time-nuts@lists.febo.com
Re: [time-nuts] Thunderbolt Monitor
ML
Major L. McGee III
Wed, Jan 23, 2013 5:31 PM
John and Ken that did the trick.  I ended up trying the easiest option
first since I already had device manager up and it worked like a charm.
I'll look into Arduino for some options for the lcd project.  I keep my
Thunderbolt right beside my frequency counter and leave both of them on
all the time attached to a good UPS.  The counter has a Rubidium
oscillator in it but I use the output from the thunderbolt at times as
well.  My master plan is to build a box for the rack with a low phase
noise multi channel distribution amplifier to feed to my other equipment
with the 10MHz signal.
How my racks are setup the LCD should give me all the info I need in
most cases.  Sometimes the lady heather software is just too much info.
I do like the satellite tracking though.  That is a cool feature.
Thanks,
Major
John and Ken that did the trick. I ended up trying the easiest option first since I already had device manager up and it worked like a charm. I'll look into Arduino for some options for the lcd project. I keep my Thunderbolt right beside my frequency counter and leave both of them on all the time attached to a good UPS. The counter has a Rubidium oscillator in it but I use the output from the thunderbolt at times as well. My master plan is to build a box for the rack with a low phase noise multi channel distribution amplifier to feed to my other equipment with the 10MHz signal. How my racks are setup the LCD should give me all the info I need in most cases. Sometimes the lady heather software is just too much info. I do like the satellite tracking though. That is a cool feature. Thanks, Major
CA
Chris Albertson
Wed, Jan 23, 2013 5:40 PM
Look into the TI Lauchpad.  It is about the same idea as Arduino but
they start at $4.30 (shipped) and the larger ARM based one is still
under $18.  I'm sure TI loses money on each one they sell
Those little 2x16 LCD displays are easy to use but you can make them
much nicer by adding a rotary shaft encoder to make it work like a
"scroll knob".  It is a very intuitive control for a user and easy to
program. Then you can have things like satelite info and so on, untill
your controller runs out of RAM
Thanks,
Major
To unsubscribe, go to
Chris Albertson
Redondo Beach, California
Look into the TI Lauchpad. It is about the same idea as Arduino but they start at $4.30 (shipped) and the larger ARM based one is still under $18. I'm sure TI loses money on each one they sell Those little 2x16 LCD displays are easy to use but you can make them much nicer by adding a rotary shaft encoder to make it work like a "scroll knob". It is a very intuitive control for a user and easy to program. Then you can have things like satelite info and so on, untill your controller runs out of RAM On Wed, Jan 23, 2013 at 9:31 AM, Major L. McGee III <majorm@sc.rr.com> wrote: > John and Ken that did the trick. I ended up trying the easiest option first > since I already had device manager up and it worked like a charm. > > I'll look into Arduino for some options for the lcd project. I keep my > Thunderbolt right beside my frequency counter and leave both of them on all > the time attached to a good UPS. The counter has a Rubidium oscillator in > it but I use the output from the thunderbolt at times as well. My master > plan is to build a box for the rack with a low phase noise multi channel > distribution amplifier to feed to my other equipment with the 10MHz signal. > > How my racks are setup the LCD should give me all the info I need in most > cases. Sometimes the lady heather software is just too much info. I do > like the satellite tracking though. That is a cool feature. > > Thanks, > > Major > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. -- Chris Albertson Redondo Beach, California
