DS
Dan Shriver
Fri, Sep 16, 2016 7:48 PM
I'm working on some code to build arches of various types.
I have some code working that builds arches using two circles (trivial).
I am now working on a general "four cirlce" arch (sometimes called "loin of
the donkey", or "ogee" arch). My solution looks like it works when the
radii are equal but the angles of intersection (among other things) are
clearly off. If the radii are not equal this becomes quickly evident (even
if they are equal and you zoom in a lot you can see there is some incorrect
overlap).
Anyone good with geometry who can point out my problem?
I also copied two routines from this list to aid me "pie_slice()" and
"point()"
module archSlice(x,y,r,fnNum,angleStarta=0, angleEnda=0, angleStartb=0,
angleEndb=0) {
translate([x,y,0]) {
pie_slice(r,angleStartb,angleEndb,fnNum);
translate([-x,y,0]) {
pie_slice(r,angleStarta,angleEnda,fnNum);
module archDbl(x,y,r,fnNum) {
intersection() {
circle(r, $fn=fnNum);
module arch(x,y,r,fnNum,angleStarta=0, angleEnda=0, angleStartb=0,
angleEndb) {
if (angleStarta == 0 && angleEnda == 0 && angleStartb == 0 && angleEndb
==0) {
difference() {
archDbl(x,y,r,fnNum);
translate([0,-r/2,0]) {
square([r,r],center=true);
else {
archSlice(x,y,r,fnNum,angleStarta, angleEnda, angleStartb, angleEndb);
module ogee(x,y,r1,r2,fnNum,width) {
angle = asin((r2+x)/(r1+r2)); //my problem is probably from how I use
this angle
x2 = x - (r1+r2)(sin(angle));
y2 = y + (r1+r2)(cos(angle));
difference() {
arch(x,y,r1,fnNum,0,angle,(180-angle),180); //for instance maybe it
shouldn't be 180-angle
arch(x,y,(r1-width),fnNum,0,angle,(180-angle),180);
translate([(x2),(y2),0]) {
difference() {
pie_slice((r2+width),(0-angle),0,fnNum);//or maybe it shouldn't
be 0-angle
pie_slice(r2,(0-angle),0,fnNum);
translate([(-2x2),0,0]) {
pie_slice(r2,180,(180+angle),fnNum);
translate([(-x2),(y2),0]) {
difference() {
pie_slice((r2+width),180,(180+angle),fnNum);//or maybe it
shouldn't be 180+angle
translate([(2x2),0,0]) {
//if you change the fourth parameter to not be equal to the third (or zoom
in) you can see
//there is incorrect overlap etc...
ogee(10,0,20,20,100,2);
module point(x,y) translate([x,y]) circle(0.01);
module pie_slice(r, a0, a1, fnNum) {
//$fa = 5;
R = r * sqrt(2) + 1;
intersection() {
hull() {
point(0,0);
for(i = [0:4])
//a = (((4 - i) * a0 + i * a1) / 4);
point(R * cos((((4 - i) * a0 + i * a1) / 4)), R *
sin((((4 - i) * a0 + i * a1) / 4)));
overlap).
"point()"
angleEndb=0) {
intersection() {
angleEndb) {
==0) {
difference() {
else {
this angle
x2 = x - (r1+r2)*(sin(angle));
y2 = y + (r1+r2)*(cos(angle));
difference() {
difference() {
be 0-angle
translate([(-2*x2),0,0]) {
difference() {
translate([(2*x2),0,0]) {
in) you can see
//$fa = 5;
intersection() {
hull() {
point(0,0);
for(i = [0:4])
R
runsun
Fri, Sep 16, 2016 9:19 PM
r1=20;
r2=40;
rotate( [0,0,-45] ){
translate([-r1,0,0]) pie_slice(r1,0,45, 50);
translate([r2,0,0]) mirror( [0,1,0]) mirror( [1,0,0]) pie_slice(r2,0,45,
50);
gives a shape:
http://forum.openscad.org/file/n18394/160916-Ogee_math.png
You can go from there.
$ Runsun Pan, PhD $ libs: doctest , faces ( git ), offline doc ( git ), runscad.py ( 2 , git ), synwrite ( 2 ); $ tips: hash ( 2 ), matrix ( 2 , 3 ), sweep ( 2 ), var ( 2 ), lerp , animation ( gif , prodVid , animlib ), precision ( 2 ), xl-control , type , rounded polygon , chfont , tailRecur ( 2, 3 ), isosphere ( 2 ), area , vol/center , RGB , CurvedImg ; $ Apps: rollApp , blockscad , openjscad , on AWS ( pdf )
View this message in context: http://forum.openscad.org/geometry-help-tp18393p18394.html
Sent from the OpenSCAD mailing list archive at Nabble.com.
This code:
> r1=20;
> r2=40;
> 50);
gives a shape:
<http://forum.openscad.org/file/n18394/160916-Ogee_math.png>
DS
Dan Shriver
Fri, Sep 16, 2016 10:49 PM
That code is infinitely more elegant than what I wrote.
I might need more help later on since I'm not sure how to make it do some
of the things I am thinking about, but I'll play around with it for now and
ask if I need more help.
On Fri, Sep 16, 2016 at 5:19 PM, runsun runsun@gmail.com wrote:
r1=20;
r2=40;
gives a shape:
Discuss@lists.openscad.org
http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
On Fri, Sep 16, 2016 at 5:19 PM, runsun <runsun@gmail.com> wrote:
> This code:
> > r1=20;
> > r2=40;
> pie_slice(r2,0,45,
> > 50);
> gives a shape:
> _______________________________________________
R
Ronaldo
Fri, Sep 16, 2016 11:03 PM
The math of your arcs:
Let O be the arc internal opening, t the arc thickness, r1 and r2 the
external radius of the lower and the internal radius of the upper circles,
then:
the center of the lower circle C1 = [ O / 2 + t - r1, 0]
the center of the upper circle C2 = [ r2, r2sin(a)+r1sin(a) ]
the concordance point CP = [C1[0] + r1cos(a), C2[1] - r2sin(a)]
where a = acos((r2 - O/2 - t - r1)/( r1 + r2 )).
This will give you the outer border of the arc. For the inner border, the
angle a is the same.
Ogee_arc.PNG http://forum.openscad.org/file/n18397/Ogee_arc.PNG
View this message in context: http://forum.openscad.org/geometry-help-tp18393p18397.html
then:
the center of the upper circle C2 = [ r2, r2*sin(a)+r1*sin(a) ]
the concordance point CP = [C1[0] + r1*cos(a), C2[1] - r2*sin(a)]
Ogee_arc.PNG <http://forum.openscad.org/file/n18397/Ogee_arc.PNG>
DS
Dan Shriver
Fri, Sep 16, 2016 11:14 PM
When you say C1[0] and C2[1] do you just mean C1 and C2 or something else?
> then:
RP
Ronaldo Persiano
Sat, Sep 17, 2016 7:31 PM
C1[0] is the first component fo C1, C2[1] the second of C2. Then:
CP = [ O / 2 + t - r1 + r1cos(a), r1sin(a)]
2016-09-16 20:14 GMT-03:00 Dan Shriver tabbydan@gmail.com:
CP = [ O / 2 + t - r1 + r1*cos(a), r1*sin(a)]
2016-09-16 20:14 GMT-03:00 Dan Shriver <tabbydan@gmail.com>:
>> then:
DS
Dan Shriver
Sun, Sep 18, 2016 1:37 AM
I'm going to play around with both solutions because runsun's is extremely
elegant but might be a huge challange to my brain to get it to do a
generalized ogee.
runsun: I'm trying to move what you did so the bottom is lying on the x
axis and the top is on the y axis. I can get the bottom on the x axis via
a translate with y value: (r2*(cos(45))) but when I try to do something
similar to get the top in line I can't get it right.
Ronaldo: I'm not sure what "first component for C1" is
On Sat, Sep 17, 2016 at 3:31 PM, Ronaldo Persiano rcmpersiano@gmail.com
generalized ogee.
On Sat, Sep 17, 2016 at 3:31 PM, Ronaldo Persiano <rcmpersiano@gmail.com>
>>> circles,
>>> then:
RP
Ronaldo Persiano
Sun, Sep 18, 2016 2:28 AM
C1 is a 2D point; it has two components or coordinates; C1[0] is the first;
C1[1] is the second.
2016-09-17 22:37 GMT-03:00 Dan Shriver tabbydan@gmail.com:
generalized ogee.
else?
2016-09-17 22:37 GMT-03:00 Dan Shriver <tabbydan@gmail.com>:
> generalized ogee.
>>> else?
>>>> circles,
>>>> then:
>>>> the
M
MichaelAtOz
Sun, Sep 18, 2016 5:35 AM
See https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/General#Vectors
Admin - PM me if you need anything, or if I've done something stupid...
Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above.
The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out!
View this message in context: http://forum.openscad.org/geometry-help-tp18393p18408.html
R
runsun
Sun, Sep 18, 2016 4:40 PM
Just translate the whole thing with the correct formula:
r1=20;
r2=40;
a =60;
translate( [0, r2*(sin(a)), 0] ){
rotate( [0,0,-a] ){
translate([-r1,0,0]) pie_slice(r1,0,a, 50);
pie_slice(r2,0,a, 50);
$ Runsun Pan, PhD $ libs: doctest , faces ( git ), offline doc ( git ), runscad.py ( 2 , git ), synwrite ( 2 ); $ tips: hash ( 2 ), matrix ( 2 , 3 ), sweep ( 2 , 3 ), var ( 2 ), lerp , animation ( gif , prodVid , animlib ), precision ( 2 ), xl-control , type , rounded polygon , chfont , tailRecur ( 2, 3 ), isosphere ( 2 ), area , vol/center , RGB , CurvedImg ; $ Apps: rollApp , blockscad , openjscad , on AWS ( pdf )
View this message in context: http://forum.openscad.org/geometry-help-tp18393p18409.html
Just translate the whole thing with the *correct* formula:
> r1=20;
> r2=40;
> a =60;
> rotate( [0,0,-a] ){
DS
Dan Shriver
Sun, Sep 18, 2016 4:56 PM
runsun I think I finally got it correct when I translated by twice the
width of the curve (at least it worked on the one case I tested). Earlier
I was trying trigonometric translations which all failed
r1=20;
r2=40;
a =60;
rotate( [0,0,-a] ){
> via
> > r1=20;
> > r2=40;
> > a =60;
> > rotate( [0,0,-a] ){
DS
Dan Shriver
Sun, Sep 18, 2016 5:54 PM
runsun: I spoke too soon translating by twice the width only works if
r1=20,r2=10,w=1. I'm trying to put the top point for the r2 pie wedge on
the y axis
r1=20;
r2=40;
a =60;
rotate( [0,0,-a] ){
the y axis
> via
> > r1=20;
> > r2=40;
> > a =60;
> > rotate( [0,0,-a] ){
R
Ronaldo
Sun, Sep 18, 2016 9:47 PM
the y axis
Well, applying my math to runsun code I got:
loin(opening=25, thickness=2, r1=25, r2=40,$fn=60);
module loin(opening, thickness, r1, r2) {
// right hand half
intersection() {
mirror([-1,0]) half_loin(opening, thickness, r1, r2);
square(2*(r1+r2));
// mirroring it
intersection() {
mirror([-1,0]) square(2*(r1+r2));
// half arc before cutting
module half_loin(opening, thickness, r1, r2) {
// my math
c1x = opening/2 + thickness - r1;
c1y = 0;
c2x = r2;
a = acos((c2x-c1x)/(r1+r2));
translate([-r1cos(a)-c1x, r1sin(a)])
// runsun's code
rotate( [0,0,-a] ){
translate([-r2,0,0]) pie_arc(r2,a,thickness);
translate([r1,0,0])
mirror( [0,1,0])
mirror( [1,0,0]) pie_arc(r1,a,-thickness);
module pie_arc(r,a,t)
difference() {
pie_slice(max(r,r+t),0,a,50);
pie_slice(min(r,r+t),0,a,50);
module pie_slice(r, a0, a1)
intersection(){
circle(r);
rotate( a0) translate([-2r,0]) square(4r);
rotate(-a1) translate([-2r,0]) square(4r);
> the y axis
> // right hand half
> intersection() {
> square(2*(r1+r2));
> // mirroring it
> intersection() {
> // my math
> c1y = 0;
> c2x = r2;
> translate([-r1*cos(a)-c1x, r1*sin(a)])
> // runsun's code
> rotate( [0,0,-a] ){
> translate([r1,0,0])
> mirror( [0,1,0])
> difference() {
> intersection(){
> circle(r);
> rotate( a0) translate([-2*r,0]) square(4*r);
> rotate(-a1) translate([-2*r,0]) square(4*r);
Note that $fn is a global variable. See the OpenSCAD manual
<https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Other_Language_Features#.24fa.2C_.24fs_and_.24fn>
View this message in context: http://forum.openscad.org/geometry-help-tp18393p18412.html
