The upper winch cable will go along the top of the boom out to the free
(aft) end of the boom, turn around a block and terminate at the top of the
mast. That will be the topping lift.
I think most topping lifts are run from the winch to the top of the mast,
around a block, to the free end of the boom. This configuration puts less
compression load on the boom.
The 12-volts needed to run this will come from the house batteries via a
suitable wire (probably #4 ... but I'll measure the current and use the
right size for two winches running at the same time).
Both winches don't have to be run at the same time. A winch selector
switch/relay would prevent this.
Joe
Joseph J. Blass
Oak Ridge, Tennessee
jjblass@ispchannel.com
Maurice,
Joe
Joseph J. Blass
<jjblass@ispchannel.com>
