I installed in-line fuel pump/priming bulbs upstream of my Racors. These are valved in or out of the fuel circuit as needed. In use, you squeeze them like an outboard motor's fuel priming bulb to re-fill the racor housings. This way there is no need to carry an extra container of fuel, and all the fuel going to the engine's final filter must go through the racor's element first. I replace the filter, install the o-ring and cap, start the Tee Handle, then with the lid just slightly ajar, begin pumping fuel. When it reaches the top of the housing, finish tightening the Tee handle. Done. My cummins never miss a beat after this exercise. You can buy the kits to install these in line priming pumps from seaboard marine (sbmar.com). These guys are the diesel (esp cummins) gurus.
-----Original Message-----
From: Stan Nackdymon via Trawlers-and-Trawlering trawlers@lists.trawlering.com
Sent: May 28, 2014 5:28 PM
To: trawlers@lists.trawlering.com
Subject: T&T: FW: Question on RACORS
Shut of the pet cocks to the engine and refill the filter from the top, to
the top. That should keep fuel in the lines to the engine.
How can you suck fuel through the racor if the pump is upstream of the filter and the housing lid is cracked open. Seems like you'd only be sucking air.
Stan
Upstream, that is, before the filter. Between the tank and the filter.
You are pumping fuel from the tank INTO the filter.
Stan
It is generally recommended that pump be installed after the fuel filter and that the pump pull fuel through the filter rather than push it.
It is my understanding that placing the pump before the filter can emulsify fuel/water and reduce the effectiveness of the water separator.
Randy Thompson
M/V Soul Tender
Sent from my iPhone
On May 29, 2014, at 9:16 PM, Frank Timpano via Trawlers-and-Trawlering trawlers@lists.trawlering.com wrote:
Upstream, that is, before the filter. Between the tank and the filter. You are pumping fuel from the tank INTO the filter.
It's a squeeze bulb. I hardly imagine it will emulsify fuel and water.
Besides, as already pointed out, if it's after the filter it will be
useless to prime the filter housing.
Randy Thompson
M/V Soul Tender
Sent from my iPhone
True enuf, my misunderstanding. All I saw was the word pump.
Randy
M/V Soul Tender
On May 30, 2014, at 9:30 PM, Frank Timpano ftimpano@infionline.net wrote:
It's a squeeze bulb. I hardly imagine it will emulsify fuel and water. Besides, as already pointed out, if it's after the filter it will be useless to prime the filter housing.
Randy Thompson
M/V Soul Tender
Sent from my iPhone
