time-nuts@lists.febo.com
Re: [time-nuts] John Vig elected President of IEEE
S
SAIDJACK@aol.com
Tue, Dec 11, 2007 4:02 AM
In a message dated 12/10/2007 13:16:38 Pacific Standard Time,
tractorb@ihug.co.nz writes:
There's also this (earlier?) similar HTML paper available  -
different coverage re quartz oscs etc. Might be an earlier version  of
the ppt  presentation.
DaveB,  NZ
Hi Dave,
http://www.ecliptek.com/tech/Vig-tutorial_8.5.1.2_files/frame.htm
(http://www.ecliptek.com/tech/Vig-tutorial_8.5.1.2_files/frame.htm)
this is the one I have been reading, impossible to print with IE6.
Same file is on the IEEE site as well.
Thanks everyone for the help!
bye,
Said
**************************************See AOL's top rated recipes
(http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004)
In a message dated 12/10/2007 13:16:38 Pacific Standard Time, tractorb@ihug.co.nz writes: >There's also this (earlier?) similar HTML paper available - >different coverage re quartz oscs etc. Might be an earlier version of >the ppt presentation. >http://www.ieee-uffc.org/freqcontrol/quartz/vig/vigtoc.htm >DaveB, NZ Hi Dave, _http://www.ecliptek.com/tech/Vig-tutorial_8.5.1.2_files/frame.htm_ (http://www.ecliptek.com/tech/Vig-tutorial_8.5.1.2_files/frame.htm) this is the one I have been reading, impossible to print with IE6. Same file is on the IEEE site as well. Thanks everyone for the help! bye, Said **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004)
X
xaos
Tue, Dec 11, 2007 5:05 AM
Hello Everyone,
I have been running simulations of different parts of the Fury Interface
board.
Here are the results so far.
http://www.darksmile.net/ee/index.html
Your feedback is most welcome.
-George
Hello Everyone, I have been running simulations of different parts of the Fury Interface board. Here are the results so far. http://www.darksmile.net/ee/index.html Your feedback is most welcome. -George
BG
Bruce Griffiths
Tue, Dec 11, 2007 6:32 AM
xaos wrote:
Hello Everyone,
board.
-George
George
In the JFET frequency doubler:
  1. Surely the 50 ohms should be is series with the the voltage source V3
    for the simulation?
  2. Usually a 1:4 impedance ratio step up transformer on the input is
    about right with a similar transformer used to step down the output
    (perhaps an even higher impedance ratio transformer (8:1, 9:1?? may be
    better). The maximum turns ratio depends somewhat on the maximum
    allowable drain voltage swing which in turn is limited by the drain
    supply voltage.
In the voltage offset circuit:
  1. The junction of R9 and R12 should be connected to the offset source
    (+5V??).
I dont understand what the 7812 does in this circuit.
Isolation amplifier looks OK.
Bruce
xaos wrote: > Hello Everyone, > > I have been running simulations of different parts of the Fury Interface > board. > > Here are the results so far. > > http://www.darksmile.net/ee/index.html > > Your feedback is most welcome. > > -George > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. > > George In the JFET frequency doubler: 1) Surely the 50 ohms should be is series with the the voltage source V3 for the simulation? 2) Usually a 1:4 impedance ratio step up transformer on the input is about right with a similar transformer used to step down the output (perhaps an even higher impedance ratio transformer (8:1, 9:1?? may be better). The maximum turns ratio depends somewhat on the maximum allowable drain voltage swing which in turn is limited by the drain supply voltage. In the voltage offset circuit: 1) The junction of R9 and R12 should be connected to the offset source (+5V??). I dont understand what the 7812 does in this circuit. Isolation amplifier looks OK. Bruce
BG
Bruce Griffiths
Tue, Dec 11, 2007 6:57 AM
Bruce Griffiths wrote:
xaos wrote:
Hello Everyone,
board.
-George
George
The LS840 series FET Idss is a little on the low side for this application.
Something equivalent to a matched pair of J310's would be better suited
to this application.
The higher Idss of such JFETs allows a larger amplitude second harmonic
output.
Bruce
Bruce Griffiths wrote: > xaos wrote: > >> Hello Everyone, >> >> I have been running simulations of different parts of the Fury Interface >> board. >> >> Here are the results so far. >> >> http://www.darksmile.net/ee/index.html >> >> Your feedback is most welcome. >> >> -George >> >> _______________________________________________ >> time-nuts mailing list -- time-nuts@febo.com >> To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts >> and follow the instructions there. >> >> >> George The LS840 series FET Idss is a little on the low side for this application. Something equivalent to a matched pair of J310's would be better suited to this application. The higher Idss of such JFETs allows a larger amplitude second harmonic output. Bruce
BG
Bruce Griffiths
Tue, Dec 11, 2007 11:09 AM
xaos wrote:
Hello Everyone,
board.
-George
George
The Fury EFC output range is [0, +5V]
The 10811A, 10544A have an EFC range of [-5V, +5V]
other OCXOs may have an EFC input range of [-10V ,0V], [0,+10V], [-10V,
+10V] or even [+2V, +8V] etc.
If the  circuit is changed so that R1 = R10 = 20K then
Range
[-10V, 0V]  U3A +ve input = 0 V.
[-5V, +5V]  U3A +ve input = +2.5V.
[0V, +10V]  U3A +ve input = +5V.
for a [-10V, +10V] range then R1=R10= 40K, U3A +ve input = +5V.
To check correct operation vary the Fury EFC output from 0 to 5V with
the desired offset at U3 +ve input.
Bruce
xaos wrote: > Hello Everyone, > > I have been running simulations of different parts of the Fury Interface > board. > > Here are the results so far. > > http://www.darksmile.net/ee/index.html > > Your feedback is most welcome. > > -George > > George The Fury EFC output range is [0, +5V] The 10811A, 10544A have an EFC range of [-5V, +5V] other OCXOs may have an EFC input range of [-10V ,0V], [0,+10V], [-10V, +10V] or even [+2V, +8V] etc. If the circuit is changed so that R1 = R10 = 20K then Range [-10V, 0V] U3A +ve input = 0 V. [-5V, +5V] U3A +ve input = +2.5V. [0V, +10V] U3A +ve input = +5V. for a [-10V, +10V] range then R1=R10= 40K, U3A +ve input = +5V. To check correct operation vary the Fury EFC output from 0 to 5V with the desired offset at U3 +ve input. Bruce
BG
Bruce Griffiths
Tue, Dec 11, 2007 11:32 AM
xaos wrote:
Hello Everyone,
board.
-George
George
A more versatile EFC circuit that allows independent adjustment of EFC
span and offset is possible if an additional opamp is used.
A 2x differential amplifier translates the Fury EFC output to either
{-10V, 0V] or [0V, +10V] depending on its input connections,  a second
opamp inverts a  +5Vreference to produce a -5V source offset source, and
a third opamp configured as an inverting opamp scales the EFC range and
adds it to the offset to produce the required EFC range to suit the OCXO
in use. An OCXO  EFC range anywhere between -10V and + 10V can be
accommodated by selecting a couple of resistors  combined with a set of
jumpers.
If you want the circuit schematic I can produce it by around 1300 UTC
tomorrow.
Bruce
xaos wrote: > Hello Everyone, > > I have been running simulations of different parts of the Fury Interface > board. > > Here are the results so far. > > http://www.darksmile.net/ee/index.html > > Your feedback is most welcome. > > -George > > George A more versatile EFC circuit that allows independent adjustment of EFC span and offset is possible if an additional opamp is used. A 2x differential amplifier translates the Fury EFC output to either {-10V, 0V] or [0V, +10V] depending on its input connections, a second opamp inverts a +5Vreference to produce a -5V source offset source, and a third opamp configured as an inverting opamp scales the EFC range and adds it to the offset to produce the required EFC range to suit the OCXO in use. An OCXO EFC range anywhere between -10V and + 10V can be accommodated by selecting a couple of resistors combined with a set of jumpers. If you want the circuit schematic I can produce it by around 1300 UTC tomorrow. Bruce
X
xaos
Tue, Dec 11, 2007 11:54 AM
George
    for the simulation?
Correct. I did a cut and paste "without rotate" there.
  1. Usually a 1:4 impedance ratio step up transformer on the input is
    supply voltage.
I will re-run with the this in mind and will repost.
    (+5V??).
This is what I didn't get about the original circuit.  I was scratching
my head as to the purpose of a variable R9 when
the only value that made sense was when it was set to the "0" position.
It was there in the original circuit so I modeled accordingly. Actually
I ran some simulations with PS voltage variation
to see the effect as well. In that case I removed the 7812.
Bruce
This is a very nice design and the AC analysis shows a bandpass around
10 MHz with 20 MHz BW.
The only issue I see there is that it needs 50 parts of 6 different values.
This might be difficult to implement on a small board and would be prone
to error for people trying to
assemble their own board.
The way I see the final product is a bare board and possibly a kit. It
has to be easy to assemble and minimize
errors.
Actually, I was looking at the isolation amplifier provided in the C.M.
Felton Paper:
http://www.darksmile.net/ee/Superimposing_Low-Phase-Noise_Low-Drift_Instrumentation_Techniques_On_RF_Design.pdf
It is relatively simple and would use similar devices as the Frequency
doubler.
I will upload more info as I compile it.
George
Bruce Griffiths wrote: > George > > In the JFET frequency doubler: > 1) Surely the 50 ohms should be is series with the the voltage source V3 > for the simulation? > Correct. I did a cut and paste "without rotate" there. > 2) Usually a 1:4 impedance ratio step up transformer on the input is > about right with a similar transformer used to step down the output > (perhaps an even higher impedance ratio transformer (8:1, 9:1?? may be > better). The maximum turns ratio depends somewhat on the maximum > allowable drain voltage swing which in turn is limited by the drain > supply voltage. > I will re-run with the this in mind and will repost. > In the voltage offset circuit: > > 1) The junction of R9 and R12 should be connected to the offset source > (+5V??). > This is what I didn't get about the original circuit. I was scratching my head as to the purpose of a variable R9 when the only value that made sense was when it was set to the "0" position. > I dont understand what the 7812 does in this circuit. > It was there in the original circuit so I modeled accordingly. Actually I ran some simulations with PS voltage variation to see the effect as well. In that case I removed the 7812. > Isolation amplifier looks OK. > > Bruce > This is a very nice design and the AC analysis shows a bandpass around 10 MHz with 20 MHz BW. The only issue I see there is that it needs 50 parts of 6 different values. This might be difficult to implement on a small board and would be prone to error for people trying to assemble their own board. The way I see the final product is a bare board and possibly a kit. It has to be easy to assemble and minimize errors. Actually, I was looking at the isolation amplifier provided in the C.M. Felton Paper: http://www.darksmile.net/ee/Superimposing_Low-Phase-Noise_Low-Drift_Instrumentation_Techniques_On_RF_Design.pdf It is relatively simple and would use similar devices as the Frequency doubler. I will upload more info as I compile it. George
BG
Bruce Griffiths
Tue, Dec 11, 2007 10:10 PM
George
    for the simulation?
    supply voltage.
The idea is that the FETs are not operated in the square law region but
are actually switched off alternately so that the combined drain current
waveform is a rectified sinewave with a small dc offset.
With a well balanced circuit the odd harmonic amplitudes (including the
fundamental) at the output will be small with the 20MHz 4th harmonic of
the fundamental being the largest component.
Achieving low distortion isnt the aim, but achieving low phase noise is.
Any residual harmonics and subharmonics can be removed with tuned
circuit traps (dont use a high Q bandpass filter as it will inevitably
have a high phase shift tempco and may add flicker phase noise depending
on the components used). A relatively broadband low pass filter
contributes little phase shift (and associated flicker phase noise as
well as little phase shift tempco) at 10MHz as do a series of relatively
high Q LC traps. High performance is rarely achieved by the
simplest/obvious solution.
If you have difficulty finding suitable JFETs a high impedance bipolar
junction transistor (BJT) implementation is also possible however
biasing is a little trickier and requires a couple of extra BJTs to
ensure reasonable thermal stability of the bias currents.
    (+5V??).
Bruce
errors.
Felton Paper:
doubler.
The trouble with this design is that it has a low input impedance and
thus is unsuitable for OCXOs that require a high impedance load (eg 10544A).
Its gain isnt adjustable and its difficult to obtain suitable dual JFETS
(you would have to use a couple of J310's to achieve similar performance
since U431 isnt readily obtainable, the LS840 is definitely unsuitable
as its minimum Idss isnt high enough ), it also has relatively low
reverse isolation. Simplicity isnt the key to high performance.
George
xaos wrote: > Bruce Griffiths wrote: > >> George >> >> In the JFET frequency doubler: >> 1) Surely the 50 ohms should be is series with the the voltage source V3 >> for the simulation? >> >> > Correct. I did a cut and paste "without rotate" there. > >> 2) Usually a 1:4 impedance ratio step up transformer on the input is >> about right with a similar transformer used to step down the output >> (perhaps an even higher impedance ratio transformer (8:1, 9:1?? may be >> better). The maximum turns ratio depends somewhat on the maximum >> allowable drain voltage swing which in turn is limited by the drain >> supply voltage. >> >> > I will re-run with the this in mind and will repost. > The idea is that the FETs are not operated in the square law region but are actually switched off alternately so that the combined drain current waveform is a rectified sinewave with a small dc offset. With a well balanced circuit the odd harmonic amplitudes (including the fundamental) at the output will be small with the 20MHz 4th harmonic of the fundamental being the largest component. Achieving low distortion isnt the aim, but achieving low phase noise is. Any residual harmonics and subharmonics can be removed with tuned circuit traps (dont use a high Q bandpass filter as it will inevitably have a high phase shift tempco and may add flicker phase noise depending on the components used). A relatively broadband low pass filter contributes little phase shift (and associated flicker phase noise as well as little phase shift tempco) at 10MHz as do a series of relatively high Q LC traps. High performance is rarely achieved by the simplest/obvious solution. If you have difficulty finding suitable JFETs a high impedance bipolar junction transistor (BJT) implementation is also possible however biasing is a little trickier and requires a couple of extra BJTs to ensure reasonable thermal stability of the bias currents. >> In the voltage offset circuit: >> >> 1) The junction of R9 and R12 should be connected to the offset source >> (+5V??). >> >> > This is what I didn't get about the original circuit. I was scratching > my head as to the purpose of a variable R9 when > the only value that made sense was when it was set to the "0" position. > > >> I dont understand what the 7812 does in this circuit. >> >> > It was there in the original circuit so I modeled accordingly. Actually > I ran some simulations with PS voltage variation > to see the effect as well. In that case I removed the 7812. > >> Isolation amplifier looks OK. >> >> Bruce >> >> > This is a very nice design and the AC analysis shows a bandpass around > 10 MHz with 20 MHz BW. > > The only issue I see there is that it needs 50 parts of 6 different values. > > This might be difficult to implement on a small board and would be prone > to error for people trying to > assemble their own board. > > The way I see the final product is a bare board and possibly a kit. It > has to be easy to assemble and minimize > errors. > > Actually, I was looking at the isolation amplifier provided in the C.M. > Felton Paper: > > http://www.darksmile.net/ee/Superimposing_Low-Phase-Noise_Low-Drift_Instrumentation_Techniques_On_RF_Design.pdf > > It is relatively simple and would use similar devices as the Frequency > doubler. > The trouble with this design is that it has a low input impedance and thus is unsuitable for OCXOs that require a high impedance load (eg 10544A). Its gain isnt adjustable and its difficult to obtain suitable dual JFETS (you would have to use a couple of J310's to achieve similar performance since U431 isnt readily obtainable, the LS840 is definitely unsuitable as its minimum Idss isnt high enough ), it also has relatively low reverse isolation. Simplicity isnt the key to high performance. > I will upload more info as I compile it. > > George >
BG
Bruce Griffiths
Tue, Dec 11, 2007 11:42 PM
George
The circuit schematic for a BJT version of the JFET frequency is attached.
The biasing is a little more complex as it is necessary set each
frequency doubler BJT collector current at about 1mA or so to maximise
conversion gain.
The input impedance  is also around 50 ohms.
Have also minimised the number of different component values used.
Other transistors may be substituted but some care is required as the
reverse voltage across the base emitter junction is about 2V for a
+13dBm input.
Some filtering of the output waveform is required.
The intended output load is 50 ohms.
The 200 ohm emitter series resistors together with the transformed
source impedance ensure that there is sufficient degeneration to keep
the phase noise low.
Obtaining suitable transistors for this circuit should be much easier
than obtaining suitable JFETS for the JFET doubler.
Whilst a diode doubler (at higher frequencies this may be the only
sensible option) could be used it would need both an input amplifier and
an output amplifier.
Bruce
George The circuit schematic for a BJT version of the JFET frequency is attached. The biasing is a little more complex as it is necessary set each frequency doubler BJT collector current at about 1mA or so to maximise conversion gain. The input impedance is also around 50 ohms. Have also minimised the number of different component values used. Other transistors may be substituted but some care is required as the reverse voltage across the base emitter junction is about 2V for a +13dBm input. Some filtering of the output waveform is required. The intended output load is 50 ohms. The 200 ohm emitter series resistors together with the transformed source impedance ensure that there is sufficient degeneration to keep the phase noise low. Obtaining suitable transistors for this circuit should be much easier than obtaining suitable JFETS for the JFET doubler. Whilst a diode doubler (at higher frequencies this may be the only sensible option) could be used it would need both an input amplifier and an output amplifier. Bruce
BG
Bruce Griffiths
Wed, Dec 12, 2007 1:03 AM
George
The schematic for a more versatile EFC translator circuit is attached.
Any EFC range in the -10V to +10V range can be accomodated.
Even greater EFC ranges are possible by using a suitable opamp for U103
with appropriate power supplies.
The messy details of power supply bypassing etc are left as an exercise
together with calculating the necessary values for R107, R108, R109 for
OCXO EFC ranges other than [-5V, +5V].
Hint: select R107 to set the EFC span and either R108 or R109  to set
the EFC offset.
Bruce
George The schematic for a more versatile EFC translator circuit is attached. Any EFC range in the -10V to +10V range can be accomodated. Even greater EFC ranges are possible by using a suitable opamp for U103 with appropriate power supplies. The messy details of power supply bypassing etc are left as an exercise together with calculating the necessary values for R107, R108, R109 for OCXO EFC ranges other than [-5V, +5V]. Hint: select R107 to set the EFC span and either R108 or R109 to set the EFC offset. Bruce
