trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
Website with interactive marina information
BM
Bob McLeran
Thu, Mar 9, 2006 12:28 AM
This arrived in my email today out of the blue. Though some of you might
be interested so am passing it along. Don't know anything about the
site, but a cursory glance suggests it may be useful to someone who
doesn't already own a cruising guide or perhaps wants more up-to-date
information.
The url is http://www.mapmuse.com
I am writing to let sailing enthusiasts know about a website that has
interactive mapping of marinas across the US.  In order to view the
Marinas map, go to Mapmuse.com, select View All Interest, and select
Marinas from the list of interests.
The idea is for sailing enthusiasts to build upon what we have started
by adding marinas we have missed, and editing and enhancing information
that is already there.  Through this kind of community effort, we hope
to have the most comprehensive, descriptive, and up to date maps to help
sailors locate marinas at home and on their travels. We would appreciate
if you would participate in the process, by checking if your favorite
marinas are mapped, enhancing information as you see fit, and adding
marinas that we have missed. This is simple to do.
To add marinas go to the Marinas map, click on Know any marinas we are
missing?, fill out the form, click submit, and your information will be
posted within a few hours.
To edit information about a marina that is already mapped, click on the
icon associated with the shop. An information box will pop up, click the
edit link, fill out the form, click submit and the changes will appear
within a few hours.
<><><><><><><><><><><><><><>Mozilla Thunderbird<><><><><><><><><><><><>
Bob McLeran and Judy Young                      Manatee Cove Marina
M/V Sanderling                                  Patrick Air Force Base
Hampton 35 Trawler                              Melbourne, Florida
This arrived in my email today out of the blue. Though some of you might be interested so am passing it along. Don't know anything about the site, but a cursory glance suggests it may be useful to someone who doesn't already own a cruising guide or perhaps wants more up-to-date information. The url is http://www.mapmuse.com -------- I am writing to let sailing enthusiasts know about a website that has interactive mapping of marinas across the US. In order to view the Marinas map, go to Mapmuse.com, select View All Interest, and select Marinas from the list of interests. The idea is for sailing enthusiasts to build upon what we have started by adding marinas we have missed, and editing and enhancing information that is already there. Through this kind of community effort, we hope to have the most comprehensive, descriptive, and up to date maps to help sailors locate marinas at home and on their travels. We would appreciate if you would participate in the process, by checking if your favorite marinas are mapped, enhancing information as you see fit, and adding marinas that we have missed. This is simple to do. To add marinas go to the Marinas map, click on Know any marinas we are missing?, fill out the form, click submit, and your information will be posted within a few hours. To edit information about a marina that is already mapped, click on the icon associated with the shop. An information box will pop up, click the edit link, fill out the form, click submit and the changes will appear within a few hours. -- <><><><><><><><><><><><><><>Mozilla Thunderbird<><><><><><><><><><><><> Bob McLeran and Judy Young Manatee Cove Marina M/V Sanderling Patrick Air Force Base Hampton 35 Trawler Melbourne, Florida
J
Jay
Thu, Mar 9, 2006 12:53 AM
I'm installing an icemaker in our trawler... my question is whether I should
install this using the inverter only or install a switch that I could use to
switch to shore power when at a marina rather than continue to drain the
house bank?
Also, is there a switch on the market that would do this automatically?
Shore power On - ice maker uses shore power
Shore power Off - ice maker uses inverter power
Or should I not really be concerned about the small drain that ice maker
would use from the house batteries?
Specs:
Icemaker U-line SP18
Run Amps: 2.5
Max Start Amps: 18.0
House bank: 450(20 Hr Rate AH)
Other items on inverter:
17" LCD TV - draws less than 10 amps
Seawatch TV Antenna - draws less than 5 amps
Norcold Refg. DE-00061 - draws less than 10 amps
Microwave Sharp R55TS - clock draws .03 amps... running draws up to 100 amps
Jay E Wigginton
CHARIS
1972 40' Eagle Sedan Trawler
North Fort Myers, FL
I'm installing an icemaker in our trawler... my question is whether I should install this using the inverter only or install a switch that I could use to switch to shore power when at a marina rather than continue to drain the house bank? Also, is there a switch on the market that would do this automatically? Shore power On - ice maker uses shore power Shore power Off - ice maker uses inverter power Or should I not really be concerned about the small drain that ice maker would use from the house batteries? Specs: Icemaker U-line SP18 Run Amps: 2.5 Max Start Amps: 18.0 House bank: 450(20 Hr Rate AH) Other items on inverter: 17" LCD TV - draws less than 10 amps Seawatch TV Antenna - draws less than 5 amps Norcold Refg. DE-00061 - draws less than 10 amps Microwave Sharp R55TS - clock draws .03 amps... running draws up to 100 amps Jay E Wigginton CHARIS 1972 40' Eagle Sedan Trawler North Fort Myers, FL
PB
Peter Bennett
Thu, Mar 9, 2006 1:16 AM
Wednesday, March 8, 2006, 4:53:55 PM, Jay wrote:
J> I'm installing an icemaker in our trawler... my question is whether I should
J> install this using the inverter only or install a switch that I could use to
J> switch to shore power when at a marina rather than continue to drain the
J> house bank?
J> Also, is there a switch on the market that would do this automatically?
J> Shore power On - ice maker uses shore power
J> Shore power Off - ice maker uses inverter power
J> Or should I not really be concerned about the small drain that ice maker
J> would use from the house batteries?
J> Specs:
J> Icemaker U-line SP18
J> Run Amps: 2.5
J> Max Start Amps: 18.0
J> House bank: 450(20 Hr Rate AH)
J> Other items on inverter:
J> 17" LCD TV - draws less than 10 amps
J> Seawatch TV Antenna - draws less than 5 amps
J> Norcold Refg. DE-00061 - draws less than 10 amps
J> Microwave Sharp R55TS - clock draws .03 amps... running draws up to 100 amps
J> Jay E Wigginton
If your inverter includes a charger, then it probably also includes a shore power/inverter transfer relay, so things connected to the output of the inverter will really be using shore power when it is available.
If your inverter doesn't have a transfer switch, but you normally use a charger while on shore power then you won't be draining the battery when the icemaker (or other inverter loads) runs - you just won't be charging the battery as fast as you might without those loads.  The microwave will discharge the batteries while it runs, unless your charger can deliver more than 100 amps - but that's not a big deal since the microwave will only be used for short periods, so the charger should catch up quickly when the microwave is off.
Peter Bennett, VE7CEI    Vancouver, B.C., Canada
Lien Hwa 28 (AKA Polaris 30) "Sea Spray"
GPS and NMEA info: http://vancouver-webpages.com/peter
Vancouver Power Squadron: http://vancouver.powersquadron.ca
Wednesday, March 8, 2006, 4:53:55 PM, Jay wrote: J> I'm installing an icemaker in our trawler... my question is whether I should J> install this using the inverter only or install a switch that I could use to J> switch to shore power when at a marina rather than continue to drain the J> house bank? J> Also, is there a switch on the market that would do this automatically? J> Shore power On - ice maker uses shore power J> Shore power Off - ice maker uses inverter power J> Or should I not really be concerned about the small drain that ice maker J> would use from the house batteries? J> Specs: J> Icemaker U-line SP18 J> Run Amps: 2.5 J> Max Start Amps: 18.0 J> House bank: 450(20 Hr Rate AH) J> Other items on inverter: J> 17" LCD TV - draws less than 10 amps J> Seawatch TV Antenna - draws less than 5 amps J> Norcold Refg. DE-00061 - draws less than 10 amps J> Microwave Sharp R55TS - clock draws .03 amps... running draws up to 100 amps J> Jay E Wigginton If your inverter includes a charger, then it probably also includes a shore power/inverter transfer relay, so things connected to the output of the inverter will really be using shore power when it is available. If your inverter doesn't have a transfer switch, but you normally use a charger while on shore power then you won't be draining the battery when the icemaker (or other inverter loads) runs - you just won't be charging the battery as fast as you might without those loads. The microwave will discharge the batteries while it runs, unless your charger can deliver more than 100 amps - but that's not a big deal since the microwave will only be used for short periods, so the charger should catch up quickly when the microwave is off. -- Peter Bennett, VE7CEI Vancouver, B.C., Canada Lien Hwa 28 (AKA Polaris 30) "Sea Spray" GPS and NMEA info: http://vancouver-webpages.com/peter Vancouver Power Squadron: http://vancouver.powersquadron.ca
J
Jay
Thu, Mar 9, 2006 1:31 AM
I have a Heart Freedom 1000 inverter... so I assume that has this function
built-in... ???
Thanks,
Jay E Wigginton
CHARIS
-----Original Message-----
From: Peter Bennett [mailto:peterbb4@interchange.ubc.ca]
Sent: Wednesday, March 08, 2006 8:16 PM
To: Jay; trawlers-and-trawlering@lists.samurai.com
Subject: Re: T&T: ice maker inverter/shore power
should
to
J> house bank?
J> Specs:
J> Run Amps: 2.5
amps
J> Jay E Wigginton
microwave is off.
I have a Heart Freedom 1000 inverter... so I assume that has this function built-in... ??? Thanks, Jay E Wigginton CHARIS 1972 40' Eagle Sedan Trawler North Fort Myers, FL -----Original Message----- From: Peter Bennett [mailto:peterbb4@interchange.ubc.ca] Sent: Wednesday, March 08, 2006 8:16 PM To: Jay; trawlers-and-trawlering@lists.samurai.com Subject: Re: T&T: ice maker inverter/shore power Wednesday, March 8, 2006, 4:53:55 PM, Jay wrote: J> I'm installing an icemaker in our trawler... my question is whether I should J> install this using the inverter only or install a switch that I could use to J> switch to shore power when at a marina rather than continue to drain the J> house bank? J> Also, is there a switch on the market that would do this automatically? J> Shore power On - ice maker uses shore power J> Shore power Off - ice maker uses inverter power J> Or should I not really be concerned about the small drain that ice maker J> would use from the house batteries? J> Specs: J> Icemaker U-line SP18 J> Run Amps: 2.5 J> Max Start Amps: 18.0 J> House bank: 450(20 Hr Rate AH) J> Other items on inverter: J> 17" LCD TV - draws less than 10 amps J> Seawatch TV Antenna - draws less than 5 amps J> Norcold Refg. DE-00061 - draws less than 10 amps J> Microwave Sharp R55TS - clock draws .03 amps... running draws up to 100 amps J> Jay E Wigginton If your inverter includes a charger, then it probably also includes a shore power/inverter transfer relay, so things connected to the output of the inverter will really be using shore power when it is available. If your inverter doesn't have a transfer switch, but you normally use a charger while on shore power then you won't be draining the battery when the icemaker (or other inverter loads) runs - you just won't be charging the battery as fast as you might without those loads. The microwave will discharge the batteries while it runs, unless your charger can deliver more than 100 amps - but that's not a big deal since the microwave will only be used for short periods, so the charger should catch up quickly when the microwave is off. -- Peter Bennett, VE7CEI Vancouver, B.C., Canada Lien Hwa 28 (AKA Polaris 30) "Sea Spray" GPS and NMEA info: http://vancouver-webpages.com/peter Vancouver Power Squadron: http://vancouver.powersquadron.ca
HW
Hal Wyman
Thu, Mar 9, 2006 2:01 AM
It certainly does.  Read carefully
http://www.rivermarine.com/ELECTRIC/INVERTER/HT1000.HTM
Hal
trawlers-and-trawlering-bounces+twl2=halwyman.com@lists.samura
i.com
[mailto:trawlers-and-trawlering-bounces+twl2=halwyman.com@list
s.samurai.com] On Behalf Of Jay
Sent: Wednesday, March 08, 2006 7:32 PM
To: trawlers-and-trawlering@lists.samurai.com
Thanks,
Jay E Wigginton
CHARIS
is whether I
should
that I could use
to
J> house bank?
automatically?
that ice maker
J> Specs:
J> Run Amps: 2.5
draws up to 100
amps
J> Jay E Wigginton
includes a shore
output of the
normally use a
battery when the
charging the
can deliver more
will only be
quickly when the
microwave is off.
http://lists.samurai.com/mailman/listinfo/trawlers-and-trawlering
To unsubscribe send email to
trawlers-and-trawlering-request@lists.samurai.com with the word
UNSUBSCRIBE and nothing else in the subject or body of the message.
Trawlers & Trawlering and T&T are trademarks of Water World
Productions. Unauthorized use is prohibited.
It certainly does. Read carefully http://www.rivermarine.com/ELECTRIC/INVERTER/HT1000.HTM Hal > -----Original Message----- > From: > trawlers-and-trawlering-bounces+twl2=halwyman.com@lists.samura > i.com > [mailto:trawlers-and-trawlering-bounces+twl2=halwyman.com@list > s.samurai.com] On Behalf Of Jay > Sent: Wednesday, March 08, 2006 7:32 PM > To: trawlers-and-trawlering@lists.samurai.com > Subject: Re: T&T: ice maker inverter/shore power > > I have a Heart Freedom 1000 inverter... so I assume that has > this function built-in... ??? > > Thanks, > Jay E Wigginton > CHARIS > 1972 40' Eagle Sedan Trawler > North Fort Myers, FL > > > -----Original Message----- > From: Peter Bennett [mailto:peterbb4@interchange.ubc.ca] > Sent: Wednesday, March 08, 2006 8:16 PM > To: Jay; trawlers-and-trawlering@lists.samurai.com > Subject: Re: T&T: ice maker inverter/shore power > > > > Wednesday, March 8, 2006, 4:53:55 PM, Jay wrote: > > J> I'm installing an icemaker in our trawler... my question > is whether I > should > J> install this using the inverter only or install a switch > that I could use > to > J> switch to shore power when at a marina rather than > continue to drain the > J> house bank? > > J> Also, is there a switch on the market that would do this > automatically? > > J> Shore power On - ice maker uses shore power > > J> Shore power Off - ice maker uses inverter power > > J> Or should I not really be concerned about the small drain > that ice maker > J> would use from the house batteries? > > J> Specs: > J> Icemaker U-line SP18 > J> Run Amps: 2.5 > J> Max Start Amps: 18.0 > J> House bank: 450(20 Hr Rate AH) > > J> Other items on inverter: > > J> 17" LCD TV - draws less than 10 amps > J> Seawatch TV Antenna - draws less than 5 amps > J> Norcold Refg. DE-00061 - draws less than 10 amps > J> Microwave Sharp R55TS - clock draws .03 amps... running > draws up to 100 > amps > > > J> Jay E Wigginton > > If your inverter includes a charger, then it probably also > includes a shore > power/inverter transfer relay, so things connected to the > output of the > inverter will really be using shore power when it is available. > > If your inverter doesn't have a transfer switch, but you > normally use a > charger while on shore power then you won't be draining the > battery when the > icemaker (or other inverter loads) runs - you just won't be > charging the > battery as fast as you might without those loads. The microwave will > discharge the batteries while it runs, unless your charger > can deliver more > than 100 amps - but that's not a big deal since the microwave > will only be > used for short periods, so the charger should catch up > quickly when the > microwave is off. > > > > -- > Peter Bennett, VE7CEI Vancouver, B.C., Canada > Lien Hwa 28 (AKA Polaris 30) "Sea Spray" > GPS and NMEA info: http://vancouver-webpages.com/peter > Vancouver Power Squadron: http://vancouver.powersquadron.ca > _______________________________________________ > http://lists.samurai.com/mailman/listinfo/trawlers-and-trawlering > > To unsubscribe send email to > trawlers-and-trawlering-request@lists.samurai.com with the word > UNSUBSCRIBE and nothing else in the subject or body of the message. > > Trawlers & Trawlering and T&T are trademarks of Water World > Productions. Unauthorized use is prohibited.
