View all threadsHi all,
I have been trying to connect to OpenbBTS network from mobile phones.
When I edit the preferred network list on mobile and search the available
networks in manual mode. But I am not able to register to it. An HTC mobile
gave an error of "Your SIM card doesn't allow connecting to this network"
and a Celkon mobile says "Failed to register" when tried to register to the
Test network. I am using MCC/MNC = 001/01 and 900 GSM band. I am using a
UNINOR local SIM, which does not have coverage at the place where i am
experimenting.
Can anyone please suggest me what are the problems that could be with my
phone or SIM card? I am also trying to employ the external clock of 10MHz
but have not yet. Please suggest me what to do. I am stuck up here.. :(
Thank you,
Madhuri.
On Tue, Jun 7, 2011 at 10:39 AM, madhuri gontala mads3009@gmail.com wrote:
Hi all,
This sounds like a phone locking issue. Phone messages can be
deceiving, however, so it may still be something with the BTS.
experimenting.
Please post a global log file. NOTICE level is fine. My guess is that
the BTS isn't receiving messages.
If your phone sees the network, I wouldn't worry about the 10 MHz
reference. It may help with reliability, but if your phone never
connects, then it's probably not a clock issue.
Thomas
Hi!
why don't you try using a different MMC/MNC combination, it could help if it is a SIM problem... I would suggest using a code of Uninor (there are several 405/819, 405/820, 405/821, 405/822). Let us know if it works and good luck.
Un saludo / Best Regards
Asier Alonso Muñoz
Investigador / Researcher
TECNALIA-Telecom
Tecnalia, Parque Tecnológico, Edificio 202. E-48170 Zamudio (Bizkaia) (SPAIN)
Tel: +34 94 600 22 66 ext: 229, Fax: +34 94 600 22 99
asier.alonso@tecnalia.com, www.tecnalia.com
**************** AVISO LEGAL **************** DISCLAIMER ****************
Este mensaje es personal y confidencial y su uso no autorizado está prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo, sin reenviarlo ni conservarlo.
This message is personal and confidential, unauthorised use is legally prohibited. If you are not the intended recipient, delete it without resending or backing it.
De: usrp-users-bounces@lists.ettus.com [usrp-users-bounces@lists.ettus.com] en nombre de Thomas Tsou [ttsou@vt.edu]
Enviado el: martes, 07 de junio de 2011 20:48
Para: madhuri gontala
CC: USRP-users@lists.ettus.com
Asunto: Re: [USRP-users] OpenBTS - phones and SIM cards
Hi all,
experimenting.
Thomas
USRP-users mailing list
Hi,
This actually should go to OpenBTS mailing list - please post there next time.
I suggest you to check your Asterisk sip.conf - it will reject
connections if you haven't added IMSIs of your phones there.
PS We should probably add a FAQ entry with all things to check in this
popular case.
On Tue, Jun 7, 2011 at 21:39, madhuri gontala mads3009@gmail.com wrote:
Hi all,
experimenting.
Thank you,
Madhuri.
Regards,
Alexander Chemeris.
