The support I have been getting on this topic is overwhelming wonderful. The
shaft is out, and it looks like I will have to work on mutilating the cutlass
apart with the same respect I afforded the coupling when I needed to remove it
from the shaft. I tried to explain this situation to my wife and she said
that she didn't realize that the sawzall had become a standard mechanics tool.
She thinks she is funny.
About the thing I am calling the shaft tube*.
I am referring to the solid met housing that the cutlass lives in. It is
bolted on to the keel horizontally from the outside. Is the proper name for
this a "shaft tube" or "strut". More importantly, what else could be holding
this on after I remove the nuts? I thought maybe 5200 was keeping it in
place, but I am able to back it out about 1/8 inch. I even used heat on the
studs, thinking maybe the 5200 was sticking in the holes where the studs pass
through and not allowing it to slide out. Apparently this isn't the case.
Could this strut be part of a shaft tube that runs all the way (110 inches) to
the other end of where the shaft comes out in the engine room? And could the
packing gland in the engine compartment be holding this together?
If so, removing this whole thing would be futile as it would be too far of a
"push" to create a device to press the bearing out anyway. Also, I would have
to remove the rudder etc.., to slide it out.
It looks like I will be bloodying up the knuckles again on this one. My
concern is that I will not be able to avoid cutting into the strut/tube if I
attempt to cut the cutlass apart. Is this strut solid brass?
Please keep the support coming. I wouldn't be able to keep this boat if I had
to pay the bucks to have someone else do the work.
By the way, I did get all four new engine mounts on. Got to take your
vicotories.
Thanks, and keep the information coming. I am taking picture of everything I
am doing to help others in the future. Maybe somebody can let me know if
there is an archive a jobs like this where they would be useful
Best,
Bob.
For what its worth, My old Formosa 37 had the screwed into the shaft log.
After you remove the studs that hold it tight against the after end of the
keel you can unscrew it.
Don P. Wilson
M/V "Gaijin", Diesel Duck 44, Yokosuka, JA
http://_gaijin.homestead.com
-----Original Message-----
From: trawlers-and-trawlering-bounces@lists.samurai.com [mailto:trawlers-
and-trawlering-bounces@lists.samurai.com] On Behalf Of Robert Pelton
Sent: Saturday, April 16, 2005 8:47 PM
To: trawlers-and-trawlering@lists.samurai.com
Subject: T&T: Cutlass extraction support - Keep it coming!
for
holding
the
pass
inches)
to
the
