I have broken 5 Pet Steps with the last incident having been a
catastrophic
failure where it broke in half and dropped me in the water with zero
warning. I left it out 24/7
Ron brings up a really important point. A lot of plastic accessories
like step stools, etc. are made from a material that over time is
susceptible to UV light degradation. We had a simple little step
stool that we kept on the aft deck. It was fine for a couple of
years. Then one day I used it while varnishing the nav light/name
boards on the sides of the flying bridge and when I stepped up onto
it it shattered into a dozen pieces. Fortunately it wasn't very
high and I simply dropped back to the deck. This was not a collapse
under too much weight, the thing simply disintegrated. When I picked
up the larger pieces and tried to bend them in my hands, they just
shattered into several smaller pieces. This is UV degradation.
There are plastics that are UV resistant, and you can always paint a
plastic step stool or boarding step which I assume would prevent UV
degradation. But be wary of plastic things that stay outside year
round. They can have a very finite life and die a violent death that
could result in a serious injury to you, too. A fiberglass or wood
boarding step or ramp would be a much better choice to my way of
thinking.
C. Marin Faure
GB36-403 "La Perouse"
Bellingham, Washington
I'll expand a bit on Marin's post. ALL plastic will degrade in sunlight over
time. There are some that are more resistant than others, and there are
additives you can put in them to slow down the degradation. The best of
these is carbon black, so black plastics will almost always last longer than
any others of the same type, etc. Thickness matters as well. A very thin
sheet of clear polyethylene with no UV additives will last almost no time in
the sun. A thick sheet will degrade on the surface, but last longer.
When you don't wax your fiberglass hull, that chalky stuff you get is
degraded gelcoat. Thank goodness you have a lot of fiberglass under that.
When you think of "plastics" remember the term includes lots of things. Your
lines are some type of plastic. Floating polypropylene degrades faster than
almost anything else on your boat, so if you have some on a life ring, be
sure to check it occasionally. I've replaced mine twice, and it's due again.
I'm going to make a bag of some type to stow it in, so the new one will last
longer.
I use black dock lines because they last longer than any other color. They
also don't appear dirty. If you decide to paint a plastic part, black would
be the color of choice, since the carbon black completely shields the
plastic underneath from UV degradation. Carbon black is about as degraded as
it's gonna get when it's made! Anything you can do to keep the UV rays away
from your plastic items will help them out.
Most modern canvas is "plastic", as it's made from synthetic fibers. Look
for protectants that have UV inhibitors.
Keith
-----Original Message-----
thinking.
