Does anybody use these in their slip? They are like a floating
bag your
boat slides on top of then you put some pool chlorine inside
to keep
growth off the boat. They have flotation at the bow and along
the
sides. At the stern you tie it up when you are in your slip
then untie
it and it is weighted to sink to let your boat out.
If you use or used one what do you think?
Thanks,
Rick
We have one in out marina in St Clair, MI--looks to be a lot
of trouble with very little benefit. Owner has a lot of
problem keeping the "float" under the boat (26-28 go fast)
when he tries to enter his slip. Once he is over it, he then
has to inflate it and it has a tendency to move out from under
his boat. Last time I watched him tie up...it took a good
half to three quarters of an hour to get it inflated.
Where we are in Michigan, all it will accomplish is to keep
the "green slime" off the bottom, maybe save him one half MPH
top end. I don't know how effective it would be in salt water.
Larry V
"Deserata" 43' custom steel trawler
