I will check those out. Thanks a lot R3gis!
On Tue, Apr 1, 2014 at 2:15 PM, pjsip-request@lists.pjsip.org wrote:
Send pjsip mailing list submissions to
pjsip@lists.pjsip.org
To subscribe or unsubscribe via the World Wide Web, visit
http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
pjsip-owner@lists.pjsip.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of pjsip digest..."
Today's Topics:
1. Re: Build PJSIP 2.2.1 with opus (R?gis Montoya)
Message: 1
Date: Tue, 1 Apr 2014 10:44:59 +0200
To: pjsip list pjsip@lists.pjsip.org
Subject: Re: [pjsip] Build PJSIP 2.2.1 with opus
Message-ID:
CALdtMaVPgqqCsLood41eAS92Fg9y1u6h4Oe9FO+a6951qOomVQ@mail.gmail.com>
Content-Type: text/plain; charset="iso-8859-1"
Hi,
You should update your code to use latest patch available (last change was
made this weekend to fix critical compatibility issue).
The opus format has evolved (in particular RTP payload format). As
consequence the old post sent is pretty outdate.
Instead, use latest versions which is compounded of :
https://code.google.com/p/csipsimple/source/browse/trunk/CSipSimple/jni/csipsimple-wrapper/src/pjsip_opus_sdp_rewriter.c
With this code you'll get opus compliant (RFC6716 + draft
draft-spittka-payload-rtp-opus version 03). It's currently compatible with
jitsi and freeswitch implementation of opus. There is however some known
limitations (for example about ptime), but it's not a problem with others
implementations of the codec.
As the work is mainly done for android on csipsimple there is currently
nothing to build using the pjsip toolchain. However it should be very easy
to build as there is no big dependancies on these plugins (it's just pjsip
Best regards
R?gis
2014-04-01 9:42 GMT+02:00 Vinay vinay.nair@novanet.net:
Hi,
I have been trying to upgrade our iOS project unsuccessfully to PJSIP
2.2.1 with opus 1.1 and openSSL for armv7, armv7s and arm64 for iOS. We
were using PJSIP 2.0 earlier.
First I got an error saying opus.h not found in pjmedia, following which
I
added it manually. But after that I am not able to generate the
libopuscodec-arm-apple-darwin9.a file. The build process does not show
any error but I am unable to generate the required lib.
I have attached the script that I have used to build it. The procedure I
followed was:
- Placed opus in pjsip2.2.1->third_party.
- Used the opus patch found on the forums (attached herewith)
- Built openSSL.
- Ran the build script (attached herewith)
Any help will be greatly appreciated as I have been stuck on this for
quite some while.
Vinay Nair
Visit our blog: http://blog.pjsip.org
pjsip mailing list
