trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
Monitoring system (was: Wi-fi camera)
WB
Wayne Beardsley
Thu, Dec 8, 2011 5:24 PM
There is an inexpensive way to provide remote video monitoring that
does not require special access through the marina firewall.  All that
is needed is a computer with one or more video cameras connected, and
remote access software.
I use a product called "Logmein Free" for remote access.  As the name
implies the cost is free and it requires no special firewall settings
to operate, only normal web browser access.  The software is reliabe,
easy to use and easy to configure.  The URL is:
https://secure.logmein.com/
The computer should be configured to boot up automatically after a
power failure.  A laptop is ideal because it provides automatic
battery backup.
Regards,
Wayne Beardsley
Grand Banks 49 Classic, Long Legged Lady
There is an inexpensive way to provide remote video monitoring that does not require special access through the marina firewall. All that is needed is a computer with one or more video cameras connected, and remote access software. I use a product called "Logmein Free" for remote access. As the name implies the cost is free and it requires no special firewall settings to operate, only normal web browser access. The software is reliabe, easy to use and easy to configure. The URL is: https://secure.logmein.com/ The computer should be configured to boot up automatically after a power failure. A laptop is ideal because it provides automatic battery backup. Regards, Wayne Beardsley Grand Banks 49 Classic, Long Legged Lady
BM
Bob McLeran
Thu, Dec 8, 2011 5:31 PM
You still have to connect your laptop to the internet, and that is where
the marina WiFi comes into play. If you have a method of connecting (an
air card, etc) that is independent of the marina's WiFi, then you're all
set. If not, then you must still use the marina WiFi and that is where
the issue of continuous use/access comes into play.
<><><><><><><><><><><><>Mozilla Thunderbird<><><><><><><><><><>
Bob McLeran and Judy Young              Manatee Cove Marina
MV Sanderling                            Patrick Air Force Base
DeFever 41 Trawler                      Melbourne, Florida
Blog: http://sanderling2011.blogspot.com/
Pics: http://tinyurl.com/yjx2vky&  http://tinyurl.com/yhxjvas
You still have to connect your laptop to the internet, and that is where the marina WiFi comes into play. If you have a method of connecting (an air card, etc) that is independent of the marina's WiFi, then you're all set. If not, then you must still use the marina WiFi and that is where the issue of continuous use/access comes into play. <><><><><><><><><><><><>Mozilla Thunderbird<><><><><><><><><><> Bob McLeran and Judy Young Manatee Cove Marina MV Sanderling Patrick Air Force Base DeFever 41 Trawler Melbourne, Florida Blog: http://sanderling2011.blogspot.com/ Pics: http://tinyurl.com/yjx2vky& http://tinyurl.com/yhxjvas On 12/8/2011 12:24 PM, Wayne Beardsley wrote: > There is an inexpensive way to provide remote video monitoring that > does not require special access through the marina firewall. All that > is needed is a computer with one or more video cameras connected, and > remote access software. > > I use a product called "Logmein Free" for remote access. As the name > implies the cost is free and it requires no special firewall settings > to operate, only normal web browser access. The software is reliabe, > easy to use and easy to configure.
HJ
Henry J. Dennig
Thu, Dec 8, 2011 8:47 PM
I have tried to do the same with an aircard and a Cradlepoint router.
Verizon only has ONE LTE card that they can assigned a static IP address on.
Sprint has several options but their service is slower at our marina.  I
have both cards aboard right now.
Henry
<snip> From: trawlers-bounces@lists.trawlering.com [mailto:trawlers-bounces@lists.trawlering.com] On Behalf Of Bob McLeran Sent: Thursday, December 08, 2011 12:32 PM To: trawlers@lists.trawlering.com Subject: Re: T&T: Monitoring system (was: Wi-fi camera)
I have tried to do the same with an aircard and a Cradlepoint router. Verizon only has ONE LTE card that they can assigned a static IP address on. Sprint has several options but their service is slower at our marina. I have both cards aboard right now. Henry <snip> From: trawlers-bounces@lists.trawlering.com [mailto:trawlers-bounces@lists.trawlering.com] On Behalf Of Bob McLeran Sent: Thursday, December 08, 2011 12:32 PM To: trawlers@lists.trawlering.com Subject: Re: T&T: Monitoring system (was: Wi-fi camera) You still have to connect your laptop to the internet, and that is where the marina WiFi comes into play. If you have a method of connecting (an air card, etc) that is independent of the marina's WiFi, then you're all set. If not, then you must still use the marina WiFi and that is where the issue of continuous use/access comes into play.
