HR
Hypnotist Romane's Mailing List
Thu, Mar 7, 2019 4:16 AM
What is in this email?
- Stop Smoking Seminars in Edmonton
- Instructions for success using hypnosis
Stop Smoking Seminar:
EDMONTON, AB
Sun. Mar. 31st at 2 PM
Fantasyland Hotel
17700 87 Ave NW
Doors open 45 minutes before the seminar.
Save BIG on advance tickets at:
https://www.ticketweb.ca/romane
https://mailtrack.io/trace/link/7927d77600acbb4349dbcd6f285ad1f41c10067f?url=https%3A%2F%2Fwww.ticketweb.ca%2Fromane&userId=2047633&signature=b151311fc8f4edc0
Or Charge By Phone: 1-888-222-6608
IMPORTANT! CLOSING TIMES OF DISCOUNTED ADVANCE TICKETS:
- Discount advance ticket sales close at 7 pm the day before the seminar.
(Unless sold out sooner) Purchase your tickets now to save and be assured a
seat!*
SAVE A LIFE – TELL YOUR FRIENDS AND FAMILY!
All advance tickets are only $85 plus Ticketweb fee and GST or $125 at
door, if available.
This may be the best opportunity anyone has to stop smoking. Simply pay
attention to Vance Romane’s voice and follow his easy
instructions. The seminar is so simple a child can follow it.
*NOTE: This may be the final stop smoking seminar for 2019. Be sure to
tell friends and relatives who need this seminar. If unable to attend,
remember that the recordings alone are usually successful for stopping
smoking, losing weight and many other challenges. Visit
https://www.vanceromane.com/products.html
https://mailtrack.io/trace/link/0d2245964b89cb1b756c81f90e9dd5b77dcb01c6?url=https%3A%2F%2Fwww.vanceromane.com%2Fproducts.html&userId=2047633&signature=915706b7800f9697
for a catalog of Romane’s hypnosis recordings. *
*INSTRUCTIONS TO MAXIMIZE SUCCESS WITH ROMANE HYPNOSIS RECORDINGS *
- If you have more than one recording, begin with the one dealing with
the simpler problem. In this manner you will build-up your confidence to
overcome a more complex problem.
- Play the recordings all through once, so you know what is on the
recordings.
- If your program is a set of 2 or more recordings, pick out one
hypnosis session that you like best and play that hypnosis session each
night before going to bed for 7-30 days. Repetition brings permanent
results!
- After success, occasionally listen to the recordings again. You will
enjoy the renewed relaxation and reinforcement.
YOUR INNER AND OUTER MIND
- Hypnosis greatly ramps up motivation and will power.
- Play one hypnosis session once per day, preferably in the evening
(after lying down and ready for sleep). At this time, you will saturate
your INNER SUBCONSCIOUS MIND. Instructions “spill over and echo” into your
subconscious mind as you sleep.
- Occasionally, you should play the recording in the daytime. Sit up
in a straight back chair and keep alert by taking notes. In this way, you
will saturate your OUTER CONSCIOUS MIND. When the inner and outer minds
are focused in the same direction, you will have self-discipline, peace of
mind and more easily attain your goals.
BEFORE YOU BEGIN
- Wear loose, relaxing, comfortable clothing.
- Play the recording in a quiet room. Unplug your telephone and place
a “DO NOT DISTURB – SLEEPING” sign on your door (if necessary).
- Close your window curtains for more darkness and better
concentration. (Or use a sleep mask from Dollarama)
- Set room temperature comfortably warm.
- Remove glasses or contact lenses.
- For greater concentration, you can listen to the recording with
headphones. Distracting sounds are eliminated.
- Initially, play the recording long enough to set the volume level:
loud enough to hear, yet quiet enough to relax.
- While the recording is playing, you may fall asleep. In this case,
daytime playing, not lying down, is best. Hypnosis is a focused mind on
Romane’s voice, not sleep! You are super aware, superconscious, not
unconscious.
ROMANE RECORDINGS AND YOU
- The recordings are designed to help you live a happier life…to help
you reach your goals. The crucial attitude to assume when listening is to
simply follow instructions, relax and pay attention to Romane’s voice.
- These recordings are safe, beneficial, and easy to use. You will
hear EVERYTHING that is said to you. All hypnotic
instructions/directions/suggestions are positive and designed for health,
success and happiness.
LASTING ADVANTAGES
- Romane recordings teach you HOW TO CONCENTRATE YOUR MIND. All in
life is achieved through CONCENTRATION. What you want in life can become
an actuality if you BELIEVE it to be already true. Hypnotic instructions
programmed into the subconscious mind set up a process to achieve that same
success.
- Recordings are best used REGULARLY. REPETITION and REINFORCEMENT are
the keys to change.
- After your challenge is part of the past (and therefore CONQUERED),
you should occasionally run through the recordings again. The effect is a
SUPER-CONCENTRATION of the instructions within your inner and outer minds –
over-learning is permanent change*. *
WORDS OF CAUTION
- Do not play ROMANE RECORDINGS while driving an automobile or while
operating moving machinery.
- Romane recordings are not a substitute for other practitioners: For
medical problems or serious emotional problems, consult your physician,
psychiatrist, psychologist or counselor.
- Refrain from eating a heavy meal before using a recording (on the
other hand, don’t be hungry either).
- Do not consume alcohol, tranquilizers, or mind-altering drugs before
using recordings. You want a focused mind.
- Avoid concentrating too INTENSELY; listen naturally to the recorded
voice. By ‘trying too hard’, you could create tension – a tension which
prevents concentration.
- Most people are not aware they are in hypnosis. Don’t ‘analyze’ or
‘wonder what is happening’. Don’t question ‘whether it will work’. Just
relax and listen. Focus on your goal as if it is already accomplished – a
done deal! The changes which occur in your life will serve as proof of the
benefit of these recordings.
All the best in Health,
M. Vance Romane
M.V.P. Ltd. (Romane Seminars)
Box 75177, RPO White Rock
Surrey, BC
V4A 0B1
Phone: 604 538 1111 or 1 800 665 4656
Fax: 604 538 8477
vanceromane.com
https://mailtrack.io/trace/link/1738c18899a0b2d8cd5849e93edb8cd28a1401fc?url=http%3A%2F%2Fvanceromane.com%2F&userId=2047633&signature=5423d27e799714d4
romane.ca
https://mailtrack.io/trace/link/c5fefff2c18ce3fea190271f83d3f28d1516cf30?url=http%3A%2F%2Fromane.ca%2F&userId=2047633&signature=37f4773393c7e378
Copyright 2019 M.V.P. Ltd. – Romane
[image: Mailtrack]
https://mailtrack.io/trace/link/70d44fa9fb5b08c5987207a386720c774ea9ec1d?url=https%3A%2F%2Fmailtrack.io%3Futm_source%3Dgmail%26utm_medium%3Dsignature%26utm_campaign%3Dsignaturevirality5%26&userId=2047633&signature=bbd4a03d50404f20
Sender
notified by
Mailtrack
https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&
03/06/19,
8:15:57 PM
1. Stop Smoking Seminars in Edmonton
2. Instructions for success using hypnosis
*Stop Smoking Seminar:*
*EDMONTON, AB*
Fantasyland Hotel
17700 87 Ave NW
*Doors open 45 minutes before the seminar.*
*Save BIG on advance tickets at:*
*https://www.ticketweb.ca/romane
<https://mailtrack.io/trace/link/7927d77600acbb4349dbcd6f285ad1f41c10067f?url=https%3A%2F%2Fwww.ticketweb.ca%2Fromane&userId=2047633&signature=b151311fc8f4edc0>*
*Or Charge By Phone: 1-888-222-6608*
*IMPORTANT! CLOSING TIMES OF DISCOUNTED ADVANCE TICKETS:*
* Discount advance ticket sales close at 7 pm the day before the seminar.
seat!*
*SAVE A LIFE – TELL YOUR FRIENDS AND FAMILY!*
door, if available.
<https://mailtrack.io/trace/link/0d2245964b89cb1b756c81f90e9dd5b77dcb01c6?url=https%3A%2F%2Fwww.vanceromane.com%2Fproducts.html&userId=2047633&signature=915706b7800f9697>
1. If you have more than one recording, begin with the one dealing with
2. Play the recordings all through once, so you know what is on the
recordings.
3. If your program is a set of 2 or more recordings, pick out one
results!
4. After success, occasionally listen to the recordings again. You will
*YOUR INNER AND OUTER MIND*
1. Hypnosis greatly ramps up motivation and will power.
2. Play one hypnosis session once per day, preferably in the evening
3. Occasionally, you should play the recording in the daytime. Sit up
*BEFORE YOU BEGIN*
1. Wear loose, relaxing, comfortable clothing.
2. Play the recording in a quiet room. Unplug your telephone and place
3. Close your window curtains for more darkness and better
4. Set room temperature comfortably warm.
5. Remove glasses or contact lenses.
6. For greater concentration, you can listen to the recording with
7. Initially, play the recording long enough to set the volume level:
8. While the recording is playing, you may fall asleep. In this case,
unconscious.
*ROMANE RECORDINGS AND YOU*
1. The recordings are designed to help you live a happier life…to help
2. These recordings are safe, beneficial, and easy to use. You will
*LASTING ADVANTAGES*
1. Romane recordings teach you HOW TO CONCENTRATE YOUR MIND. All in
success.
2. Recordings are best used REGULARLY. REPETITION and REINFORCEMENT are
the keys to change.
3. After your challenge is part of the past (and therefore CONQUERED),
*WORDS OF CAUTION*
1. Do not play ROMANE RECORDINGS while driving an automobile or while
2. Romane recordings are not a substitute for other practitioners: For
3. Refrain from eating a heavy meal before using a recording (on the
4. Do not consume alcohol, tranquilizers, or mind-altering drugs before
5. Avoid concentrating too INTENSELY; listen naturally to the recorded
6. Most people are not aware they are in hypnosis. Don’t ‘analyze’ or
M. Vance Romane
Surrey, BC
V4A 0B1
Fax: 604 538 8477
vanceromane.com
<https://mailtrack.io/trace/link/1738c18899a0b2d8cd5849e93edb8cd28a1401fc?url=http%3A%2F%2Fvanceromane.com%2F&userId=2047633&signature=5423d27e799714d4>
romane.ca
<https://mailtrack.io/trace/link/c5fefff2c18ce3fea190271f83d3f28d1516cf30?url=http%3A%2F%2Fromane.ca%2F&userId=2047633&signature=37f4773393c7e378>
[image: Mailtrack]
<https://mailtrack.io/trace/link/70d44fa9fb5b08c5987207a386720c774ea9ec1d?url=https%3A%2F%2Fmailtrack.io%3Futm_source%3Dgmail%26utm_medium%3Dsignature%26utm_campaign%3Dsignaturevirality5%26&userId=2047633&signature=bbd4a03d50404f20>
Sender
notified by
Mailtrack
<https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&>
03/06/19,
8:15:57 PM
