trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
Marine Trader Window Frames
Jan Ölander
Tue, Nov 27, 2012 1:01 PM
Greetings all,
I have an old Marine Trader Europa from 1986. As with all older boats
it needs some maintenance, and now I have to do something with the teak
window frames. Does anybody of you know how they were treaded from the
beginning? And do you have a good suggestion how to treat them and
example of products to use?
Jan Olander
Stockholm, Sweden
Marine Trader 36 Europa, Easy Livin?
Greetings all, I have an old Marine Trader Europa from 1986. As with all older boats it needs some maintenance, and now I have to do something with the teak window frames. Does anybody of you know how they were treaded from the beginning? And do you have a good suggestion how to treat them and example of products to use? Jan Olander Stockholm, Sweden Marine Trader 36 Europa, Easy Livin?
RT
Richard Tomkinson
Thu, Nov 29, 2012 8:03 PM
Look in the archive for good advice in removing /repairing. Actually not
that big a job if you don't break the frames on removal.
As to refinishing, consider sealing and painting to reduce the annual
maintenance load.
My experience is that amazingly, the biggest danger to windows is the small
amount of dirt that accumulates in the smallest crevices. This feeds very
small insects and over freeze/thaw conditions allows the dirt to slowly
detach even the best adhesives.
Richard
----- Original Message -----
To: trawlers@lists.trawlering.com
Sent: Tuesday, November 27, 2012 5:01 AM
Subject: T&T: Marine Trader Window Frames
Greetings all,
Jan Olander
Stockholm, Sweden
http://lists.trawlering.com/mailman/listinfo/trawlers_lists.trawlering.com
To unsubscribe or modify your subscription options (get password, change
email address, etc) go to:
Trawlers & Trawlering and T&T are trademarks of Water World
Productions. Unauthorized use is prohibited.
Look in the archive for good advice in removing /repairing. Actually not that big a job if you don't break the frames on removal. As to refinishing, consider sealing and painting to reduce the annual maintenance load. My experience is that amazingly, the biggest danger to windows is the small amount of dirt that accumulates in the smallest crevices. This feeds very small insects and over freeze/thaw conditions allows the dirt to slowly detach even the best adhesives. Richard ----- Original Message ----- From: "Jan Ölander" <jan.olander@telia.com> To: <trawlers@lists.trawlering.com> Sent: Tuesday, November 27, 2012 5:01 AM Subject: T&T: Marine Trader Window Frames > Greetings all, > I have an old Marine Trader Europa from 1986. As with all older boats > it needs some maintenance, and now I have to do something with the teak > window frames. Does anybody of you know how they were treaded from the > beginning? And do you have a good suggestion how to treat them and > example of products to use? > > Jan Olander > Stockholm, Sweden > Marine Trader 36 Europa, Easy Livin? > > _______________________________________________ > http://lists.trawlering.com/mailman/listinfo/trawlers_lists.trawlering.com > > To unsubscribe or modify your subscription options (get password, change > email address, etc) go to: > http://lists.trawlering.com/mailman/listinfo/trawlers_lists.trawlering.com > Trawlers & Trawlering and T&T are trademarks of Water World > Productions. Unauthorized use is prohibited.
