhd_find_devices* shows the following: -------------------------------------------------- -- UHD Device 0 -------------------------------------------------- Device Address: type: usrp2 addr: 192.168.10.1 name: serial: Does anybody know the reason for this error? Thanks, Pradeep Thanks, Pradeep
