View all threadsHello, thanks for your comments!
I'm very sure I've saved the correct complex data in a .txt file. the complex data use "float32" format, each complex data has 64bits. I did a lot of similar experiment with single antenna mode, so I'm sure the file data is correct.
How can I specify the subdev spec accordingly (A:0 B:0), just add "(A:0 B:0)" following the "Mb0: Subdev Spec"?
What does "L" & "S" mean exactly?
Wu Haoyang
------------------ Original ------------------
Date: Thu, Nov 27, 2014 06:46 PM
To: "usrp-users"usrp-users@lists.ettus.com;
Subject: Re: [USRP-users]回复: Can USRP X300 support 2*2 MIMO
A couple of comments:
On 11/27/2014 04:05 AM, WuHaoyang via USRP-users wrote:
version information:
UHD version: 003.007.000
This is our flowgraph, Two "File Sources" include different time domain
waveforms that generated by ourselves. We try to send different signal
with two TX antennas simultaneously.
To reiterate, please make sure the file data is correct.
Following picture is the configuration of USRP Sink module.
when this test case is executed, we can not see the correct wave in RX
end. It seems that only the signal in Channel0 has been send out.(we use
single RX antenna, not MIMO mode, to receive and save the TX wave, and
print the waveform using MATLAB).
The following picture shows the front panel of X300,
We can see the LED behave like this:
TX/RX: Red
REF: Green
PPS: Green, twinkle
LINK: sometimes Red, sometimes Green
These are fine.
Also we can see a lot of characters "L" and "S" in GNU Radio control panel.
These are not good. I wonder if the MIMO setup is too fast... Is there a
chance you could try running GNU Radio master branch?
Cheers,
M
USRP-users mailing list
USRP-users@lists.ettus.com
吴浩洋 北京大学
高能效计算与应用中心
2013级 计算机系 博士
电话:+86 15210831011
Haoyang Wu
PhD Candidate , Center for Energy-Efficient Computing and Applications(CECA)
School of EECS, Peking University
TEL:+86 15210831011
Just use:
A:0 B:0
In the subdev spec.
L = Late packet. The packet arrived with a time-spec on it, but that
time had already come-and-gone when the packet arrived at the USRP
S = Sequence error. usually because the network interface is dropping
packets
Are you doing this on a VM, rather than a naked hardware machine?
Wu Haoyang
*Date: * Thu, Nov 27, 2014 06:46 PM
*To: * "usrp-users"usrp-users@lists.ettus.com;
Subject: * Re: [USRP-users]??: Can USRP X300 support 22 MIMO
TX/RX: Red
REF: Green
PPS: Green, twinkle
These are fine.
panel.
Cheers,
M
2013? ???? ??
??:+86 15210831011
Haoyang Wu
Applications(CECA)
TEL:+86 15210831011
