Rich posted that he found leaks in belt driven coolant pumps. It reminded
me of the advantage of gear driven pumps: no belt tension to add bearing wear.
On my last boat, I had a gear driven pump develop a salt water leak....
it dribbled down the engine and sprayed about the engine...caused rust before
I found it... which required cleaning and repainting. My current boat had the
same condition on one engine when I bought it.
Depending on the pump style, you can add a "cover" over the top of any
pump case opening to contain water spraying from the shaft. A piece of
inner tube rubber or gasket material can be easily affixed with plastic
ties. My prior 6V53 pumps were open on top, my current 71 series pumps
are enclosed, so don't spray even if leaking. Aluminum sheet will work for
perhaps a year before it corrodes...foil only a few months at most.
Beneath the pump, an opening is present to allow a salt water to drip
off. Here you can install a container under the pump that will fit; I used
a plastic food storage plastic container (with no cover). I drilled a hole
and inserted clear 1/2" plastic tubing and glued it in place...sometimes
tricky
to get a glue to adhere. The tube bypasses the engine into the bilge. Any
salt water leak will leave a salt residue and perhaps liquid in the
container,
so during routine engine checks it's easy to spot effects of a leak before
your engine is rusted....
As a double check, or if your pump is out of sight,you can also place
the lower end of the tube in the bilge in a can or other shallow container
for easy visual check for liquid....
Cheers,
Rob Brueckner
1972 Hatteras Yachtfisherman
