great-loop@lists.trawlering.com
Cruising America's Great Loop and other inland routes
Boat Name Removal
KT
Ken Tucknott
Thu, Apr 16, 2009 9:31 PM
Hello All,
I need to remove the old name from the boat to make room for the new name.
Black paint on white fiberglass gelcote.  It seems to me that I read some
where that using Easy Off oven cleaner works best, but it needs to be
unscented variety.  Do I have the facts straight, and is there anything
special I should know about, about doing this project.  Any & all suggestions
will be greatly appreciated.
Ken Tucknott
Trista Gray
Hello All, I need to remove the old name from the boat to make room for the new name. Black paint on white fiberglass gelcote. It seems to me that I read some where that using Easy Off oven cleaner works best, but it needs to be unscented variety. Do I have the facts straight, and is there anything special I should know about, about doing this project. Any & all suggestions will be greatly appreciated. Ken Tucknott Trista Gray
RY
Ralph Yost (home)
Thu, Apr 16, 2009 10:48 PM
Ken;
Use Acetone and a plain scotch bright pad. Get heavy rubber gloves. Wipe
with Acetone then rub a section at a time. See pics attached.
Lots of hard work.
I wouldnt use OVEN OFF because you may harm the finish.
R.
----- Original Message -----
To: "Great Loop" great-loop@lists.samurai.com
Sent: Thursday, April 16, 2009 5:31 PM
Subject: GL: Boat Name Removal
Hello All,
suggestions
Ken Tucknott
Trista Gray
http://lists.samurai.com/mailman/listinfo/great-loop
To modify your Great-Loop subscription options (change email address,
unsubscribe, etc.) go to:
http://lists.samurai.com/mailman/options/great-loop
[demime 1.01d removed an attachment of type image/jpeg which had a name of IMG_6764.JPG]
[demime 1.01d removed an attachment of type image/jpeg which had a name of IMG_6765.JPG]
Ken; Use Acetone and a plain scotch bright pad. Get heavy rubber gloves. Wipe with Acetone then rub a section at a time. See pics attached. Lots of hard work. I wouldnt use OVEN OFF because you may harm the finish. R. ----- Original Message ----- From: "Ken Tucknott" <katuck214@mchsi.com> To: "Great Loop" <great-loop@lists.samurai.com> Sent: Thursday, April 16, 2009 5:31 PM Subject: GL: Boat Name Removal > Hello All, > > I need to remove the old name from the boat to make room for the new name. > Black paint on white fiberglass gelcote. It seems to me that I read some > where that using Easy Off oven cleaner works best, but it needs to be > unscented variety. Do I have the facts straight, and is there anything > special I should know about, about doing this project. Any & all > suggestions > will be greatly appreciated. > > Ken Tucknott > Trista Gray > _______________________________________________ > http://lists.samurai.com/mailman/listinfo/great-loop > > To modify your Great-Loop subscription options (change email address, > unsubscribe, etc.) go to: > http://lists.samurai.com/mailman/options/great-loop [demime 1.01d removed an attachment of type image/jpeg which had a name of IMG_6764.JPG] [demime 1.01d removed an attachment of type image/jpeg which had a name of IMG_6765.JPG]
