Hi guys
I want a stable & reliable frequency standard.
I do NOT have a cesium beam.
I DO have a lot of gpsdos and some rubidiums.
Since I have one PRS-10 and this device has a 1 pps input, you already
know what I'm thinking...
What I have:
Trimble Thunderbolt
Trimble UCCM
Symmetricom UCCM
Samsung UCCM
HP 58503A
TruePosition
Oscilloquartz Star 4+
and a little board with a ublox LEA 5T and 1 pps output.
Which device is more suitable for disciplining the PRS-10?
My gps antenna setup is:
Symmetricom 58532A on the top of the water tank of my building with a
very good sky view.
A Raven Industries LA-21-1575-100-T. About 50 m of RG6.
A Symmetricom antenna distributor (don't remember the code but is the 4
outputs one)
By the way... Someone knows the delay of the inline amplifier and the
antenna distributor? (for Lady Heather)
Mark Sims is out there reading this list? I'm having problems with LH
6.14 and the UCCM units.
Any help you can give me will be welcomed.
Thanks
Luiz Alberto Saba
from Santos - São Paulo - Brazil
Hi
You have a lot of stuff that runs off of GPS L1. Any “common mode” issues
(like ionospheric disturbances) will propagate into all of them. What impact that
has on each one is very much a “that depends” sort of thing. The firmware and
filtering quickly get into the act …. They all will wander, just not in exactly the
same way.
The PRS-10 does have an internal “sync” capability. The main purpose for the
input is to simply calibrate the device from time to time. It is not really intended
to replace a GPSDO.
Any of the devices you have are fine for putting the PRS-10 on frequency to calibrate
it. All are equally likely to wander around. The PRS-10 will not help much with this wandering.
You can look at all of this with something like a TAPR TICC. To look at lots of them
at once, a set of TAPR TICC’s would be nice to have …..
Bob
On Sep 29, 2020, at 11:02 AM, Luiz Alberto Saba las@intercat.com.br wrote:
Hi guys
Since I have one PRS-10 and this device has a 1 pps input, you already know what I'm thinking...
What I have:
Trimble Thunderbolt
Trimble UCCM
Symmetricom UCCM
Samsung UCCM
HP 58503A
TruePosition
Symmetricom 58532A on the top of the water tank of my building with a very good sky view.
A Symmetricom antenna distributor (don't remember the code but is the 4 outputs one)
By the way... Someone knows the delay of the inline amplifier and the antenna distributor? (for Lady Heather)
Mark Sims is out there reading this list? I'm having problems with LH 6.14 and the UCCM units.
Thanks
Luiz Alberto Saba
time-nuts mailing list -- time-nuts@lists.febo.com
To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com
I would be curious to hear from those who have a GPS disciplined PRS 10 in their home time labs. I was never that impressed with the performance of one of mine in that configuration from a 10 MHz ADEV perspective (I did try making a few parameter changes.) I ended up essentially free running mine but would occasionally apply a 1pps signal to mine as means of adjusting its output frequency on an as needed basis.
I may try this again with a different PRS10 (the 1pps output on the unit in question failed a few years ago but I have a spare that has been recently put into service.) Perhaps the second unit will work better. Both units were obtained via the usual auction site.
Mark Spencer
mark@alignedsolutions.com
604 762 4099
On Sep 29, 2020, at 8:02 AM, Luiz Alberto Saba las@intercat.com.br wrote:
Hi guys
What I have:
Trimble Thunderbolt
Trimble UCCM
Symmetricom UCCM
Samsung UCCM
HP 58503A
TruePosition
Thanks
Luiz Alberto Saba
Look at the SRS FS740 and you get an idea how "good" the PRS10 Rb is! Bert Kehren In a message dated 9/29/2020 2:22:13 PM Eastern Standard Time, mark@alignedsolutions.com writes:
Mark Spencer
604 762 4099
Hi guys
What I have:
Trimble Thunderbolt
Trimble UCCM
Symmetricom UCCM
Samsung UCCM
HP 58503A
TruePosition
Thanks
Luiz Alberto Saba
Mark:
I don't have a PPS syncable PRS-10 yet, but will probably be getting one
within a
year or so. My expectations are not great, however, because I already know
that
the received GPS time has diurnal wiggles to the tune of up to 10's of nsec
p-p.
And I also know that the PRS-10 (and probably all others in its price
class) make
seemingly random frequency "adjustments" on a time scale of just a few
hours.
For a GPS disciplining loop to fix both, it would have to have a loop time
constant
long compared to a day on the one hand, yet a loop time constant of well
under a
day on the other. It's kind of tough to have one loop with both properties
at once.
Dana
On Tue, Sep 29, 2020 at 1:22 PM Mark Spencer mark@alignedsolutions.com
Mark Spencer
604 762 4099
wrote:
Hi guys
What I have:
Trimble Thunderbolt
Trimble UCCM
Symmetricom UCCM
Samsung UCCM
HP 58503A
TruePosition
very good sky view.
outputs one)
Thanks
Luiz Alberto Saba
Hi
On Sep 29, 2020, at 10:23 PM, Dana Whitlow k8yumdoober@gmail.com wrote:
Mark:
within a
that
p-p.
class) make
hours.
constant
under a
at once.
Dana
Rb’s do not have super duper performance at short tau. At least not compared to
reasonably good OCXO’s. An OCXO with a 1 second ADEV below 1x10^-12 is
not terribly hard to find. Your “typical” Rb ( = not a 5065) is going to be 10X worse
than that at 1 second. Indeed the PRS-10 (by design) has some interesting issues
in the 1 to 10 second region ( = it is worse than several others out there …).
If you are looking for good short term, an OCXO is cheaper to buy and cheaper
to run ( = lower power ). What you are after very much dictates what makes sense.
There is no “one size fits all” solution.
A fancy Rb GPSDO will have some method of stretching the disciplining process out
way past what anb OCXO based part would do. Some way of looking at day to day
(or couple day) readings is needed. It still will not take out all of the daily “wobble” in
GPS, but it will attenuate it some.
Indeed an L1 / L2 based part ( possibly using a ZED-F9P (or T) ) could take out all
the wobble if corrections are applied. That’s not as crazy a thing as it once was. There
would be a bit of lag to deal with so it’s not quite a slam dunk.
Since Rb’s do not typically have super temperature performance ( = they are not
a Cs standard …) some sort of solution also needs to be applied in that area if
you will be running a really long loop. Otherwise all you will do is track your
HVAC system :)
Fun !!
Bob
Mark Spencer
604 762 4099
wrote:
Hi guys
What I have:
Trimble Thunderbolt
Trimble UCCM
Symmetricom UCCM
Samsung UCCM
HP 58503A
TruePosition
very good sky view.
outputs one)
Thanks
Luiz Alberto Saba
Em 29/09/2020 14:08, Bob kb8tq escreveu:
Hi
same way.
to replace a GPSDO.
I was just wanderng what is the best thing to do, with the stuff that I
already have, in order to have a poor substitute for a cesium...
I have just one...
Bob
Hi guys
What I have:
Trimble Thunderbolt
Trimble UCCM
Symmetricom UCCM
Samsung UCCM
HP 58503A
TruePosition
Thanks
Luiz Alberto Saba
Hi
Hi
same way.
to replace a GPSDO.
I was just wanderng what is the best thing to do, with the stuff that I already have, in order to have a poor substitute for a cesium...
A GPSDO, pretty much by it’s self is the best “poor substitute for a cesium”. The biggest improvement
over a stock part would be to go to L1 / L2. Past that you get into fancy loops and a lot of work.
Bob
I have just one...
Bob
Hi guys
What I have:
Trimble Thunderbolt
Trimble UCCM
Symmetricom UCCM
Samsung UCCM
HP 58503A
TruePosition
Thanks
Luiz Alberto Saba
