Synthetic 004
Odds and Ends
QUESTIONS TO MOBIL
Claims are made that synthetic oil provides improved fuel economy because of
reduced friction. There are no SAE or API specifications available that
speak to the differences in friction between motor oils of the same
viscosity. I was interested in discussing just what physical properties
might be responsible for the reduced friction, so I made a call to the Mobil
technical staff for the answers.
I didn't get an answer that defined, in any technical sense, what those
factors were. The answers I got were about tests made on fleets of trucks,
etc. Well, of course we don't have any real means to verify those facts.
Note that there is a difference between doubting the claims and verifying
them.
They did describe a test that I can verify. They pointed out that comparing
the temperature of a closed gearbox using petroleum gear oil with the same
gearbox using synthetic gear oil would indicate the differences in the
friction of the two oils. It's strange how it all seems to come around. A
failure in a differential because of excess heat is the mother of this whole
investigation. After installing synthetic gear oil in the new differential,
it does not even get warn under full load.
HONDA?
My bride and I own two Honda Accord autos. I stopped at the local
dealership to inquire if they had synthetic oil available in connection with
their service program.
I was informed that not only did they not have it available. I was also
advised that Honda said the long-term use of synthetic oil would shorten the
life of the rear oil-seal and cause it to leak. That's pretty strong stuff.
This was word of mouth stuff from the person who checks cars in for work.
I turned to the Honda owner's manual. The official manual states that
synthetic oil is suitable for use in my Honda Accord. Remember, Look to the
Document.
Reference to the Mobil web site Delvac 1 FAQs: The answer to Question 34
provides the following: "Delvac 1 is compatible with all engine seals and
will not dry out or crack seal materials."
A call to the Mobil technical phone line confirmed that both Delvac 1 and
Mobil 1 are compatible with all engine seals. They say that synthetic oils
may be incompatible with engine seals on engines manufactured before 1980.
I feel certain that these discoveries do not apply to Mobil products alone,
but to synthetic motor oils in general. The safest procedure is to consult
the engine manual for any engine that you consider using synthetic motor oil
in. That's what I did with my Cummins. Note that I did that with my Honda
also, but I got information from an "unofficial" source that turned out to
be unreliable. Check your sources carefully.
SYNTHETIC FLOOD
Walking past the shelves of the local WalMart demonstrated just how fast the
number of full synthetic and synthetic blend motor oils is growing. There
were more of these oils than petroleum based oils.
All of these were rated API SJ, the current gasoline motor oil
specification. Some were also rated API CF, which is the diesel motor oil
specification for just a few years ago. Any of these oils rated API CF will
work fine in diesel engines who's requirements do not exceed CF. But read
the label because some do not have any diesel ratings at all.
SYNTHETIC OIL AND ANALYSIS
Since petroleum based oils and synthetic oils are formulated differently,
their analysis must be done with different parameters. It is important to
make sure the laboratory you send your samples to know just what oil you are
using. If you are using synthetic blends, talk to the laboratory before you
send them a sample to make sure they know enough about your particular
synthetic blend to do the analysis.
As reported in 003, the POA can handle full synthetic oils just fine by
adjusting the meaning of the results. For example, the reading to change
oil is 8 for synthetic oils, but 4.6 for petroleum based oils.
I am not aware that any factors have been worked out for the POA when using
synthetic blends. I suspect the factors will change depending on just what
the proportions of the blend are. At least for the time, the best procedure
is to use the factors for petroleum based oil with the blends.
CaptnWil, Ret
40 Pier Pointe
New Bern NC 28562
(252) 636-3601
captnwil@coastalnet.com
Hi Wil,
Great report, I've really enjoyed it.
I've got a couple of comments here that may help explain why synthetics have
different friction characteristics or at least why Mobil doesn't exactly
answer your question.
----- Original Message -----
of
reduced friction. I was interested in discussing just what physical
properties
Mobil
trucks,
etc
Oil company technical types take a perverse pride in the fact that theirs is
an "empirical science". They don't much care about the reason something
works, just so long as it gets the desired result. A good example of this is
tetra-ethyl-lead (anti-knock compound); Petroleum scientists can tell you,
with great precision, what effect a given amount of TEL will have on any
given refinery run of gasoline. What they cannot tell you is why it works -
even after 80 years or so of experience.
As to why synthetics have slightly better friction characteristics than
mineral oils; It probably has to do with the molecular makeup of the two
materials. I say "probably" because, as stated above, the people that design
this stuff don't really care why it works. To save a bit of typing, let me
excerpt a post I made 1-12-99 concerning the differences between synthetic
and mineral oil:
First, a definition of terms:
A mineral oil is one that comes out of the ground, is physically separated
into component parts which are then re-mixed in whatever proportions are
necessary to achieve the desired result. It follows that a mineral based
engine oil is a mixture of two or more base stocks along with an additive
package that, taken together lubricates, cools, inhibits corrosion, absorbs
contamination, transports crud to the filter, neutralizes acids, and
probably a few other things that don't immediately come to mind.
A synthetic oil is any material that does an oil type job but doesn't fit
the definition above and also isn't animal or vegetable in origin.The
synthetic oil you buy
for your boat or car engine belongs to a subset called "Synthesized
Hydrocarbon Fluids" (SHF) chemically
they are nearly identical to mineral oils.
With SHF oils the manufacturing process is radically different; rather than
physically separating and remixing a complex feedstock a simple feedstock
(natural gas) is compounded with itself until the desired molecular weight
and configuration is attained at which point an additive package is blended
in. The outcome is that SHF oils are very consistent at the molecular level
while mineral oils are a real hodge-podge.
The benefits of this molecular uniformity are mostly restricted to extreme
conditions, SHF oil performs far better than mineral oil at sub-zero
temperatures and at very high temps as well but does not show much advantage
under the operating conditions typically discussed on this list.
Another advantage that I didn't consider in that post has to do with the
problem of molecules of widely varying size getting in each other's way as
they flow through an engine (or gearbox). Because the molecules that make up
a synthetic oil are more nearly uniform in size they don't interfere with
each other as much. That results in lowered fluid friction and less heat.
These are considered to be MINOR advantages at best by most of the people
concerned with the formulation and marketing of these products. There are,
of course other economy/temperature advantages that derive from making the
oil thinner as in the 5w40 oil you cited in an earlier report. It's not
uncommon for oil marketers to claim fuel economy improvements by switching
to their product. Most often those claims are based on switching from 15w40
to 10w30. Improvements from replacing mineral 15w40 with synthetic 15w40 are
predicted (by the people selling the synthetic product) to be much more
modest.
I really hope that you find a significant mileage improvement since such
data would help us sell this stuff (demand for synthetics is flat and
miniscule).
HONDA?
In the interest of quote snipping let me summarize the conflict: Honda
service writer says no to synthetics; Honda manual says yes to synthetics;
Delvac 1 literature says it's safe for Honda.
First, your owners manual was written when the car was designed and things
change. The dealership gets a constant stream of updates as new information
comes to light about any particular model car. Ergo, it's possible that he
has some piece of info that you don't about seal compatibility. It's more
likely, however, that the service writer has been encouraged to sell the
"house brand" of oil.
Another thing to consider is that there are different tiers of lubricant
manufacturers. Major oil companies (Shell, Exxon, Mobil, etc.) are EXTREMELY
conservative with the products that they send to market. The big guys also
have the resources to thoroughly research all aspects of a new product (like
how it works with Honda seals). Smaller companies are more aggressive in
both formulation and marketing and at the same time are less able to do the
little nit-picky bits of research (again, like Honda seals).
All of this puts your Honda dealer in a difficult position: If FBN SuperSyn
10w30 has been shown to eat the seals out of the engine they obviously don't
want you to use it. They also know that there are probably other companies
marketing oils with similar formulations and they don't want you using those
either. OTOH: Honda has determined that certain Mobil products are just
fine. Catch 22 - There are legal issues with one company recommending the
products of another in this context. What you end up with is blanket
prohibitions against whole classes of products like synthetic oil.
Bottom line: If a major oil company tells you something you can be assured
that they know what they're talking about but you also have to be sure that
you are asking the right questions.
Cynically yours,
Alex
