View all threadsI have been messing with the XG image for my X310 and have run into a
strange issue. First, here is the system setup:
When I updated the firmware of the radio I noted that port 0 was not
showing up as having a link (per ethtool). I changed UHD versions several
times and flashed the radio after each version change. At some point I
walked away for ~ 15 minutes, and when I came back the link was established
and uhd_find_devices was happy. I rebooted and was able to repeat this
process several times. It seems that it takes ~ 10-20 minutes for the link
to show as active in Linux. The radio shows lights on both port 0 and 1,
but only port 1 comes up right away on the NIC.
Any ideas as to why this is happening? It's a real bummer because while
testing my current code, it's easy to get the radio into a bad state that
requires restarting it. Then I get to wait for the link to come up.
Thanks!
-Dave
Dave,
I can’t speak to anything that might be happening because of recent code changes, but I would recommend you doing a quick switch of the cables/ports to see if the problem follows the cable/SFP/Port jut in case it’s a coincidence that you did the firmware update at that time. I’ve had problems with those passive Twin-Ax cables being quirky occasionally, and there were some cheap brands we could never get to work when I originally qualified various SFP’s and Cables.
It’s hard to imagine a firmware problem causing a long delay like this at the physical level, the link negotiation is a largely automatic process between both ends.
-Ian
On Nov 26, 2018, at 3:17 PM, Dave NotTelling via USRP-users usrp-users@lists.ettus.com wrote:
I have been messing with the XG image for my X310 and have run into a strange issue. First, here is the system setup:
Intel X710 dual 10 Gb/s SFP+ NIC
2x SFP+ direct attach copper cables
X310 (revision 4)
2x UBX-160 (both v1 boards)
UHD_3.13.1.HEAD-0-ga0a71d10
Ubuntu 16.04
When I updated the firmware of the radio I noted that port 0 was not showing up as having a link (per ethtool). I changed UHD versions several times and flashed the radio after each version change. At some point I walked away for ~ 15 minutes, and when I came back the link was established and uhd_find_devices was happy. I rebooted and was able to repeat this process several times. It seems that it takes ~ 10-20 minutes for the link to show as active in Linux. The radio shows lights on both port 0 and 1, but only port 1 comes up right away on the NIC.
Any ideas as to why this is happening? It's a real bummer because while testing my current code, it's easy to get the radio into a bad state that requires restarting it. Then I get to wait for the link to come up.
Thanks!
-Dave
USRP-users mailing list
USRP-users@lists.ettus.com
Ian,
I forgot to mention that I did test to see if the cable was at fault.
I swapped the cables and still only got a link on port 1. Using either
cable to either port on the NIC from port 0 on the radio results in no link
for several minutes. The light on the radio port immediately comes on and
blinks, but the X710 doesn't seem to think there is a link.
Thankfully I have another X310 kicking around and was able to verify
that both SFP+ ports work immediately with it. Perhaps something is wrong
with the first X310? I've tried flashing it with both the onboard JTAG
(USB-B connector up front) and the normal uhd_image_loader utility, so I
don't think it's a misconfiguration issue on the radio firmware. Is there
a way to flush the EEPROM without bricking the radio?
Thanks!
-Dave
On Mon, Nov 26, 2018 at 11:13 PM Ian Buckley ianb@ionconcepts.com wrote:
Dave,
between both ends.
-Ian
On Nov 26, 2018, at 3:17 PM, Dave NotTelling via USRP-users <
- Intel X710 dual 10 Gb/s SFP+ NIC
- 2x SFP+ direct attach copper cables
- X310 (revision 4)
- 2x UBX-160 (both v1 boards)
- UHD_3.13.1.HEAD-0-ga0a71d10
- Ubuntu 16.04
Thanks!
-Dave
Ian,
I take that back. I didn't realize the other X310 was on the HG
image. Once I updated it to the XG image port 0 stopped working properly.
No matter what combination of cable arrangements I use, port 0 just does
not want to come up even on the spare X310.
I don't have another system that I can test on at the moment, but I
see that as the next step to troubleshooting. Is there a known gold
standard version that you've had success using the XG image with?
Thanks!
-Dave
On Tue, Nov 27, 2018 at 8:47 AM Dave NotTelling dmp250net@gmail.com wrote:
Ian,
fault. I swapped the cables and still only got a link on port 1. Using
either cable to either port on the NIC from port 0 on the radio results in
no link for several minutes. The light on the radio port immediately comes
on and blinks, but the X710 doesn't seem to think there is a link.
Thanks!
-Dave
Dave,
between both ends.
-Ian
- X310 (revision 4)
- Ubuntu 16.04
Thanks!
-Dave
Dave,
I might be miss-reading what you are telling me here but…..are you saying that an “HG” image brought up both ports over a 10G Twinax passive cable to the X710, but not the “XG” image? Is it possible either you or someone at Ettus has got HG and XG switched in the latest release? Can you use ethtool or similar on the host to see what speeds the links are running at? I confess I have never thought to try deliberatly bringing 1G up over what I always regarded as a 10G only cable.
(I’ve not personally qualified an XG image since UHD3.9 so no recent Golden XG version to offer you, I use HG images in my day to day.)
-Ian
On Nov 27, 2018, at 6:22 AM, Dave NotTelling dmp250net@gmail.com wrote:
Ian,
I take that back. I didn't realize the other X310 was on the HG image. Once I updated it to the XG image port 0 stopped working properly. No matter what combination of cable arrangements I use, port 0 just does not want to come up even on the spare X310.
I don't have another system that I can test on at the moment, but I see that as the next step to troubleshooting. Is there a known gold standard version that you've had success using the XG image with?
Thanks!
-Dave
On Tue, Nov 27, 2018 at 8:47 AM Dave NotTelling <dmp250net@gmail.com mailto:dmp250net@gmail.com> wrote:
Ian,
I forgot to mention that I did test to see if the cable was at fault. I swapped the cables and still only got a link on port 1. Using either cable to either port on the NIC from port 0 on the radio results in no link for several minutes. The light on the radio port immediately comes on and blinks, but the X710 doesn't seem to think there is a link.
Thankfully I have another X310 kicking around and was able to verify that both SFP+ ports work immediately with it. Perhaps something is wrong with the first X310? I've tried flashing it with both the onboard JTAG (USB-B connector up front) and the normal uhd_image_loader utility, so I don't think it's a misconfiguration issue on the radio firmware. Is there a way to flush the EEPROM without bricking the radio?
Thanks!
-Dave
On Mon, Nov 26, 2018 at 11:13 PM Ian Buckley <ianb@ionconcepts.com mailto:ianb@ionconcepts.com> wrote:
Dave,
-Ian
On Nov 26, 2018, at 3:17 PM, Dave NotTelling via USRP-users <usrp-users@lists.ettus.com mailto:usrp-users@lists.ettus.com> wrote:
X310 (revision 4)
Ubuntu 16.04
Thanks!
-Dave
USRP-users@lists.ettus.com mailto:USRP-users@lists.ettus.com
http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com
