Well the actual details of the WWVB modulation and time
codes are now published.
Was just leafing through some journals while doing some
boring system configuration here...
IEEE Communications Magazine May 2014 has a paper on page 210
by Yingsi Liang, Oren Eliezer, Dinesh Rajan, John Lowe
"WWVB Time Signal Broadcast Format and Multi Mode Receiver"
Seems to tell a lot more...
Dave Emery N1PRE/AE, die@dieconsulting.com DIE Consulting, Weston, Mass 02493
"An empty zombie mind with a forlorn barely readable weatherbeaten
'For Rent' sign still vainly flapping outside on the weed encrusted pole - in
celebration of what could have been, but wasn't and is not to be now either."
and here is a more detailed description of a similar signal's
demodulation: http://caxapa.ru/thumbs/417284/Engeler_DCF77.pdf
Hi
Well that’s a bit more information. We seem to be missing the deployment schedule on the other new modulation formats. I kind of doubt that the watch and clock guys are going to start the fabs turning out millions of chips until they can test all the formats.
…… the 100 bps signals looks interesting …. Not real clear how well it will do with a <30Hz wide crystal filter.
Bob
Wonder what the consequences to my Junghans watch will be? - Regards - Mike
Mike B. Feher, EOZ Inc.
89 Arnold Blvd.
Howell, NJ, 07731
732-886-5960 office
908-902-3831 cell
-----Original Message-----
From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] On
Behalf Of Tom Van Baak (lab)
Sent: Saturday, May 31, 2014 4:14 AM
To: Discussion of precise time and frequency measurement
Subject: Re: [time-nuts] WWVB paper in May 2014 IEEE communications...
http://tf.boulder.nist.gov/general/pdf/2719.pdf
/tvb (i5s)
wrote:
Well the actual details of the WWVB modulation and time codes are
now published.
Was just leafing through some journals while doing some boring
IEEE Communications Magazine May 2014 has a paper on page 210 by
Mass 02493 "An empty zombie mind with a forlorn barely readable
weatherbeaten 'For Rent' sign still vainly flapping outside on the
weed encrusted pole - in celebration of what could have been, but wasn't
time-nuts mailing list -- time-nuts@febo.com To unsubscribe, go to
Hi
I’d say it is a safe bet that they will fiddle the way they do the various modulation formats so that the WWVB wrist watches keep working. It will be interesting to see how they do that with the “fast” modulation. I both want my watch to work and I’d like to see the fast stuff on the air for high(er) resolution timing.
Bob
89 Arnold Blvd.
Howell, NJ, 07731
732-886-5960 office
908-902-3831 cell
/tvb (i5s)
now published.
At 08:01 AM 5/31/2014, Bob Camp wrote:
Hi
Well that's a bit more information. We seem to be missing the
http://www.eversetclocks.com/press
http://www.eversetclocks.com/receivers
They claim to have shipped samples back in 2013, with production
slated for Q3. I can't find anyone selling them.
Is anyone recording or decoding the new phase modulation? If so, what
are you using?
I'm trying to measure WWVB signal quality with an old radio clock
tied to a PC parallel port. Maybe I should ask for a sample of the
ES100 or ES200 to compare.
More modulation details:
http://www.nist.gov/pml/div688/grp40/upload/NIST-Enhanced-WWVB-Broadcast-Format-1_01-2013-11-06.pdf
newell N5TNL
Hi
They tested the modulation format they now are using back in 2013. If they also tested the other formats that was done for a very brief period of time. I would think that knowing the transmission schedule of the various formats would be an important input into the chip’s design. More or less, you want to put it to sleep when the format you are after is off the air.
Bob
Hi
Well that's a bit more information. We seem to be missing the deployment schedule on the other new modulation formats. I kind of doubt that the watch and clock guys are going to start the fabs turning out millions of chips until they can test all the formats.
They claim to have shipped samples back in 2013, with production slated for Q3. I can't find anyone selling them.
Is anyone recording or decoding the new phase modulation? If so, what are you using?
I'm trying to measure WWVB signal quality with an old radio clock tied to a PC parallel port. Maybe I should ask for a sample of the ES100 or ES200 to compare.
newell N5TNL
I have been able to consistently receive the WWVB phase-modulated data of
what is now being referred to as "Normal Mode" since last summer, using an
air-wound coil antenna, multiple op-amp front end, and a PIC
microcontroller setup that I originally used for receiving the
amplitude-modulated signal.
I think that Bob Camp brings up a legitimate issue when he writes "I kind
out millions of chips until they can test all the formats."
One observation has been that data interpretation does not look altogether
simple. With the AM scheme, you could easily find the beginning of a
minute frame, just by looking for two consecutive markers. With the PSK
Normal Mode, each second begins with a 13-bit sync word. Sounds simple
enough, but if you see the sync word pattern, don't jump to any
conclusions, because the pattern will re-occur sometimes at other places
within the same minute frame. It strikes me that when product testers
develop test cases, their work is complicated by all of these "special
cases" some of which will not actually occur until decades from now.
I also wonder if the introduction of new products has been delayed because
of the seemingly capricious manner in which changes are made to the
broadcast specification. Normally, if portions of a communications
protocol are To Be Determined, we see early versions of specifications
which formally reserve certain areas or aspects that are subject to change,
so that early designers can nonetheless work around them. Who wants to put
a trademark on a product that suddenly ceases to operate when the next
unpredictable format change occurs? (Can you tell that I might be a little
frustrated?)
I've noticed that instrument manufacturers typically have quality programs
that are useful in establishing the reliability of their products. Such
manufacturers may run into a traceability problem in that the NIST's
coverage by quality programs apparently doesn't currently extend to the
Time and Frequency Division. --Steve
On Sat, May 31, 2014 at 8:01 AM, Bob Camp kb8tq@n1k.org wrote:
Hi
Bob
Mass 02493
pole - in
either."
Hi
We are in a “brave new world” of industry / government interaction. Watching how it plays out with WWVB (through real product) probably will provide a number of people with research topics for years to come. Yes it’s frustrating, a lot of it is as new to them as it is to us. I’m willing to cut them a bit of slack on that basis.
Bob
frustrated?)
Hi
Bob
Mass 02493
pole - in
either."
