Can any one give me a line on finding a replacement holding tank for an
Albin 36 trawler?
Regards, Ron on Albin 36 "Meander"
----- Original Message -----
From: trawler-world-list owner-trawler-world-list@samurai.com
To: trawler-world-list-digest@samurai.com
Sent: Friday, October 26, 2001 11:00 PM
Subject: trawler-world-list V5 #118
trawler-world-list Saturday, October 27 2001 Volume 05 : Number
118
TWL: Mantazza Cut
RE: TWL: RE: engine room temperature/venting
Re: TWL: engine room temperature/venting
TWL: Engine Room Venting
TWL: Re: Book Value???
TWL: Re: Okeechobee
TWL: Impeller puller
Re: TWL: locking
Re: TWL: Okeechobee waterway
Re: TWL: Book Value???
TWL: RE: Book Value
TWL: Perfect Boat Dog
TWL: Bilge pump oil filter
TWL: Lehman Coolers
TWL: Re: engine room temperature/venting
TWL: Unzipping bridge enclosure side curtains when docking in crosswind
TWL: Re: Perfect Boat Dog
TWL: Re: trawler-world-list V5 #117/Opinions on fan-driven engine room air
supply?
TWL: Re: Mantazza Cut
TWL: RE: Re: engine room temperature/venting
TWL: Big Weather in the Pacific
Re: TWL: Unzipping bridge enclosure side curtains when docking in
crosswind
crosswind
TWL: Re: Re: Perfect Boat Dog
TWL: Detroit 8.2L
Re: TWL: Re: Mantazza Cut
TWL: RE: Big Weather in the Pacific
TWL:Book Value???
Re: TWL: Engine Room Venting
Re: TWL: Unzipping bridge enclosure side curtains when dockingin
crosswind
TWL: Tips and Tricks
Re: TWL:Book Value???
TWL: Travel Channel -- Dangerous Ports
TWL: Dinghy crane motor & winch
Re: TWL: Travel Channel -- Dangerous Ports
Re: TWL: RE: Re: engine room temperature/venting
Date: Fri, 26 Oct 2001 01:48:39 -0400
Subject: TWL: Mantazza Cut
Hi Al,
Were on board MV Liquidity, an Offshore 62' Flushdeck drawing 5" now In
St
Augustine, FL. planning to go inside on the ICW to Ft Lauderdale.
Is this bad cut at St M 81? Please advise. Appreciate your help. We have
made it from FL to Nova Scotia and back to here without incident and don't
want one now. Thanks.
Joe Chernow
Date: Thu, 25 Oct 2001 10:43:39 -0400
Subject: RE: TWL: RE: engine room temperature/venting
At 03:53 PM 10/25/2001 -0700, Garrett Lambert wrote:
Based on this thread, I suspect the builder was right about the fan
direction,
<<< snip>>>
I suspect a trawler running at maximum speed isn't going to deliver the
kind of volume and rate that Glenn Wauss suggests is needed.
Opinions on fan-driven engine room air supply?
REPLY
All the big yachts ( 65 - 90 feet ) that I have been on lately have been
fitted with forced ventilation blowers.
Judging by the power needed to drive these, the air volume is
considerable.
Certainly a 16 inch dimater duct with a fan running at 1000 RPM moves
a
lot of air.
Evidently the designers and or engine makers have decided that forced
ventilation is necessary for both engine and passenger comfort.
Cheers
Arild
Date: Fri, 26 Oct 2001 01:59:20 EDT
Subject: Re: TWL: engine room temperature/venting
In a message dated 10/23/2001 12:11:35 PM Central Daylight Time,
mdgoode@bwr.eastlink.ca writes:
<< How do the rest of you address this? >>
With Air Conditioning!!!!!!!! Increasing your fan size may help just a
little but you probably wouldn't even notice it......Good Luck.
Trawler on,
John
Date: Fri, 26 Oct 2001 04:53:44 -0400
Subject: TWL: Engine Room Venting
At a Grand Banks rendezvous, I was lucky enough to get Bob Smith ( Ford
Lehman designer & geru) to stop by my boat. He frequently does this, and
if you are ever have the opportunity, try to get him onto your boat.
Anyway, he asked me to start the engine. I did my normal starting
routine, which included turning on the engine room blower. He said" What
did you do that for?" I mumbled something about ventilation....cool
air....and he said "Bull. The only thing you will do with that fan is
burn it out." ( Loose quote). Since then, I've only used the fan to get
rid of heat after a shut down on a summer night.
Ted Grave
GB32
Branford, CT
Date: Fri, 26 Oct 2001 04:40:08 -0500
Subject: TWL: Re: Book Value???
Hi all,
Have seen several posts on looking at used boats but were disappointed
because the boat was priced way above "book" value. What determines
"book"
value? Is it supply & demand? Is it governed by insurance interests?
Seems
to me if you have something a lot of people want but few are available,
the
price goes up. What do you think??
Cheers,
Dick
Dick Schroder
M/V Pan Handler
"Book value" doesn't address supply and demand because it doesn't know
that.
And one can insure a boat for way over the "book value". (I assume that)
it
assumes everything is still original equipment...no updates such as
expensive electronics, new dinghy/ob etc. and assuming normal wear and
tear
with minimal maintenance. There is also some price/inflation appreciation
offsetting the depreciation. It is highly arbitrary. I sold Texas Cookin'
(a clean, well maintained and equipped '84 PT 38) three months ago for 51
grand over the "book value" of 89K. So much for "book value". I had buyers
lined up and no one mentioned "book value" except my broker who thought I
was asking too much. The market rules.
Zeke Anderson
way ashore in Kerrville TX
Date: Fri, 26 Oct 2001 06:29:56 EDT
Subject: TWL: Re: Okeechobee
I just did the waterway about 3 weeks ok, it's all back to normal.
Sterling
www.captsterling.com
Date: Fri, 26 Oct 2001 06:25:05 -0500
Subject: TWL: Impeller puller
I have used the Jabisco impeller puller. It is much easier than two
screwdrivers or anything else I have used.
Be careful that you have room to use it. It is a close call on my Lehman
135.
Marty Campanell
Bay Pelican KK42
Date: Fri, 26 Oct 2001 08:15:20 -0400
Subject: Re: TWL: locking
jcj@chattanooga.net writes:
Don't be concerned about locking. Although I haven't seen the FL
locks, I know they have to be a very short lift. In any case, the
process needn't be much more complicated than docking side-to.
Escellent piece of writing. Good information. I bet a magazine like
"Living Aboard" would be happy to publish it. I put it in my "keeper"
file
George of Scaramouche1, Lake Ontario, Canada
Date: Fri, 26 Oct 2001 08:50:43 EDT
Subject: Re: TWL: Okeechobee waterway
In a message dated 10/24/01 9:59:08 PM Eastern Daylight Time,
jalexander127@home.com writes:
<< Well, to be honest, this is something new to me, I just never have had
the
fortune or misfortune, whichever is the case, to have transited a lock
before.
Congrats on the boat, Jim. One thing that made us more comfortable when
transiting a type of lock we had never seen before was to visit the lock
on
foot and if possible watch someone else go through. You can usually tie up
at
the wharf in front of the lock and walk up to it. After a while they begin
to
look alike but some are known to be difficult like lock 17 on the Erie and
lock 12 on the Champlain. Each system has different tie up conventions:
some
have hanging ropes, some have fixed cables, some have pipes or ladders,
some
have floating bollards, some have nothing and you must use the bollards
along
the top. If you are really lucky, some have beautiful young ladies who
will
throw you lines and practice their English on you. Whoa Baby!
Al Johnson
34' Marine Trader "Angelina"
Date: Fri, 26 Oct 2001 09:11:27 -0400
Subject: Re: TWL: Book Value???
At 11:08 PM 10/25/2001 -0400, Dick Schroder wrote:
Hi all,
"book"
Seems
the
Cheers,
Dick
The value of a privatly owned boat is based, in my opinuin, mostly on
emotion. Looking back on our experience when shopping, the longer the
boat
was owned and the older the owner was, the futher from reality the price.
"Don't confuse me with the facts" is the standard thinking when you tell
these people about the market and the condition of thier boat. We would
hear stories about what a great boat it was when the kids were growing up
(10 -15 years ago) The fact that it hasn't been cleaned (or run) since
then doesn't matter. I would say that the situation is worse now that
everyone with a trawler for sale thinks that everyone is selling his sail
boat and buying a trawler. It was bad out there then and I suspect it
still the same now, if not worse. As to Broker/owned boats, they beleive
there are plenty of buyers out there and I guess they (the brokers)
remember what P.T. Barnum said...jd
Joe DellaFera / Margaret Murray
36' Prairie DC "Prairie Star"
Pompano Beach, Fl.
Date: Fri, 26 Oct 2001 10:46:38 -0400
Subject: TWL: RE: Book Value
Having just completed a lengthy process of looking for and purchasing a
new
boat, I have had reason to address the issue of "Book Value" first hand
while shopping. I will say this about book values, they do serve as a
"guide" in developing the price of what a seller should ask and what a
buyer
should pay for any given model. Usually I found that boats that were
priced
way over book value were in especially good condition and loaded with
relatively new electronics and other equipment or were highly sought after
models. But this was not always the case.
There are basically about three sources of "book" value on boats. They
are
"BUC", NADA and McKnew & Parker Power Boat Guide. I usually found that
the
BUC and McKnew were usually fairly close together, usually within 10-15%.
But, NADA usually is way off, especially on older boats, sometimes as much
as 70% low. NADA is basically worthless because unlike BUC and McKnew the
values are calculated by plugging in the New cost of the boat and then
using
a computer program that automatically reduces the value year to year by
some
set percentage. Obviously this method of establishing value never takes
into
account actual market pressure for any given model.
So, using the "book" as a guide, you can at least establish a "Ballpark"
figure for where a boat will fall in value as compared to other vessels.
The one place I found where the book does matter was when I bought my last
boat, a Whitby 42 Ketch. At that time I financed a portion of the boat
through my Credit Union and they would only consider the boats NADA value
when considering the loan value for the boat. I recall at that time the
NADA book on that boat was about $55,000.00 where I paid about $90,000.00
for the boat. In discussion with the loan officer at the Credit Union I
found that they would not budge from the NADA value, regardless of the
Survey Value or any other source. Fortunately I was only financing about
50% of the purchase price anyway, so I did get the amount I needed. This
is
why when you buy a boat and need financing, especially an older model, it
is
best to stick with Banks and other financial sources that specialize in
Marine Financing as they don't normally use NADA figures.
Hope this helps to clear up some of the mystic of "book value"
Jim Alexander
Date: Fri, 26 Oct 2001 11:47:57 -0400
From: "M. Kenneth McQuage" tobyboat@worldnet.att.net
Subject: TWL: Perfect Boat Dog
Submitted only in light of our most recent discussions re: the Perfect
Boat Dog .
All the Best
Ken
How many dogs does it take to change a light bulb?
Golden Retriever
The sun is shining, the day is young, we've got our whole lives ahead of
us, and you're inside worrying about a stupid burned out bulb?
Border Collie:
Just one. And then I'll replace any wiring that's not up to code.
Dachshund:
You know I can't reach that damned stupid lamp!
Rottweiler:
Make me.
Lab:
Oh, me, me!!!! Pleeeeeeze let me change the light bulb! Can I? Can I?
Huh? Huh? Huh? Can I?
Malamute:
Let the Border Collie do it. You can feed me while he's busy.
Jack Russell Terrier:
I'll just pop it in while I'm bouncing off the walls and furniture.
Poodle:
I'll just blow in the Border Collie's ear and he'll do it. By the time
he
finishes rewiring the house, my nails will be dry.
-Doberman Pinscher:
While it's dark, I'm going to sleep on the couch.
Boxer:
Who cares? I can still play with my squeaky toys in the dark......
Mastiff:
Mastiffs are NOT afraid of the dark.
Chihuahua:
Yo quiero Taco Bulb.
Irish Wolfhound:
Can somebody else do it? I've got this hangover.....
Pointer:
I see it, there it is, there it is, right there....
Greyhound:
It isn't moving. Who cares?
Australian Shepherd:
First, I'll put all the light bulbs in a little circle....
Old English Sheep Dog:
Light bulb? I'm sorry, but I don't see a light bulb?
Hound Dog:
Z Z Z Z Z Z Z Z Z z z z z z z z
Cat:
Dogs do not change light bulbs. People change light bulbs. So the
question is how long will it be before I can expect light?
Date: Fri, 26 Oct 2001 13:16:35 -0400
A few years ago while looking for my previous boat, I spent a lot of time
with the BUC book. As I had looked over the past few years, I found that
all the values for the boats listed increased by the exact same percentage
from year to year and from model to model.
The value of anything is what a buyer and seller agree on...
Terry Hoy
Date: Thu, 25 Oct 2001 22:04:12 -0400
Subject: TWL: Bilge pump oil filter
Does anyone know the manufacturer's name of the filter used for bilge pump
outflows.
I need some technical data so a mass retailer is not too helpful.
Thanks in advance
Arild
Date: Fri, 26 Oct 2001 13:42:30 -0400
Terry,
That is a very interesting observation on the increases in value in the
BUC
book. I had been led to believe that the BUC was one book that relied
upon
Broker sale reports to establish its values.
You are certainly correct about what a boat is really worth, that being
what
a buyer and seller agree upon on any given day, however the book values
are
still useful for Ballparking various models before you actually go out and
look for one.
Jim
time
that
percentage
Terry Hoy
Date: Fri, 26 Oct 2001 11:10:07 -0700
From: "Thompson, Stuart M (Stuart)" stuartt@lucent.com
Subject: TWL: Lehman Coolers
Bear with me on this one!
I have a 66 Grand Banks42 Classic (#005) that has two different Lehman's.
Both are 120-D's and have just over 600hrs ea.on them. The Starboard eng
seems to be original and has been rebuilt. It has an injector pump that is
towards the aft of the engine, and runs off of a shaft about a foot and a
half long. The Port eng looks like a new re-power unit, and has the
injector pump forward being driven directly off a gear.
These engine differences are some times perplexing as parts like impellers
and such are different which makes me have to keep more in the way of
spares
on board.
My current issue is that I am servicing the heat exchangers and tranny/oil
coolers on both engines, and discovered that the starboard eng only has a
tranni cooler, while the port eng has both a Tranny & oil cooler! I am
contemplating adding an oil cooler but was wondering if I could get a
little
advice. The starboard eng also runs a lower oil pressure. Could this be
due
to the fact that the oil viscosity is lower due to not having an oil
cooler
installed? Was this the OEM spec for this year boat??
Please advise !!
Stuart
Date: Fri, 26 Oct 2001 14:56:12 -0400
......however the book values are
and
look for one.
True, but it leaves you in a very large ballpark. I'm of the opinion that
a
more realistic estimation of the market for a particular type of boat can
only be had by doing your own sampling, even if initially it's only a few
months of published ads and online sites.
The "books" cannot work nearly as well in the boat world as they do in the
automotive world, because the sampling is too small for any particular
type
of vessel, and the nature of the purchase (usually large) is such that the
market simply does not respond as quickly. Even in the auto world, after
NADA releases the numbers for this month, if Ford (for example) starts
aggressively leasing Explorers, it will immediately depress the used
Explorer market, and will cause smart dealers to anticipate a weakness in
the used Explorer market two years from now. The book is a ballpark at
best
for autos, and even less reliable for boats.
$0.02.......
Regards,
John Gaquin
m/v Brefnie Queen, 32' Luhrs
blocked and wrapped @
Bass River Marina, West Dennis, MA
Date: Fri, 26 Oct 2001 14:55:27 -0400
Subject: TWL: Re: engine room temperature/venting
On survey, it was noted that my boat's engine room blowers sucked air IN
rather than blowing it OUT, and it was recommended they be reversed.
My Present (a.k.a. CHB) is built the same way Garret. I asked the engine
surveyor what he thought about it later and he kind of shrugged and said
that 400hp worth of engines thumping along were capable of sucking a whole
&^%$ lot more air than the blower could force and it wouldn't really
matter
if the blower ran or not or even whether the engines sucked the air
backwards through the blower for that matter. I must say that I've tried
running the engines with the blower running or without it and don't really
see any obvious difference so I'm inclined to believe him. While I
accept
that as a common sense distillation of the situation it doesn't sit well
with my engineering view of the problem.
What I've decided to do is to put a simple reversing toggle switch in the
blower circuit. This way I can have the blower forcing air into the
engine
room while running, but switch it to exhaust when the engines aren't
running and I just want to cool out the engine space or get some
ventilation while working in there or whatever. Of course the blower
probably won't work as efficiently exhausting as it will blowing in, but
it
seems more efficient than installing two blowers. I went out and bought
the switch, but so far actually installing it is too far down the list to
do much more than contemplate it.
Finding the ground return wire has turned out to be the problem -- it
looks
like I'll just have to disconnect all the grounds at the wiring panel one
screw at a time until I find the right one.
Bill Martin
Telegraph Hill
Date: Fri, 26 Oct 2001 12:14:33 -0700
On Thu, 25 Oct 2001 23:08:25 -0400 "Dick Schroder" oilpans@thepoint.net
writes:
Hi all,
disappointed
There is no such thing as an industry wide accepted "book" or appraised
value for a boat like there is for an
automobile or real estate. Such guides as BUC, NADA, and others for
boats are useless.
Even a value assigned by a qualified surveyor is useless, it is only done
for insurance or financing purposes. Many people think that you can
apply a type of
automotive blue book value to a boat. Nothing could be further from the
truth, it is a fallacy. The ONLY true value for a boat is what an owner
is willing to sell it for and what a buyer is willing to pay for it.
Patrick
WILLARD 40PH
ALOHA
Date: Fri, 26 Oct 2001 15:17:27 -0400
Subject: TWL: Unzipping bridge enclosure side curtains when docking in
crosswind
Would there be a perceptable difference if side curtains on bridge
canvas were unzipped and allowed to flap freely when docking or
undocking in crosswind? I understand that wind velocity, vessel profile
dimensions are variables but am looking for a sense of listees opinions.
Date: Fri, 26 Oct 2001 12:24:22 -0700
Subject: TWL: Re: Perfect Boat Dog
Andy, our Boatdog, says she doesn't do fluorescent bulbs but, in the
meantime, she is herding all the incandescent ones in a large circle.
Andy's mom
on Seabird
Date: Fri, 26 Oct 2001 16:07:16 -0400
Subject: TWL: Re: trawler-world-list V5 #117/Opinions on fan-driven engine
room air supply?
I am a truck guy and the engine room is under the hood and air is sucked
into the room and therefore is positive pressure. To ventilate our
bedroom
on warm/hot summer days we suck air in. A wise gentleman once told me he
tried to cool his bedroom by sucking air out of the room. He said,
without
going into detail, it didn't work, positive presssure rules. Of course
where the air goes may produce another problem somewhere else. Tune in
next
week, same boat time, same boat channel?
FYI FWIIW.
Date: Fri, 26 Oct 2001 16:22:02 -0400
Subject: TWL: Re: Mantazza Cut
At 10:04 AM 10/26/2001 -0400, you wrote:
Can't really find a "Matanzas Cut". There is a Matanzas I snip..
Thank you all for input.
Safely made it to New Smryna Beach -Sea Love Boat Works Marina. Passed
dredge with about 5.0' and we draw 5.0'! Boat US Towing was most helpful
on VHF.
Regards,
Joe Chernow
MV Liquidity Offshore 62' `Fluishdeck.
Date: Fri, 26 Oct 2001 14:24:54 -0600
In my search/research for a boat I've run across various methods to
evaluate
boat values. Most are those that have already been listed but I found one
through a very helpful broker in San Diego. Seems that Yacht World has a
section only available to Dealers/Brokers and this section is a
compilation
of actual selling prices for boats that have been listed on Yacht
World.com.
The broker had time to kill (don't they all) so he showed it to me in
action. A search brings up sold boats and their prices. I found it truly
helpful (Amazed at how much higher asking is than selling in most cases) .
As I'm not a broker, I don't have access but for those who are searching,
you could ask a yachtworld affiliated broker to check out that section
when
you get close to purchase.
No affiliation w/YachtWorld...
Regards,
Joel Wilkins
Date: Fri, 26 Oct 2001 22:38:36 +0200
Subject: TWL: RE: Re: engine room temperature/venting
Might be a cheap idea/solution to install a thermometer in the engine
room
with clock and alarm in the Pilothouse board ? Could that also advise of a
posible fire in the engine room?
Regards
Luis / Spain
Date: Fri, 26 Oct 2001 16:34:25 -0400
helpful
on VHF.
Joe, I have other friends headed through there in the next couple of
weeks.
Was it indeed between markers 80 and 82? Many thanks.
M.J. Taylor
Lucky VII
Date: 26 Oct 2001 13:37:31 -0400
Subject: TWL: Big Weather in the Pacific
In case you have always wanted to follow the gyrations of a super typhoon,
take a look at Padou near 22 N, 154 East.
WInds 140 knots, gusts to 170. Moving north at 8 knots. Should deteriorate
into an extra tropical storm when it gets into cold water. By that time it
should be coming east towards the Pacific coast. The swell from this
thing
may do something for the US West coast. Eventually it should come ashore
if
it does not peter out completely.
The weather right now off the Oregon and Washington coasts is nothing to
enjoy while immersed in it. And may not be for at least a week. Yuk.
I will be following the weather real close since I have 2 boats going
south
as soon as there is an opening. For which I will not hold my breath, as I
might die of asphyxiation, instead of drowning. The latter being
preferable
for a real seaman. For a writer of prose the preferred method is traumatic
shock induced by visual images, with captions.
Capt. Mike Maurice
Near Portland Oregon.
Date: Fri, 26 Oct 2001 14:08:46 -0700
I believe it was Shakespeare who said, "The price of a thing is what it
will bring."
Cheers, Garrett
Date: Fri, 26 Oct 2001 17:05:32 -0400
From: Captain Al Pilvinis yourcaptain@earthlink.net
Subject: Re: TWL: Unzipping bridge enclosure side curtains when docking in
crosswind
Hi Bob........... I suggest you learn how to dock your boat with the flaps
downlike they do on Jet liners.
Captain Al Pilvinis
"M/V Driftwood"--Prairie 47
2630 N.E. 41st Street
Lighthouse Point, Fl 33064-8064
Voice 954-941-2556 Fax 954 788-2666
Email yourcaptain@earthlink.net
Website http://home.earthlink.net/~yourcaptain
Date: Fri, 26 Oct 2001 17:06:32 -0400
crosswind
I can't believe it would make much difference and the flapping would be a
distraction in my view. The most effective tool in docking in the wind is
to be aware of the direction and anticipate the effect it is going to have
on your boat. When you are first learning to dock I think the best advise
is to keep the throttles at idle but after you get the hang of it using
the
throttles to get a faster response is advisable.
Frank Burrows 1979 43' Viking MY Piney Narrows Marina Chesapeake Bay
Date: Fri, 26 Oct 2001 17:13:05 -0700
Subject: TWL: Re: Re: Perfect Boat Dog
Our Australian Sheppard is herding the fiddler crabs that crawl off the
docks onto the boat.
We sell them for fishing, $1 per dozen. Goes for dog treats.
She loves it.
docmoss
Andy's mom
on Seabird
Date: Fri, 26 Oct 2001 01:18:14 -0400
value for a boat like there is for an automobile or real estate.
REPLY
That is quite true. However, in Ontario Canada, Doug Dawson is a boat
broker who has set up a computerized business compiling listings with both
asking and selling price.
Over the past 10 -15 years this has amounted to a considerable data
base.
Doug was also smart enough to enlist the cooperation of other dealers.
Consequently, he ia able to offer a computerized search of all boats
listed in Ontario and even beyond.
With such an extensive database the financial and insurance companies
have begun asking him for values.
Because the listing includes both asking and actual selling price the
list reflects a more realistic market value than simple depreciation
would indicate.
This service to the financial community has now grown into a business
all of its own. There is a small fee for such searches.
If you are simply a buyer looking for a boat there is no fee. You pay the
usual sales commission to the broker handling the sale.
Sound like an idea which could grow to national proportions.
Cheers
BTW, no commercial interest - I just know the guy and meet him once a
year at the Toronto Boat show.
Arild
Date: Fri, 26 Oct 2001 14:30:05 -0700 (PDT)
Subject: TWL: Detroit 8.2L
I have these engines in my 37 President, have run them
for three years (100 hrs/yr). I bought the boat used,
at auction without a survey. The engines were the
unknown and I figured to have problems with them. To
date I have had no major problems. I replaced one
relay, and in three years I have not had to call a
mechanic. I have a friend who has them in a sport fish
boat and really abuses them he also has no problems.
They are a bit dirty(oil; leaks) but most Detroit s
are.
I would say they are a good engine but not a great
engine. They are not sleeved and are considered a
throw away engine but everyone I have talked to likes
them. The early models required a couple of mods, one
was return hoses on the manifolds back to the
thermostat housing, the other was a major which
increased the head bolt size.
There is also a recommendation that the gasket at the
manifold to turbo transition be checked annually. The
surfaces should be machined the first time this check
is made. Do not over heat these engines, I have
installed raw water Flow sensors to give me an edge in
this department, some people also add exhaust temp
sensors. Do not exceed the recomended 2800 RPM max
cruise speed. Change the oil regular, keep the fuel
clean and enjoy.
Tom Egan
Do You Yahoo!?
Make a great connection at Yahoo! Personals.
http://personals.yahoo.com
Date: Fri, 26 Oct 2001 18:05:28 -0400
Subject: Re: TWL: Re: Mantazza Cut
helpful
on VHF.
weeks.
M.J. Taylor
Lucky VII
M.J.,
Yes, it was indeed!
In 16 years of cruising the ICW from Brownvsille, TX, to Florida and to
Norfolk-- never seen it so shallow. Thanks for the info.
Regards,
Joe Chernow
MV Liquidity, Offshore 62 Flushdeck
Date: Fri, 26 Oct 2001 15:10:41 -0700
Subject: TWL: RE: Big Weather in the Pacific
In my role as a controller on PacSeaNet we had a vessel leave Neah Bay
yesterday for the Marquesas. The vessel INNOEY is being singlehanded.
Situation was 25 knots and 10 feet last night. This guy is a
circumnavigator name of Michael. If you want to see how bad it gets you
can
-----Original Message-----
[mailto:owner-trawler-world-list@samurai.com]On Behalf Of Michael
Maurice
Sent: Friday, October 26, 2001 10:38 AM
To: trawler-world-list@samurai.com
going south
I
preferable
traumatic
Capt. Mike Maurice
Date: Fri, 26 Oct 2001 17:50:23 -0500
Subject: TWL:Book Value???
Don't forget that LOCATION can radically influence the value of a boat.
Daniel Meyer
http://cuagain.manilasites.com
Date: Sat, 27 Oct 2001 09:15:56 +1000
Subject: Re: TWL: Engine Room Venting
Hello Ted,
26 October, 2001, 6:53:44 PM, you wrote:
TG> Anyway, he asked me to start the engine. I did my normal starting
TG> routine, which included turning on the engine room blower. He said"
What
TG> did you do that for?" I mumbled something about ventilation....cool
TG> air....and he said "Bull. The only thing you will do with that fan is
TG> burn it out." ( Loose quote).
He's entitled to his opinion Ted, but it seems to me that if you are
pulling cool air into the engine room it must do more good than harm.
He might have left unsaid that your engines may use more air than the
fan could provide.
Cheers
Glenn.
Date: Fri, 26 Oct 2001 17:13:48 -0700
Yup, based on the info, best to enlarge the engine room vents. Seems the
prudent thing to do after 21 years.
I'll do it at night tho.
My boat neighbors get nervous when they see a chain saw on the dock.
Richard
Date: Fri, 26 Oct 2001 17:31:48 -0700
Subject: Re: TWL: Unzipping bridge enclosure side curtains when dockingin
crosswind
Frank wrote: <<The most effective tool in docking in the wind is to be aware of the direction>>
I'm sure everybody does this, but for those who don't, I always check
the windex at the top of a sailboat whenever I dock to see what the wind
is doing. This has become such a habit over the years that I find
myself with binoculars in hand looking at sailboat masts even on the
calmest days in summer.
Cheers,
Gregg McKay
37 Tolly
Date: Fri, 26 Oct 2001 19:36:27 -0500
Glenn,
Think for a minute of how a diesel engine works. It compresses air and
fuel
until it burns.
Starting a cold engine you need HOT air.
My engines , PERKINS 6.354's have pre HEATERS on them to heat the
incoming cold
air for starting on cold days.
This is mho of why Bob made the comment. It is not inconceivable that I am
wrong
but those hot little glow plugs sure make starting easy on cold days( we
do have
a few of those here).
CCC
glennwaus@netspace.net.au wrote:
Hello Ted,
What
fan could provide.
Cheers
Glenn.
Charles and Pat Culotta
Patterson, La.
Web Site: http://www.geocities.com/charlesculotta/
Date: Fri, 26 Oct 2001 18:24:38 -0700
Subject: TWL: Tips and Tricks
Just went thru a shaft alignment process today that I thought some might
be
interested in. We set out to align the shafts on my 46' Alaskan which has
twin 120 Lehmans. After grunting our way thru removing the fibre shaft
coupler (used to insulate shaft from engine and protect against breakage)
we
used a feeler guage to compare spacing between the end of the shaft and
end
of the trany.
The way you determine whether a problem has to do with bent shaft or motor
out of alignment is to test to see if the uneven space moves when the
shaft
is rotated. If the space moves, it suggests a bent shaft. If the space
remains in the same place, the engine needs alignement.
Luckily for me, the space didn't move and by dropping the front of the
engine, along with a slight raise on the rear port side engine mount, the
spacing became even all the way around. Ta daaa!
Job done.
We started this job after noticing a slight 'rumble' every once in a while
when underway and I am hopeful this alignment will elliminate it.
Sorry for the poor explanation. I'll blame it on the fruit of the vine.
Cheers ... Shaun
aboard Rana III
lying Nanaimo Harbour
Date: Fri, 26 Oct 2001 21:46:22 -0400
Subject: Re: TWL:Book Value???
I have come to believe that all books on boat values should begin with "
Once upon a time ....."
Ken
Date: Fri, 26 Oct 2001 20:17:14 -0600
Subject: TWL: Travel Channel -- Dangerous Ports
I saw this on the Travel Channel for the first tme. Hour long show. Last
night was about entering the Columbia River in the NorthWest. It explained
how the Pacific blowing in and the Columbia flowing out, made the entrance
to the Columbia one of the most "Dangerous Ports". It showed the CG
playing
about in breakeers that pitched and rolled them 45 degrees. Also described
the lives of pilots, locals hired to bring the big ships into the
Columbia.
Made me glad I cruise the Chesapeake.
JimAgue
M/V Derreen, Monk 36 Trawler
Date: Fri, 26 Oct 2001 22:21:00 -0400
Subject: TWL: Dinghy crane motor & winch
The boat I just purchased has a dinghy crane atop the sundeck, but the
motor
and winch are missing. Much as I have searched on the net, I cannot find
a
source for a new one. Any one able to help here?
Jim Alexander
Date: 26 Oct 2001 20:02:10 -0400
Subject: Re: TWL: Travel Channel -- Dangerous Ports
explained
entrance
playing
Rubbish.
Columbia is the safest in bad conditions of any entrance on the coast.
The rest are all worse and I can back this up with facts. Not video hype.
Regards,
Mike
Capt. Mike Maurice
Date: Fri, 26 Oct 2001 02:40:21 -0400
Subject: Re: TWL: RE: Re: engine room temperature/venting
room
a
Regards
Luis / Spain
REPLY
The automotive indoor/outdoor thermometers are so cheap that this is
likely the best bet for remote monitoring.
However, a simple temp sensor is not a reliable fier detector.
Especially
one limited to a temp range at or less than boiling water.
Cheers
Arild
End of trawler-world-list V5 #118
Well, we may have found our trawler. I'm not sure what to do next but here
is where we stand right now. We found a nice 51' 1986 Defever offered by
Oviatt Marine. We have all the spec on it and like it very much.
Yesterday my brother went down to Hollywood, FL to look at it and he liked
it too. He felt it needed a lot of cosmetics but he is a boat builder/wood
worker and if it's not absolutely perfect he thinks it all needs to be
redone. So the fact that he thought it was a nice boat says a lot. He is
not a surveyor however, so I guess this week my husband is going to fly down
and eyeball the boat and then we need to arrange all the surveys we need.
Does anyone have the name of a good surveyor for the boat and engines? Also
any comments about the 375 hp CAT 3208 turbo aftercooled diesels?
Susan
Susan
I would call Jonathan Howe (1-954-792-6092) he works with Ed Rowe & Assc.
He did a "reinsurence survey" for us last month. All we exspected was a
quick survey to assure the Insurance Company that the boat did exsist and
that it was not about to sink. But this guy spent hours on the boat and
looked into everything (to the point of getting me upset but would have
made me happy if I was looking at the boat to buy) ) First class report.
I would use him again if I was buying a new boat...jd
Pompano Beach, Fl.
Albin 36 trawler?
http://www.ronco-plastics.com/PDF/powerwash.pdf
If you want more advice on this send to me off line. I completed a tank
replacement in a 40' last winter.
Richard
