I recently purchased a surplus HP 53131A and was surprised to see that it's
designed to stay partially powered on, with the fan running, even when the
power switch is in standby. The manual says this is for timebase
temperature stability but, since I plan to use with my Trimble Thunderbolt
as the reference source, I don't really need this feature. So, I decided
to see if I could change this.
But, unlike how Gary Sweeney accomplished this,
https://www.youtube.com/watch?v=xyFBBYZ6jXI&t=271s I wanted a mod that I
could easily undo and which wouldn't require me to hack up the existing
power switch. After looking over the schematic, I determined that the
power/standby switch is DPDT switch that's used only to enable +12 volt and
-12 volt DC power by pulling two control lines to ground. The actual power
supply is wired directly to the AC entry connector. The signal lines from
the switch enter the main board via a 26 pin ribbon cable on pins 17 and
19. So, I designed a simple PCB that breaks out these connections (and
ground) to a separate, 3 pin connector and then hard wires the +/- 12 volt
enable lines to ground.
The connector on top is intended to plug into the ribbon header connector
on the main board and the connector on the end of ribbon cable then plugs
into the lower connector.
I also designed another PCB that's going to mount inside the 53131A using
3, 3mm holes located in the rear of the unit near where the 26 pin ribbon
cable connects to the main board using nylon standoffs.
This board will contain a small, 12 volt encapsulated AC power supply
module, a relay and a pluggable connector where the AC lines will come and
go. The Mean Well IRM-01-12 power supply module I selected has a no load
power consumption <0.075W, so I think that's about as close as you get to a
true "off" switch without making a more invasive mod like Sweeney's. The
overall design is shown in the following schematic:
I'm waiting to get the PCBs back from OSH Park so, if anyone is interested
in implementing my approach in their 53131A, stay tuned and I'll let you
know how this all turns out. BTW, the parts count (excluding the PCBs) is
about $17. The switch breakout PCB costs $7.50 (for 3 copies of the board)
at OSH Park and an additional $15 for the power supply/relay board. But,
one could easily build these on .1 inch perfboard to save a few bucks. Or,
if I don't screw anything up, I'd be happy to pass on one of my 2 spare
PCBs to anyone interested.
Wayne
Hi Wayne,
Congrats on a nice simple mod !
I have both a 53131 and 181 in need of these :)
Can you share the gerbers for your PCBs and then I can cut them out on
my mill.
I could probably make a few for any interested Australians, to save on
cross pond postage.
thanks
Tim
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
Thanks! I plan to publish the Gerber files and make them available to fab
at OSH Park as part of an a article I'll put up on my webpage at
https://sites.google.com/site/wayneholder/ but I want to make sure
everything works as expected before I do. I'm still waiting for parts and
the PCBs to show up and I want to make sure every things works safely, as
AC voltages are involved. So, it make take a week, or two before I'll know
if I need to fix anything, or redo one of the PCBs.
Wayne
On Mon, May 7, 2018 at 10:27 PM, Tim Tuck timt@skybase.net wrote:
Hi Wayne,
Can you share the gerbers for your PCBs and then I can cut them out on my
mill.
cross pond postage.
thanks
Tim
it's
To unsubscribe, go to https://www.febo.com/cgi-bin/m
ailman/listinfo/time-nuts
The PCBs and Parts arrived and, after putting everything together and
testing it, it all seems to work fine. And, to document everything, I've
put up a web page at my web site that describes the mod and how to
implement it:
https://sites.google.com/site/wayneholder/hp-53131a-power-off-mod
I had two spare board sets left. One is claimed, but if someone would like
the other set, send me your address and I'll send them your way.
Wayne
Hi Wayne,
mill.
cross pond postage.
thanks
Tim
it's
Important Update: due to a mistake in my thinking, I had to upgrade the
fuse I added to a 220V, 3A model to match the fuses on the internal
switching power supply. My original plans were to mount the fuse on the
power supply PCB and use it only to fuse the small power adapter used to
power the relay. But, when there was not enough space, I decided to use
the in-line fuse adapter, instead. Completely overlooking the fact that
the in-line fuse would then need to handle the full power load.
The project page at
https://sites.google.com/site/wayneholder/hp-53131a-power-off-mod has been
updated accordingly. Sorry for the mistake and I hope this hasn't
inconvenienced anyone.
Wayne
On Fri, May 18, 2018 at 4:56 PM, Wayne Holder wayne.holder@gmail.com
implement it:
like the other set, send me your address and I'll send them your way.
Wayne
Hi Wayne,
mill.
cross pond postage.
thanks
Tim
it's
the
Thunderbolt
