I too did not have any lubrication plates on my transmissions but I just
found one in the spare parts bin.
Mine take 1.7 gallons and are 1991 vintage behind 3208 Cat's
Here's what the plate basically says:
MARINE TRANSMISSION LUBRICANT
OIL SERVICE CLASS - USE SAE-API SERVICE CLASS CD ENGINE OIL
CERTIFIED BY VENDOR TO PASS TC-2 OIL TEST
ALSO APPROVED ARE SAE-API SERVICE CLASS CC ENGINE OIL MIL-L-B AND
TRANSMISSION FLUID TYPE C-3
VISCOSITY - BASE SELECTION ON SUMP TEMPERATURE
STARTUP - 32 DEGREES MINIMUM
RUNNING - 150 -185 DEGREES USE SAE 30
OR - 174 - 210 DEGREES USE SAE 40
Hope that helps
Jim on GB 46 "TWINS" (Anchored on the Tennessee)
Hope that helps
