JP
Joel Parker
Mon, May 14, 2012 3:44 PM
I was able to get the system back up with the upgrade kernel. Thanks for your help with that. I have a new issue, I am following the instructions for openBTS : http://gnuradio.org/redmine/projects/gnuradio/wiki/OpenBTSE100
but when I run the command :
$ ./configure --with-uhd CFLAGS="-march=armv7-a -mtune=cortex-a8 -mfpu=neon -mfloat-abi=softfp -O3" CXXFLAGS="-march=armv7-a -mtune=cortex-a8 -mfpu=neon -mfloat-abi=softfp -O3"
It complains that the build requirements have not been met because it is missing libosip2 . Any idea's
how I can get this lib ?
-- Joel Parker
To: Joel Parker joelparker27@yahoo.com
Cc: Philip Balister philip@opensdr.com
Sent: Friday, May 11, 2012 5:40 PM
Subject: Re: [USRP-users] Read Only File System ?
Joel -
No. If anything, you probably have a bad SD card.
If the original Make script worked, then try that again, and see if the card boots. If it doesn't, please send us the output of the make script, the output of this command:
$ sudo fdisk -l
(which should show us the partition table of the SD card)
And the console output showing errors.
Also, in the future, it may take me longer than an hour to respond to you. That does not mean that I am ignoring you.
Cheers,
Ben
On Fri, May 11, 2012 at 3:26 PM, Joel Parker joelparker27@yahoo.com wrote:
Do you have any suggestions of what to do ? Do I need to return the unit ?
-- Joel
Sent from Yahoo! Mail on Android
To: Ben Hilburn ben@ettus.com;
Sent: Fri, May 11, 2012 8:46:10 PM
It finished successfully but when I put it back in the E100 and turn it on. The only thing that shows in the console output is @
and it never returns from there. So the issue looks like it is not booting period. It was originally so not sure what happened.
-- Joel Parker
To: Philip Balister philip@opensdr.com
Cc: Joel Parker joelparker27@yahoo.com
Sent: Friday, May 11, 2012 3:08 PM
Joel -
If you used the MakeEttusSDCard.sh script distributed with the image tarball, and it failed, it's possible your version of the parted program isn't working properly.
This is a known bug, and I've made an alternate Make script to get around it. I have attached that script to this e-mail - after you check out your console output and confirm that the issue is that it's not booting, give this script a shot.
Cheers,
Ben
On Fri, May 11, 2012 at 1:05 PM, Philip Balister philip@opensdr.com wrote:
On 05/11/2012 04:03 PM, Joel Parker wrote:
When I put the sd card back in and applied power only the F light is on and the Ethernet physical layer lights never turn on. I will need to get a console cable adapter to get specific messages but wanted to know if there may some common error that I am not aware of.
Bother. I am copying Ben @ Ettus. He'll send you an alternate sd card
creation script.
Philip
On 05/11/2012 11:36 AM, Joel Parker wrote:
Yeah, same thing I thought but svn also had errors when installing but seems to work ?
root@usrp-e1xx:~# opkg install subversion
Installing subversion (1.6.5-r1.9) to root...
Downloading http://feeds.angstrom-distribution.org/feeds/next/ipk/eglibc/armv7a/base/subversion_1.6.5-r1.9_armv7a.ipk.
Installing libaprutil-1-0 (1.3.10-r1.9) to root...
Downloading http://feeds.angstrom-distribution.org/feeds/next/ipk/eglibc/armv7a/base/libaprutil-1-0_1.3.10-r1.9_armv7a.ipk.
Installing libapr-1-0 (1.4.2-r0.9) to root...
Downloading http://feeds.angstrom-distribution.org/feeds/next/ipk/eglibc/armv7a/base/libapr-1-0_1.4.2-r0.9_armv7a.ipk.
Collected errors:
* opkg_prep_intercepts: Failed to make temp dir /var/lib/opkg/tmp/opkg-lK8a4R/opkg-intercept-2uyF1V: Invalid argument.
I don't see timeout issues but do see many i/o errors with the mmc. This is the first time I ever powered this device up ... very strange.
Here is the output from dmesg:
Linux version 3.0.0 (balister@octopus) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #1 Tue Nov 15 14:07:23 EST 2011
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Gumstix Overo
Reserving 12582912 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
OMAP3630 ES1.2 (l2cache iva sgx neon isp 192mhz_clk )
SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x10000
On node 0 totalpages: 128000
free_area_init_node: node 0, pgdat c0599010, node_mem_map c05fe000
Normal zone: 1024 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 126976 pages, LIFO batch:31
Clocking rate (Crystal/Core/MPU): 26.0/332/600 MHz
Reprogramming SDRC clock to 332000000 Hz
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 126976
Kernel command line: console=ttyO2,115200n8 mpurate=720 vram=12M omapfb.mode=dvi:1024x768MR-16@60 omapdss.def_disp=dvi root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 500MB = 500MB total
Memory: 501328k/501328k available, 22960k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xe0800000 - 0xf8000000 ( 376 MB)
lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.init : 0xc0008000 - 0xc0037000 ( 188 kB)
.text : 0xc0037000 - 0xc0554f94 (5240 kB)
.data : 0xc0556000 - 0xc05996c0 ( 270 kB)
.bss : 0xc05996e4 - 0xc05fd684 ( 400 kB)
NR_IRQS:410
IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts
Total of 96 interrupts on 1 active controller
OMAP clockevent source: GPTIMER1 at 32768 Hz
sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
Console: colour dummy device 80x30
Calibrating delay loop... 597.64 BogoMIPS (lpj=2334720)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
omap_hwmod: gpt12_fck: missing clockdomain for gpt12_fck.
print_constraints: dummy:
NET: Registered protocol family 16
GPMC revision 5.0
OMAP GPIO hardware version 2.5
omap_mux_init: Add partition: #1: core, flags: 0
Found NAND on CS0
Registering NAND on CS0
Setup up gpmc timing.
GPMC_CONFIG1 reg: 28001002
GPMC_CONFIG2 reg: 30600
GPMC_CONFIG3 reg: 20201
GPMC_CONFIG4 reg: 3000501
GPMC_CONFIG5 reg: 1030306
GPMC_CONFIG6 reg: 83030000
GPMC_CONFIG1 reg: 1000
GPMC_CONFIG2 reg: 141f00
GPMC_CONFIG4 reg: 14001f00
GPMC_CONFIG5 reg: 11e151f
GPMC_CONFIG6 reg: f030f80
hw-breakpoint: debug architecture 0x4 unsupported.
omap_device: omap-mcbsp.2: alias fck already exists
omap_device: omap-mcbsp.3: alias fck already exists
Switched to new clocking rate (Crystal/Core/MPU): 26.0/332/720 MHz
OMAP DMA hardware revision 5.0
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
omap_i2c omap_i2c.1: bus 1 rev4.0 at 2600 kHz
twl4030: PIH (irq 7) chaining IRQs 368..375
twl4030: power (irq 373) chaining IRQs 376..383
twl4030: gpio (irq 368) chaining IRQs 384..401
machine_constraints_voltage: VUSB1V5: override min_uV, 1 -> 1500000
machine_constraints_voltage: VUSB1V5: override max_uV, 2147483647 -> 1500000
print_constraints: VUSB1V5: 1500 mV normal standby
machine_constraints_voltage: VUSB1V8: override min_uV, 1 -> 1800000
machine_constraints_voltage: VUSB1V8: override max_uV, 2147483647 -> 1800000
print_constraints: VUSB1V8: 1800 mV normal standby
machine_constraints_voltage: VUSB3V1: override min_uV, 1 -> 3100000
machine_constraints_voltage: VUSB3V1: override max_uV, 2147483647 -> 3100000
print_constraints: VUSB3V1: 3100 mV normal standby
twl4030_usb twl4030_usb: HW_CONDITIONS 0x10/16; link 0
twl4030_usb twl4030_usb: Initialized TWL4030 USB module
print_constraints: VMMC1: 1850 <--> 3150 mV at 3000 mV normal standby
print_constraints: VDAC: 1800 mV normal standby
print_constraints: VDVI: 1800 mV normal standby
omap_i2c omap_i2c.3: bus 3 rev4.0 at 400 kHz
Advanced Linux Sound Architecture Driver Version 1.0.24.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
Switching to clocksource 32k_counter
Switched to NOHz mode on CPU #0
musb-hdrc: version 6.0, musb-dma, host
twl4030_usb twl4030_usb: twl4030_phy_resume
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 1.800
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
musb-hdrc musb-hdrc: MUSB HDRC host driver
drivers/usb/core/inode.c: creating file 'devices'
drivers/usb/core/inode.c: creating file '001'
musb-hdrc musb-hdrc: new USB bus registered, assigned bus number 1
usb usb1: default language 0x0409
usb usb1: udev 1, busnum 1, minor = 0
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: MUSB HDRC host driver
usb usb1: Manufacturer: Linux 3.0.0 musb-hcd
usb usb1: SerialNumber: musb-hdrc
usb usb1: usb_probe_device
usb usb1: configuration #1 chosen from 1 choice
usb usb1: adding 1-0:1.0 (config #1, interface 0)
hub 1-0:1.0: usb_probe_interface
hub 1-0:1.0: usb_probe_interface - got id
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
hub 1-0:1.0: standalone hub
hub 1-0:1.0: individual port power switching
hub 1-0:1.0: no over-current protection
hub 1-0:1.0: Single TT
hub 1-0:1.0: TT requires at most 8 FS bit times (666 ns)
hub 1-0:1.0: power on to power good time: 10ms
hub 1-0:1.0: 100mA bus power budget for each child
hub 1-0:1.0: local power source is good
hub 1-0:1.0: enabling power on all ports
musb-hdrc musb-hdrc: USB Host mode controller at fa0ab000 using DMA, IRQ 92
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Registering unionfs 2.5.9.2 (for 3.0.0-rc4)
JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
msgmni has been set to 979
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
OMAP DSS rev 2.0
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a OMAP UART0
omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a OMAP UART2
console [ttyO2] enabled
hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0000
omap_uart.3: ttyO3 at MMIO 0x49042000 (irq = 80) is a OMAP UART3
brd: module loaded
loop: module loaded
twl4030_usb twl4030_usb: HW_CONDITIONS 0x50/80; link 0
twl4030_usb twl4030_usb: twl4030_phy_suspend
omap2-nand driver initializing
ONFI flash detected
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xbc (Micron NAND 512MiB 1,8V 16-bit)
Creating 5 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000080000 : "xloader"
0x000000080000-0x000000240000 : "uboot"
0x000000240000-0x000000280000 : "uboot environment"
0x000000280000-0x000000680000 : "linux"
0x000000680000-0x000020000000 : "rootfs"
smsc911x: Driver version 2008-10-21
smsc911x-mdio: probed
smsc911x smsc911x.0: eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:01, irq=-1)
smsc911x smsc911x.0: eth0: MAC Address: a0:36:fa:85:31:b7
usbcore: registered new interface driver asix
usbcore: registered new interface driver cdc_ether
cdc_ncm: 01-June-2011
usbcore: registered new interface driver cdc_ncm
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci_hcd: block sizes: qh 60 qtd 96 itd 160 sitd 96
ehci-omap ehci-omap.0: failed to get ehci port1 regulator
ehci-omap ehci-omap.0: phy reset operation timed out
ehci-omap ehci-omap.0: reset hcs_params 0x1313 dbg=0 cc=1 pcc=3 ordered ports=3
ehci-omap ehci-omap.0: reset hcc_params 0016 thresh 1 uframes 256/512/1024 park
ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
drivers/usb/core/inode.c: creating file '002'
ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 2
ehci-omap ehci-omap.0: park 0
ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
ehci-omap ehci-omap.0: reset command 0080b02 park=3 ithresh=8 period=1024 Reset HALT
ehci-omap ehci-omap.0: init command 0010005 (park)=0 ithresh=1 period=512 RUN
ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
usb usb2: default language 0x0409
usb usb2: udev 1, busnum 2, minor = 128
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: OMAP-EHCI Host Controller
usb usb2: Manufacturer: Linux 3.0.0 ehci_hcd
usb usb2: SerialNumber: ehci-omap.0
usb usb2: usb_probe_device
usb usb2: configuration #1 chosen from 1 choice
usb usb2: adding 2-0:1.0 (config #1, interface 0)
hub 2-0:1.0: usb_probe_interface
hub 2-0:1.0: usb_probe_interface - got id
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 3 ports detected
hub 2-0:1.0: standalone hub
hub 2-0:1.0: individual port power switching
hub 2-0:1.0: individual port over-current protection
hub 2-0:1.0: power on to power good time: 20ms
hub 2-0:1.0: local power source is good
hub 2-0:1.0: enabling power on all ports
ehci-omap ehci-omap.0: ...powerup ports...
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
twl_rtc twl_rtc: Power up reset detected.
i2c /dev entries driver
OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
Bluetooth: HCI UART driver ver 2.2
Bluetooth: HCI H4 protocol initialized
Bluetooth: HCI BCSP protocol initialized
Bluetooth: HCILL protocol initialized
cpuidle: using governor ladder
cpuidle: using governor menu
Registered led device: overo:blue:COM
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
usbcore: registered new interface driver snd-usb-audio
overo SoC init
hub 2-0:1.0: state 7 ports 3 chg 0000 evt 0000
asoc: twl4030-hifi <-> omap-mcbsp-dai.1 mapping ok
ALSA device list:
#0: overo
oprofile: hardware counters not available
oprofile: using timer interrupt.
TCP cubic registered
NET: Registered protocol family 17
NET: Registered protocol family 15
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Registering the dns_resolver key type
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
ThumbEE CPU extension supported.
sr_init: No PMIC hook to init smartreflex
smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver initialized
smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver initialized
clock: disabling unused clocks to save power
fbcvt: 1024x768@60: CVT Name - .786M3-R
Console: switching to colour frame buffer device 128x48
regulator_init_complete: VDAC: incomplete constraints, leaving on
twl_rtc twl_rtc: setting system clock to 2000-01-01 00:00:20 UTC (946684820)
Waiting for root device /dev/mmcblk0p2...
mmc0: host does not support reading read-only switch. assuming write-enable.
mmc0: new SDHC card at address b368
mmcblk0: mmc0:b368 SDC 3.84 GiB
mmcblk0: p1 p2
EXT3-fs: barriers not enabled
kjournald starting. Commit interval 5 seconds
EXT3-fs (mmcblk0p2): using internal journal
EXT3-fs (mmcblk0p2): recovery complete
EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
VFS: Mounted root (ext3 filesystem) on device 179:2.
devtmpfs: mounted
Freeing init memory: 188K
NET: Registered protocol family 10
usrp_e entering driver initialization
usrp_e data struct malloc'd.
usrp_e Data initialized..
usrp_e major number : 249
Getting Chip Select
Got CS4, address = 1000000
Got CS6, address = 2000000
usrp_e Driver Initialized.
udevd[102]: starting version 171
smsc911x smsc911x.0: eth0: SMSC911x/921x identified at 0xe086a000, IRQ: 336
eth0: no IPv6 routers present
usrp_e open called, use_count = 0
rx_dma->ch 4
tx_dma->ch 5
usrp: leaving open
usrp_e release called
Waiting for DMA to become inactive
Freeing gpio irq's
Freeing DMA channels
rx_dma->ch 5
tx_dma->ch 6
usrp: leaving open
Size = 2105344, expected sixe = 2105344
Freeing gpio irq's
mmcblk0: error -110 transferring data, sector 438648, nr 8, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 438649
Buffer I/O error on device mmcblk0p2, logical block 38447
lost page write due to I/O error on mmcblk0p2
mmcblk0: error -110 transferring data, sector 779688, nr 8, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 779689
Buffer I/O error on device mmcblk0p2, logical block 81077
mmcblk0: error -110 transferring data, sector 788864, nr 8, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 788865
Buffer I/O error on device mmcblk0p2, logical block 82224
mmcblk0: error -110 transferring data, sector 1864744, nr 8, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 1864745
Buffer I/O error on device mmcblk0p2, logical block 216709
mmcblk0: error -110 sending read/write command, response 0x900, card status 0xe00
mmcblk0: error -110 transferring data, sector 1874144, nr 8, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 1874145
Buffer I/O error on device mmcblk0p2, logical block 217884
mmcblk0: error -110 transferring data, sector 1968272, nr 8, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 1968273
Buffer I/O error on device mmcblk0p2, logical block 229650
mmcblk0: error -110 transferring data, sector 2293616, nr 8, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 2293617
Buffer I/O error on device mmcblk0p2, logical block 270318
mmcblk0: error -110 transferring data, sector 5113152, nr 624, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 5113153
Buffer I/O error on device mmcblk0p2, logical block 622760
end_request: I/O error, dev mmcblk0, sector 5113160
Buffer I/O error on device mmcblk0p2, logical block 622761
end_request: I/O error, dev mmcblk0, sector 5113168
Buffer I/O error on device mmcblk0p2, logical block 622762
end_request: I/O error, dev mmcblk0, sector 5113176
Buffer I/O error on device mmcblk0p2, logical block 622763
end_request: I/O error, dev mmcblk0, sector 5113184
Buffer I/O error on device mmcblk0p2, logical block 622764
end_request: I/O error, dev mmcblk0, sector 5113192
Buffer I/O error on device mmcblk0p2, logical block 622765
end_request: I/O error, dev mmcblk0, sector 5113200
Buffer I/O error on device mmcblk0p2, logical block 622766
end_request: I/O error, dev mmcblk0, sector 5113208
Buffer I/O error on device mmcblk0p2, logical block 622767
end_request: I/O error, dev mmcblk0, sector 5113216
Buffer I/O error on device mmcblk0p2, logical block 622768
end_request: I/O error, dev mmcblk0, sector 5113224
end_request: I/O error, dev mmcblk0, sector 5113232
end_request: I/O error, dev mmcblk0, sector 5113240
end_request: I/O error, dev mmcblk0, sector 5113248
end_request: I/O error, dev mmcblk0, sector 5113256
end_request: I/O error, dev mmcblk0, sector 5113264
end_request: I/O error, dev mmcblk0, sector 5113272
end_request: I/O error, dev mmcblk0, sector 5113280
end_request: I/O error, dev mmcblk0, sector 5113288
end_request: I/O error, dev mmcblk0, sector 5113296
end_request: I/O error, dev mmcblk0, sector 5113304
end_request: I/O error, dev mmcblk0, sector 5113312
end_request: I/O error, dev mmcblk0, sector 5113320
end_request: I/O error, dev mmcblk0, sector 5113328
end_request: I/O error, dev mmcblk0, sector 5113336
end_request: I/O error, dev mmcblk0, sector 5113344
end_request: I/O error, dev mmcblk0, sector 5113352
end_request: I/O error, dev mmcblk0, sector 5113360
end_request: I/O error, dev mmcblk0, sector 5113368
end_request: I/O error, dev mmcblk0, sector 5113376
end_request: I/O error, dev mmcblk0, sector 5113384
end_request: I/O error, dev mmcblk0, sector 5113392
end_request: I/O error, dev mmcblk0, sector 5113400
end_request: I/O error, dev mmcblk0, sector 5113408
end_request: I/O error, dev mmcblk0, sector 5113416
end_request: I/O error, dev mmcblk0, sector 5113424
end_request: I/O error, dev mmcblk0, sector 5113432
end_request: I/O error, dev mmcblk0, sector 5113440
end_request: I/O error, dev mmcblk0, sector 5113448
end_request: I/O error, dev mmcblk0, sector 5113456
end_request: I/O error, dev mmcblk0, sector 5113464
end_request: I/O error, dev mmcblk0, sector 5113472
end_request: I/O error, dev mmcblk0, sector 5113480
end_request: I/O error, dev mmcblk0, sector 5113488
end_request: I/O error, dev mmcblk0, sector 5113496
end_request: I/O error, dev mmcblk0, sector 5113504
end_request: I/O error, dev mmcblk0, sector 5113512
end_request: I/O error, dev mmcblk0, sector 5113520
end_request: I/O error, dev mmcblk0, sector 5113528
end_request: I/O error, dev mmcblk0, sector 5113536
end_request: I/O error, dev mmcblk0, sector 5113544
end_request: I/O error, dev mmcblk0, sector 5113552
end_request: I/O error, dev mmcblk0, sector 5113560
end_request: I/O error, dev mmcblk0, sector 5113568
end_request: I/O error, dev mmcblk0, sector 5113576
end_request: I/O error, dev mmcblk0, sector 5113584
end_request: I/O error, dev mmcblk0, sector 5113592
end_request: I/O error, dev mmcblk0, sector 5113600
end_request: I/O error, dev mmcblk0, sector 5113608
end_request: I/O error, dev mmcblk0, sector 5113616
end_request: I/O error, dev mmcblk0, sector 5113624
end_request: I/O error, dev mmcblk0, sector 5113632
end_request: I/O error, dev mmcblk0, sector 5113640
end_request: I/O error, dev mmcblk0, sector 5113648
end_request: I/O error, dev mmcblk0, sector 5113656
end_request: I/O error, dev mmcblk0, sector 5113664
end_request: I/O error, dev mmcblk0, sector 5113672
end_request: I/O error, dev mmcblk0, sector 5113680
end_request: I/O error, dev mmcblk0, sector 5113688
end_request: I/O error, dev mmcblk0, sector 5113696
end_request: I/O error, dev mmcblk0, sector 5113704
end_request: I/O error, dev mmcblk0, sector 5113712
end_request: I/O error, dev mmcblk0, sector 5113720
end_request: I/O error, dev mmcblk0, sector 5113728
end_request: I/O error, dev mmcblk0, sector 5113736
end_request: I/O error, dev mmcblk0, sector 5113744
end_request: I/O error, dev mmcblk0, sector 5113752
end_request: I/O error, dev mmcblk0, sector 5113760
end_request: I/O error, dev mmcblk0, sector 5113768
mmcblk0: error -110 transferring data, sector 5155920, nr 72, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 5155921
end_request: I/O error, dev mmcblk0, sector 5155928
end_request: I/O error, dev mmcblk0, sector 5155936
end_request: I/O error, dev mmcblk0, sector 5155944
end_request: I/O error, dev mmcblk0, sector 5155952
end_request: I/O error, dev mmcblk0, sector 5155960
end_request: I/O error, dev mmcblk0, sector 5155968
end_request: I/O error, dev mmcblk0, sector 5155976
end_request: I/O error, dev mmcblk0, sector 5155984
mmcblk0: error -110 transferring data, sector 7210904, nr 16, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 7210905
quiet_error: 78 callbacks suppressed
Buffer I/O error on device mmcblk0p2, logical block 884979
end_request: I/O error, dev mmcblk0, sector 7210912
Buffer I/O error on device mmcblk0p2, logical block 884980
mmcblk0: error -110 transferring data, sector 7241736, nr 16, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 7241737
Buffer I/O error on device mmcblk0p2, logical block 888833
end_request: I/O error, dev mmcblk0, sector 7241744
Buffer I/O error on device mmcblk0p2, logical block 888834
EXT3-fs error (device mmcblk0p2): ext3_find_entry: reading directory #216064 offset 0
------------[ cut here ]------------
WARNING: at fs/inode.c:901 unlock_new_inode+0x20/0x40()
Modules linked in: usrp_e ipv6
[<c0040c7c>] (unwind_backtrace+0x0/0xe0) from [<c0060654>] (warn_slowpath_common+0x4c/0x64)
[<c0060654>] (warn_slowpath_common+0x4c/0x64) from [<c0060684>] (warn_slowpath_null+0x18/0x1c)
[<c0060684>] (warn_slowpath_null+0x18/0x1c) from [<c00d6ac0>] (unlock_new_inode+0x20/0x40)
[<c00d6ac0>] (unlock_new_inode+0x20/0x40) from [<c011138c>] (ext3_new_inode+0x868/0x89c)
[<c011138c>] (ext3_new_inode+0x868/0x89c) from [<c0117a74>] (ext3_mkdir+0xa8/0x2d0)
[<c0117a74>] (ext3_mkdir+0xa8/0x2d0) from [<c00cd6fc>] (vfs_mkdir+0x68/0x98)
[<c00cd6fc>] (vfs_mkdir+0x68/0x98) from [<c00d02c0>] (sys_mkdirat+0x80/0xcc)
[<c00d02c0>] (sys_mkdirat+0x80/0xcc) from [<c003c480>] (ret_fast_syscall+0x0/0x30)
---[ end trace 53e65c8e2ab3e159 ]---
mmcblk0: error -110 transferring data, sector 7258120, nr 16, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 7258121
Buffer I/O error on device mmcblk0p2, logical block 890881
end_request: I/O error, dev mmcblk0, sector 7258128
Buffer I/O error on device mmcblk0p2, logical block 890882
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913496
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913497
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913498
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913499
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913502
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913592
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913593
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913596
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913620
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913871
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913878
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913879
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913881
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913882
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913883
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913884
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913885
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913886
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913887
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913880
EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216210
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 892928
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 892929
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894333
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894334
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894335
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894336
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894337
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894338
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894339
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894340
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894341
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894342
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894344
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894345
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894346
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894347
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894348
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894349
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894350
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894351
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894352
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894353
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894354
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894355
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894356
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894357
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894358
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894359
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894360
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894361
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894362
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894363
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894364
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894365
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894366
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894367
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894368
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894369
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894370
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894371
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894372
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894373
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894374
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894375
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894376
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894377
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894378
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894379
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894380
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894381
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894382
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894383
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894384
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894385
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894386
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894387
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894388
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894389
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894390
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894391
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894392
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894393
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894394
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894395
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894396
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894397
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894398
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894399
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894400
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894401
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894402
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894403
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894404
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894405
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894406
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894407
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894408
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894409
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894410
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894411
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894412
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894413
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894414
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894415
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894416
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894417
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894418
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894419
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894420
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894421
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894422
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894423
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894424
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894425
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894426
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894427
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894428
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894429
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894430
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894431
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894432
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894433
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894434
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894435
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894436
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894437
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894438
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894439
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894440
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894441
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894442
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894443
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894444
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894445
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894446
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894447
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894448
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894449
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894450
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894451
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894452
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894453
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894454
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894455
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894456
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894457
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894458
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894459
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894460
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894461
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894462
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894463
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894464
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894465
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894466
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894467
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894468
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894469
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894470
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894471
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894472
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894473
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894474
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894475
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894476
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894477
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894478
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894479
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894480
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894481
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894482
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894483
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894484
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894485
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894486
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894487
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894488
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894489
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894490
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894491
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894492
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894493
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894494
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894495
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894496
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894497
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894498
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894499
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894500
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894501
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894502
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894503
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894504
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894505
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894506
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894507
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894508
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894509
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894510
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894511
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894343
EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216195
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899072
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899073
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899074
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899075
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899076
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899077
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899078
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899079
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899080
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899081
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899082
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899083
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899085
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899086
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899084
EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216206
EXT3-fs error (device mmcblk0p2): htree_dirblock_to_tree: bad entry in directory #216196: rec_len % 4 != 0 - offset=0, inode=1801675088, rec_len=26465, name_len=101
EXT3-fs (mmcblk0p2): warning: empty_dir: bad directory (dir #216196) - no .' or ..'
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 888834
EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216196
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 888847
EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216213
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 888842
EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216212
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 888846
EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216211
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 888845
EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216209
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 888844
EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216208
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 888843
EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216207
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 888833
EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216064
mmcblk0: error -110 transferring data, sector 3823096, nr 536, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 3823097
end_request: I/O error, dev mmcblk0, sector 3823104
end_request: I/O error, dev mmcblk0, sector 3823112
end_request: I/O error, dev mmcblk0, sector 3823120
end_request: I/O error, dev mmcblk0, sector 3823128
end_request: I/O error, dev mmcblk0, sector 3823136
end_request: I/O error, dev mmcblk0, sector 3823144
end_request: I/O error, dev mmcblk0, sector 3823152
end_request: I/O error, dev mmcblk0, sector 3823160
end_request: I/O error, dev mmcblk0, sector 3823168
end_request: I/O error, dev mmcblk0, sector 3823176
end_request: I/O error, dev mmcblk0, sector 3823184
end_request: I/O error, dev mmcblk0, sector 3823192
end_request: I/O error, dev mmcblk0, sector 3823200
end_request: I/O error, dev mmcblk0, sector 3823208
end_request: I/O error, dev mmcblk0, sector 3823216
end_request: I/O error, dev mmcblk0, sector 3823224
end_request: I/O error, dev mmcblk0, sector 3823232
end_request: I/O error, dev mmcblk0, sector 3823240
end_request: I/O error, dev mmcblk0, sector 3823248
end_request: I/O error, dev mmcblk0, sector 3823256
end_request: I/O error, dev mmcblk0, sector 3823264
end_request: I/O error, dev mmcblk0, sector 3823272
end_request: I/O error, dev mmcblk0, sector 3823280
end_request: I/O error, dev mmcblk0, sector 3823288
end_request: I/O error, dev mmcblk0, sector 3823296
end_request: I/O error, dev mmcblk0, sector 3823304
end_request: I/O error, dev mmcblk0, sector 3823312
end_request: I/O error, dev mmcblk0, sector 3823320
end_request: I/O error, dev mmcblk0, sector 3823328
end_request: I/O error, dev mmcblk0, sector 3823336
end_request: I/O error, dev mmcblk0, sector 3823344
end_request: I/O error, dev mmcblk0, sector 3823352
end_request: I/O error, dev mmcblk0, sector 3823360
end_request: I/O error, dev mmcblk0, sector 3823368
end_request: I/O error, dev mmcblk0, sector 3823376
end_request: I/O error, dev mmcblk0, sector 3823384
end_request: I/O error, dev mmcblk0, sector 3823392
end_request: I/O error, dev mmcblk0, sector 3823400
end_request: I/O error, dev mmcblk0, sector 3823408
end_request: I/O error, dev mmcblk0, sector 3823416
end_request: I/O error, dev mmcblk0, sector 3823424
end_request: I/O error, dev mmcblk0, sector 3823432
end_request: I/O error, dev mmcblk0, sector 3823440
end_request: I/O error, dev mmcblk0, sector 3823448
end_request: I/O error, dev mmcblk0, sector 3823456
end_request: I/O error, dev mmcblk0, sector 3823464
end_request: I/O error, dev mmcblk0, sector 3823472
end_request: I/O error, dev mmcblk0, sector 3823480
end_request: I/O error, dev mmcblk0, sector 3823488
end_request: I/O error, dev mmcblk0, sector 3823496
end_request: I/O error, dev mmcblk0, sector 3823504
end_request: I/O error, dev mmcblk0, sector 3823512
end_request: I/O error, dev mmcblk0, sector 3823520
end_request: I/O error, dev mmcblk0, sector 3823528
end_request: I/O error, dev mmcblk0, sector 3823536
end_request: I/O error, dev mmcblk0, sector 3823544
end_request: I/O error, dev mmcblk0, sector 3823552
end_request: I/O error, dev mmcblk0, sector 3823560
end_request: I/O error, dev mmcblk0, sector 3823568
end_request: I/O error, dev mmcblk0, sector 3823576
end_request: I/O error, dev mmcblk0, sector 3823584
end_request: I/O error, dev mmcblk0, sector 3823592
end_request: I/O error, dev mmcblk0, sector 3823600
end_request: I/O error, dev mmcblk0, sector 3823608
end_request: I/O error, dev mmcblk0, sector 3823616
end_request: I/O error, dev mmcblk0, sector 3823624
Aborting journal on device mmcblk0p2.
mmcblk0: error -110 transferring data, sector 3805104, nr 8, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 3805105
Buffer I/O error on device mmcblk0p2, logical block 459254
JBD: I/O error detected when updating journal superblock for mmcblk0p2.
EXT3-fs (mmcblk0p2): error: ext3_journal_start_sb: Detected aborted journal
EXT3-fs (mmcblk0p2): error: remounting filesystem read-only
WARNING: at fs/ext3/inode.c:1645 ext3_writeback_writepage+0x50/0x150()
[<c0060684>] (warn_slowpath_null+0x18/0x1c) from [<c01120f4>] (ext3_writeback_writepage+0x50/0x150)
[<c01120f4>] (ext3_writeback_writepage+0x50/0x150) from [<c00a37e8>] (__writepage+0x14/0x5c)
[<c00a37e8>] (__writepage+0x14/0x5c) from [<c00a3da4>] (write_cache_pages+0x204/0x300)
[<c00a3da4>] (write_cache_pages+0x204/0x300) from [<c00a3ee0>] (generic_writepages+0x40/0x5c)
[<c00a3ee0>] (generic_writepages+0x40/0x5c) from [<c00def6c>] (writeback_single_inode+0xa0/0x1ac)
[<c00def6c>] (writeback_single_inode+0xa0/0x1ac) from [<c00df594>] (writeback_sb_inodes+0x8c/0xfc)
[<c00df594>] (writeback_sb_inodes+0x8c/0xfc) from [<c00dfa94>] (writeback_inodes_wb+0x114/0x130)
[<c00dfa94>] (writeback_inodes_wb+0x114/0x130) from [<c00dfcb0>] (wb_writeback+0x200/0x280)
[<c00dfcb0>] (wb_writeback+0x200/0x280) from [<c00dfe50>] (wb_do_writeback+0x120/0x1b4)
[<c00dfe50>] (wb_do_writeback+0x120/0x1b4) from [<c00dff4c>] (bdi_writeback_thread+0x68/0x158)
[<c00dff4c>] (bdi_writeback_thread+0x68/0x158) from [<c00758d8>] (kthread+0x7c/0x84)
[<c00758d8>] (kthread+0x7c/0x84) from [<c003cd14>] (kernel_thread_exit+0x0/0x8)
---[ end trace 53e65c8e2ab3e15a ]---
root@usrp-e1xx:~#
Cc: "usrp-users@lists.ettus.com" usrp-users@lists.ettus.com
Sent: Friday, May 11, 2012 10:29 AM
On 05/11/2012 11:22 AM, Joel Parker wrote:
I am trying to compile OpenBTS on the E100 and am having issues downloading the code because it complains about a read-only file system. Where is a read / write area that I can download and build the source ?
What version of the root file system are you using? It like you are
seeing the MMC timeout issue. Can you look at the boot messages and see
if you see mmc timeout messages?
This is a little odd, since you (I think) just managed to install
subversion, which would need a rw file system.
Philip
root@usrp-e1xx:~# svn co http://wush.net/svn/range/software/public
A public/RRLP
A public/RRLP/trunk
A public/RRLP/trunk/MAP-CH-DataTypes.asn
A public/RRLP/trunk/rrtest
A public/RRLP/trunk/decode
A public/RRLP/trunk/MAP-ExtensionDataTypes.asn
A public/RRLP/trunk/rrlpserver.erl
A public/RRLP/trunk/testall.erl
A public/RRLP/trunk/setUpFiles.sh
A public/RRLP/trunk/MAP-ER-DataTypes.asn
A
public/RRLP/trunk/parseargs.escript
A public/RRLP/trunk/sendrrlp.escript
A public/RRLP/trunk/MAP-CommonDataTypes.asn
A public/RRLP/trunk/MAP-OM-DataTypes.asn
A public/RRLP/trunk/tests
A public/RRLP/trunk/tests/additional_assitance_data.per
A public/RRLP/trunk/tests/ms_based.per
A public/RRLP/trunk/tests/temp.per
A public/RRLP/trunk/tests/runtest.py
A public/RRLP/trunk/tests/good_pos.per
A public/RRLP/trunk/MAP-MS-DataTypes.asn
A public/RRLP/trunk/MAP-SM-DataTypes.asn
A public/RRLP/trunk/MAP-BS-Code.asn
A public/RRLP/trunk/rrlpserver.cgi
A public/RRLP/trunk/rrfake
A public/RRLP/trunk/MAP-SS-DataTypes.asn
A
public/RRLP/trunk/Makefile
A public/RRLP/trunk/testall.sh
A public/RRLP/trunk/RRLP-Components.asn
A public/RRLP/trunk/send_many_rrlp.escript
A public/RRLP/trunk/parseargsbody.erl
A public/RRLP/trunk/xrrlp.erl
A public/RRLP/trunk/MAP-SS-Code.asn
A public/RRLP/trunk/sendrrlpbody.erl
A public/RRLP/trunk/MAP-TS-Code.asn
A public/RRLP/trunk/RRLP.set.asn
A public/RRLP/trunk/MAP-Protocol.asn
A public/RRLP/trunk/README
A public/RRLP/trunk/util.erl
A public/RRLP/trunk/log2per.py
A public/RRLP/trunk/file2bin.escript
A public/RRLP/trunk/RRLP-Messages.asn
A public/RRLP/trunk/MAP-LCS-DataTypes.asn
svn: Can't change perms of file
'public/RRLP/trunk/.svn/entries': Read-only file system
USRP-users mailing list
USRP-users@lists.ettus.com
-- Joel Parker
________________________________
To: Joel Parker <joelparker27@yahoo.com>
Cc: Philip Balister <philip@opensdr.com>
Joel -
$ sudo fdisk -l
Cheers,
Ben
>-- Joel
> From: Joel Parker <joelparker27@yahoo.com>;
>To: Ben Hilburn <ben@ettus.com>;
>-- Joel Parker
> From: Ben Hilburn <ben@ettus.com>
>To: Philip Balister <philip@opensdr.com>
>Cc: Joel Parker <joelparker27@yahoo.com>
>Joel -
>Cheers,
>Ben
>On Fri, May 11, 2012 at 1:05 PM, Philip Balister <philip@opensdr.com> wrote:
>>creation script.
>>Philip
>>> -- Joel
>>> From: Philip Balister <philip@opensdr.com>
>>> Sent: Friday, May 11, 2012 12:58 PM
>>> OK, the IO errors are bad. The kernel in the 003 image fixes this. The
>>> best thing to do at the moment is make a card based on the 003 image and
>>> use that going forward.
>>> Your kernel date says you have the older version.
>>> See:
>>> http://code.ettus.com/redmine/ettus/projects/usrpe1xx/wiki/FAQ#How-do-I-create-re-create-E1xx-SD-Card-Images
>>> Philip
>>>> Collected errors:
>>>> pcpu-alloc: [0] 0
>>>> NR_IRQS:410
>>>> GPMC revision 5.0
>>>> Found NAND on CS0
>>>> TCP reno registered
>>>> OMAP DSS rev 2.0
>>>> brd: module loaded
>>>> loop: module loaded
>>>> ONFI flash detected
>>>> overo SoC init
>>>> ALSA device list:
>>>> #0: overo
>>>> mmcblk0: p1 p2
>>>> devtmpfs: mounted
>>>> Getting Chip Select
>>>> rx_dma->ch 4
>>>> tx_dma->ch 5
>>>> usrp: leaving open
>>>> Freeing gpio irq's
>>>> rx_dma->ch 5
>>>> tx_dma->ch 6
>>>> usrp: leaving open
>>>> Freeing gpio irq's
>>>> EXT3-fs (mmcblk0p2): warning: empty_dir: bad directory (dir #216196) - no `.' or `..'
>>>> root@usrp-e1xx:~#
>>>> Cc: "usrp-users@lists.ettus.com" <usrp-users@lists.ettus.com>
>>>> Philip
>>>>> A public/RRLP
>>>>> A public/RRLP/trunk
>>>>> A
>>>>> A
>>>>> _______________________________________________
>>>>> http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com
BH
Ben Hilburn
Mon, May 14, 2012 3:50 PM
Hi Joel -
I was actually just typing a response to your previous e-mail.
Unfortunately, when an SD card fails to boot, it looks very similar to bad
UART parameters. It's almost always the former, in these cases, though.
So what ended up being the problem? It's important for us to know what the
issue was so that we can take better steps to prevent it in the future =)
for openBTS :
In general, you will get better and more targeted help regarding OpenBTS
-- Joel Parker
Joel -
$ sudo fdisk -l
Cheers,
Ben
-- Joel
To: * Ben Hilburn ben@ettus.com;
Subject: * Re: [USRP-users] Read Only File System ?
Sent: * Fri, May 11, 2012 8:46:10 PM
-- Joel Parker
Joel -
this script a shot.
Cheers,
Ben
creation script.
Philip
-- Joel
See:
Philip
Downloading
Downloading
Downloading
Collected errors:
- opkg_prep_intercepts: Failed to make temp dir
pcpu-alloc: [0] 0
NR_IRQS:410
GPMC revision 5.0
Found NAND on CS0
TCP reno registered
OMAP DSS rev 2.0
brd: module loaded
loop: module loaded
ONFI flash detected
overo SoC init
ALSA device list:
#0: overo
mmcblk0: p1 p2
devtmpfs: mounted
Getting Chip Select
rx_dma->ch 4
tx_dma->ch 5
usrp: leaving open
Freeing gpio irq's
rx_dma->ch 5
tx_dma->ch 6
usrp: leaving open
Freeing gpio irq's
Philip
A public/RRLP
A public/RRLP/trunk
A
A
Hi Joel -
> for openBTS :
on the OpenBTS mailing list, here:
http://sourceforge.net/mail/?group_id=230904
You can find the sip library here:
http://www.riverbankcomputing.co.uk/software/sip/download
# python configure.py CXXFLAGS+="-march=armv7-a -mtune=cortex-a8
-mfpu=neon -mfloat-abi=softfp" CFLAGS+="-march=armv7-a
-mtune=cortex-a8 -mfpu=neon -mfloat-abi=softfp"
# make
# make install
Cheers,
Ben
> -- Joel Parker
> *From:* Ben Hilburn <ben@ettus.com>
> *To:* Joel Parker <joelparker27@yahoo.com>
> *Cc:* Philip Balister <philip@opensdr.com>
> *Sent:* Friday, May 11, 2012 5:40 PM
> *Subject:* Re: [USRP-users] Read Only File System ?
> Joel -
> $ sudo fdisk -l
> Cheers,
> Ben
> On Fri, May 11, 2012 at 3:26 PM, Joel Parker <joelparker27@yahoo.com>wrote:
> -- Joel
> * From: * Joel Parker <joelparker27@yahoo.com>;
> * To: * Ben Hilburn <ben@ettus.com>;
> * Subject: * Re: [USRP-users] Read Only File System ?
> * Sent: * Fri, May 11, 2012 8:46:10 PM
> -- Joel Parker
> *To:* Philip Balister <philip@opensdr.com>
> *Cc:* Joel Parker <joelparker27@yahoo.com>
> *Sent:* Friday, May 11, 2012 3:08 PM
> Joel -
> this script a shot.
> Cheers,
> Ben
> On Fri, May 11, 2012 at 1:05 PM, Philip Balister <philip@opensdr.com>wrote:
> creation script.
> Philip
> > -- Joel
> > See:
> > Philip
> seems to work ?
> >> Downloading
> >> Downloading
> >> Downloading
> >> Collected errors:
> >> pcpu-alloc: [0] 0
> 126976
> >> NR_IRQS:410
> 131071999ms
> >> GPMC revision 5.0
> >> Found NAND on CS0
> 1500000
> 1800000
> 3100000
> IRQ 92
> >> TCP reno registered
> >> OMAP DSS rev 2.0
> >> brd: module loaded
> >> loop: module loaded
> >> ONFI flash detected
> 1,8V 16-bit)
> ports=3
> 256/512/1024 park
> period=512 RUN
> >> overo SoC init
> >> ALSA device list:
> >> #0: overo
> (946684820)
> write-enable.
> >> mmcblk0: p1 p2
> >> devtmpfs: mounted
> >> Getting Chip Select
> 336
> 336
> 336
> >> rx_dma->ch 4
> >> tx_dma->ch 5
> >> usrp: leaving open
> >> Freeing gpio irq's
> >> rx_dma->ch 5
> >> tx_dma->ch 6
> >> usrp: leaving open
> >> Freeing gpio irq's
> 0xc00
> 0xc00
> 0xc00
> status 0xc00
> status 0xe00
> status 0xc00
> status 0xc00
> status 0xc00
> status 0xc00
> status 0xc00
> status 0xe00
> status 0xc00
> status 0xc00
> #216064 offset 0
> status 0xc00
> for inode 216210
> for inode 216195
> for inode 216206
> no `.' or `..'
> for inode 216196
> for inode 216213
> for inode 216212
> for inode 216211
> for inode 216209
> for inode 216208
> for inode 216207
> for inode 216064
> status 0xc00
> status 0xc00
> journal
> (kthread+0x7c/0x84)
> >> root@usrp-e1xx:~#
> >> Philip
> >>> A public/RRLP
> >>> A public/RRLP/trunk
> >>> A
> >>> A
PB
Philip Balister
Mon, May 14, 2012 3:59 PM
On 05/14/2012 11:44 AM, Joel Parker wrote:
I was able to get the system back up with the upgrade kernel. Thanks for your help with that. I have a new issue, I am following the instructions for openBTS : http://gnuradio.org/redmine/projects/gnuradio/wiki/OpenBTSE100
but when I run the command :
$ ./configure --with-uhd CFLAGS="-march=armv7-a -mtune=cortex-a8 -mfpu=neon -mfloat-abi=softfp -O3" CXXFLAGS="-march=armv7-a -mtune=cortex-a8 -mfpu=neon -mfloat-abi=softfp -O3"
It complains that the build requirements have not been met because it is missing libosip2 . Any idea's
how I can get this lib ?
opkg update
opkg install libosip-dev
Let me know if you have any more issues with missing packages.
Philip
opkg update
Philip
TT
Thomas Tsou
Tue, May 15, 2012 3:01 PM
opkg update
On Mon, May 14, 2012 at 11:59 AM, Philip Balister <philip@opensdr.com> wrote:
> opkg update
I have updated the wiki.
http://gnuradio.org/redmine/projects/gnuradio/wiki/OpenBTSE100#Dependencies
-Tom
BH
Ben Hilburn
Tue, May 15, 2012 4:29 PM
Tom -
Thanks!
Cheers,
Ben
opkg update
Tom -
Thanks!
Cheers,
Ben
> > opkg update
> -Tom
