HI,
I have successfully compiled the PJSIP Softphone application on Windows
Mobile 6 Professional Emulator. The registration and calling is going fine,
When I am calling to any mobile the call is going right but when call is
picked up, there is no voice on either Side. Neither on PC running emulator
nor on the device being called.
Also I have checked the packets on wireshark all the SIP Packets are coming
and also the RTP packets are coming only from server side with the GSM
payload type.
Also when i am calling pjsua function pjsua_get_snd_dev after
pjsua_start() function I am receiving the deviceID as -1 in both the input
device ID and receiving Device ID. When using the funciton
pjsua_enum_snd_dev(pjmedia_snd_info info[], int* count) to enumerate the
sound devices it returns the 5 devices in count, but in parameter
pjmedia_snd_info info it gives the same name "Microsoft Sound Mapper -
Input" all the 5 times.
Please see what the problem is, is there some settings to connect headphones
of the PC running emulator to the WM6 emulator.
Thanks in advance ....Any help will be appreciated.....
Regards:
Ravi
On Fri, Feb 13, 2009 at 10:53 AM, varun pratapsingh
varunps2003@gmail.comwrote:
HI,
payload type.
Hi Ravi , based on my experience, normally we couldn't get the microphone to
work with the emulator too, so that's probably why you don't see any RTP
packets transmitted by the emulator. As for traffic from the other
direction, it is also known that the emulator puts somekind of NAT in front
of it, so unless some NAT traversal methods are enabled (such as STUN)
probably the packets from server won't go through.
Device ID -1 is used to identify the default device. As for device names, I
haven't tested it myself on WM platforms, and I suppose there could be some
potential problems due to Unicode things.
cheers
Benny
