trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
TWL: Sorry
N
nunas@pacific.net.sg
Thu, Mar 16, 2000 3:11 AM
All,
Sorry.  The incoming message about Manatee did not look like anything but
plain text at my end, but I am told that it was in MIME protocol (whatever
that is!).  I have been informed that my reply was full of mime junk.
I believe I have all settings in Outlook set to minimise this problem but it
persists. Also, if I see anything that looks like "MIME" I try to remember
to do 'cut and paste' to a fresh reply.  If any confuser gurus out there
want to give me a detailed list of settings in Outlook 2000 to verify, I'd
be happy to double-check.
I get over a hundred emails a day. It is highly likely that despite my
efforts, my responses to people that post in MIME protocol will continue to
bother a few list members (only the digest?) from time to time.  So if this
becomes too much of a bother I will be withdrawing from the TWL.  That will
be a pity, as I enjoy the list and I believe that other than Georgs, I have
the most "seniority" on the list.  Also, I believe that I have been a net
contributor.
Georgs, I suggest that the list server needs tweaking.  IMHO, It is
unreasonable to expect people to remember to not use advanced protocols on
this list.
Maurice
All, Sorry. The incoming message about Manatee did not look like anything but plain text at my end, but I am told that it was in MIME protocol (whatever that is!). I have been informed that my reply was full of mime junk. I believe I have all settings in Outlook set to minimise this problem but it persists. Also, if I see anything that looks like "MIME" I try to remember to do 'cut and paste' to a fresh reply. If any confuser gurus out there want to give me a detailed list of settings in Outlook 2000 to verify, I'd be happy to double-check. I get over a hundred emails a day. It is highly likely that despite my efforts, my responses to people that post in MIME protocol will continue to bother a few list members (only the digest?) from time to time. So if this becomes too much of a bother I will be withdrawing from the TWL. That will be a pity, as I enjoy the list and I believe that other than Georgs, I have the most "seniority" on the list. Also, I believe that I have been a net contributor. Georgs, I suggest that the list server needs tweaking. IMHO, It is unreasonable to expect people to remember to not use advanced protocols on this list. Maurice
S
scaramouche@tvo.org
Thu, Mar 16, 2000 6:54 AM
All,
anything but
(whatever
Just for your info: I'm a plain MacHead, my system only reads ASCII
text and your message came across as clear as if I had typed it on my
own keyboard. Methinks the way you're transmitting is near perfect.
It works well - don't futz with it!  And don't be sorry(for what).
Ciao - George of Scaramouche
nunas@pacific.net.sg writes: >All, >Sorry. The incoming message about Manatee did not look like >anything but >plain text at my end, but I am told that it was in MIME protocol >(whatever >that is!). I have been informed that my reply was full of mime junk. Just for your info: I'm a plain MacHead, my system only reads ASCII text and your message came across as clear as if I had typed it on my own keyboard. Methinks the way you're transmitting is near perfect. It works well - don't futz with it! And don't be sorry(for what). Ciao - George of Scaramouche
