Hi all,
I'm playing around with the Bell X1 3D model from the Smithsonian
(http://3d.si.edu/explorer?modelid=1341). I've downloaded the STL and
imported it into OpenSCAD, and want to cut it in half and produce a shell,
for 3D printing.
The following does what I want:
intersection() {
minkowski() {
difference() {
translate([-5000, -1000, -10000 + 200])
cube([5000, 4000, 10000]);
aircraft();
sphere(50);
aircraft();
module aircraft() {
import("bellX1-300kPrintReady.stl");
NB before trying the above yourself: it takes 2 hours to compile due to
the minkowski()!
But it would be nice if OpenSCAD could be told to automatically calculate
the bounding box for an object. I'm aware of the bounding box code at
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Commented_Example_Projects,
but that still needs the user to specify the value for the "height". And I
could use the hull() command, but that gives me a hull over the whole
aircraft, and I want to split it in half, so I'd still need to specify a
box.
So what I think I'm after is a function to return an array of [X,Y,Z]
coordinates, which could then be processed with a for() loop, something like
this:
for (i = [/vertices/(aircraft())] { ... }
and in the body of the loop find the max() and min() of each coordinate.
Is there something like this already? Or planned? Or am I going in the wrong
direction entirely?
Frank
View this message in context: http://forum.openscad.org/Access-vertices-in-an-object-tp18995.html
Sent from the OpenSCAD mailing list archive at Nabble.com.
If you just want the shell, I believe most slicers will allow you to print only the shell of an object.
We don’t have a good plan for how to support what you ask for in OpenSCAD. For imported STL files, it’s likely that querying the bounding box would be supported before querying then vertices themselves.
-Marius
One approach to have access to a model vertex coordinates is to export it in
AMF format, to process it with Neon22's python code and to load the
polyhedron in OpenSCAD format back in your code. See: Wrapping text around a
complex geometry
http://forum.openscad.org/Wrapping-text-around-a-complex-geometry-tc18145.html
View this message in context: http://forum.openscad.org/Access-vertices-in-an-object-tp18995p18999.html
