time-nuts@lists.febo.com
Re: [time-nuts] Different breed of time nuttery
G
GandalfG8 (at) aol.com
Mon, Feb 24, 2014 9:02 AM
A triumph of matter over mind.
In a message dated 24/02/2014 04:35:21 GMT Standard Time,
dmendesf@gmail.com writes:
This  is a different breed of time nuttery than usual in this list but i
think  that at least some of you will enjoy  it:
http://www.behance.net/gallery/FLUX-1440/2420150
Found it at  hack a  day....
Daniel
time-nuts  mailing list -- time-nuts@febo.com
To unsubscribe, go to
and follow the  instructions there.
A triumph of matter over mind. In a message dated 24/02/2014 04:35:21 GMT Standard Time, dmendesf@gmail.com writes: This is a different breed of time nuttery than usual in this list but i think that at least some of you will enjoy it: http://www.behance.net/gallery/FLUX-1440/2420150 Found it at hack a day.... Daniel _______________________________________________ time-nuts mailing list -- time-nuts@febo.com To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts and follow the instructions there.
CH
Chuck Harris
Mon, Feb 24, 2014 2:08 PM
Really impressive would be to have it create the
patterns that make the numeric display out of only
several feet of slowly moving rope connected as a
loop... but that would require some thinking, rather
than just a brute force approach.
-Chuck Harris
Daniel
Really impressive would be to have it create the patterns that make the numeric display out of only several feet of slowly moving rope connected as a loop... but that would require some thinking, rather than just a brute force approach. -Chuck Harris GandalfG8@aol.com wrote: > A triumph of matter over mind. > > > In a message dated 24/02/2014 04:35:21 GMT Standard Time, > dmendesf@gmail.com writes: > > > This is a different breed of time nuttery than usual in this list but i > think that at least some of you will enjoy it: > > http://www.behance.net/gallery/FLUX-1440/2420150 > > Found it at hack a day.... > > Daniel
TH
Tom Holmes
Mon, Feb 24, 2014 2:51 PM
So that is what string theory is all about!
Who knew?
Tom Holmes, N8ZM
-----Original Message-----
From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] On
Behalf Of GandalfG8@aol.com
Sent: Monday, February 24, 2014 4:02 AM
To: time-nuts@febo.com
Subject: Re: [time-nuts] Different breed of time nuttery
Daniel
So that is what string theory is all about! Who knew? Tom Holmes, N8ZM -----Original Message----- From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] On Behalf Of GandalfG8@aol.com Sent: Monday, February 24, 2014 4:02 AM To: time-nuts@febo.com Subject: Re: [time-nuts] Different breed of time nuttery A triumph of matter over mind. In a message dated 24/02/2014 04:35:21 GMT Standard Time, dmendesf@gmail.com writes: This is a different breed of time nuttery than usual in this list but i think that at least some of you will enjoy it: http://www.behance.net/gallery/FLUX-1440/2420150 Found it at hack a day.... Daniel _______________________________________________ time-nuts mailing list -- time-nuts@febo.com To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts and follow the instructions there. _______________________________________________ time-nuts mailing list -- time-nuts@febo.com To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts and follow the instructions there.
JL
Jim Lux
Mon, Feb 24, 2014 3:27 PM
It's art, after all..
Maybe the huge pile of rope is part of the art?  Like the threads of
life that the 3 fates decide to cut.  Or if the rope/thread gets tangled
and jammed.  And the fact that the machine cannot go backwards.
There is a mention in the write up of the whole order out of chaos
thing, too.
The artist has some other interesting things.. the "dot matrix" graffiti
printer, for instance.
On 2/24/14 6:08 AM, Chuck Harris wrote: > Really impressive would be to have it create the > patterns that make the numeric display out of only > several feet of slowly moving rope connected as a > loop... but that would require some thinking, rather > than just a brute force approach. > > It's art, after all.. Maybe the huge pile of rope is part of the art? Like the threads of life that the 3 fates decide to cut. Or if the rope/thread gets tangled and jammed. And the fact that the machine cannot go backwards. There is a mention in the write up of the whole order out of chaos thing, too. The artist has some other interesting things.. the "dot matrix" graffiti printer, for instance.
PK
Poul-Henning Kamp
Mon, Feb 24, 2014 3:46 PM
In message 530B5258.4060202@erols.com, Chuck Harris writes:
Nah... Just run it through a turing machine which counts the
seconds/minutes whatever, and you're golden:
http://aturingmachine.com/
Poul-Henning Kamp      | UNIX since Zilog Zeus 3.20
phk@FreeBSD.ORG        | TCP/IP since RFC 956
FreeBSD committer      | BSD since 4.3-tahoe
Never attribute to malice what can adequately be explained by incompetence.
In message <530B5258.4060202@erols.com>, Chuck Harris writes: >Really impressive would be to have it create the >patterns that make the numeric display out of only >several feet of slowly moving rope connected as a >loop... but that would require some thinking, rather >than just a brute force approach. Nah... Just run it through a turing machine which counts the seconds/minutes whatever, and you're golden: http://aturingmachine.com/ -- Poul-Henning Kamp | UNIX since Zilog Zeus 3.20 phk@FreeBSD.ORG | TCP/IP since RFC 956 FreeBSD committer | BSD since 4.3-tahoe Never attribute to malice what can adequately be explained by incompetence.
