time-nuts@lists.febo.com
Re: [time-nuts] 1" 14 tpi UNS die
RA
Robert Atkinson
Tue, Jul 7, 2009 8:13 PM
Try Shakespeare 4705
http://shakespeare-marine.com/mountshow.asp?findmount=4705
1" pipe slip-over to 1"-14tpi
Photo attached
Robert G8RPI
--- On Tue, 7/7/09, Arnold Tibus Arnold.Tibus@gmx.de wrote:
Subject: Re: [time-nuts] 1" 14 tpi UNS die
To: "Discussion of precise time and frequency measurement" time-nuts@febo.com
Date: Tuesday, 7 July, 2009, 7:10 PM
Nigel and the group,
this very useful adapter is what is needed and I am looking
for as well.
regards
Arnold
On Tue, 7 Jul 2009 13:53:55 EDT, GandalfG8@aol.com
wrote:
In a message dated 07/07/2009 18:43:55 GMT Daylight
Time,
writes:
I have  the same problem with several GPS
antennas, a Quadrifilar from
Raytheon,
Irvine 2640NW with mounting base, HP 58532A with
mounting base,
HP  58504Ac. etc. Some complete boxes from HP do
contain an adapter.
So this  thread is definitively a kind of
standard. The thread is fully
cylindrical,  all the plumbers tubes do use
conical threads which are not
compatible.  Very difficult to find proper
solution in the metrical Europe.
If I would  find a source of that HP-adapters I
would buy 4 units.
I did not check for  the correct naming of this
thread though.
As commented previously, this is a common fitting and
fairly standard  for
GPS antennas and some other antenna kit, especially in
a marine  environment.
A variety of adaptors is available from marine
suppliers ranging from
expensive stainless steel fittings to much cheaper
plastic, they are also
regularly listed on Ebay.
However, there doesn't seem to be anything readilly
available  which has a
collar to sit over a plain pipe, which I suspect
might  meet David's needs.
They are widely available with a flange fitting, for
mounting to flat
surfaces, or rail fittings to attach to horizontal deck
rails, but perhaps a
trawl through some of the marine suppliers might throw
up something else that
could do the job without the need for threading the end
of the pipe.
regards
Nigel
GM8PZR
-----Inline Attachment Follows-----
Try Shakespeare 4705 http://shakespeare-marine.com/mountshow.asp?findmount=4705 1" pipe slip-over to 1"-14tpi Photo attached Robert G8RPI --- On Tue, 7/7/09, Arnold Tibus <Arnold.Tibus@gmx.de> wrote: > From: Arnold Tibus <Arnold.Tibus@gmx.de> > Subject: Re: [time-nuts] 1" 14 tpi UNS die > To: "Discussion of precise time and frequency measurement" <time-nuts@febo.com> > Date: Tuesday, 7 July, 2009, 7:10 PM > Nigel and the group, > > this very useful adapter is what is needed and I am looking > for as well. > > regards > Arnold > > On Tue, 7 Jul 2009 13:53:55 EDT, GandalfG8@aol.com > wrote: > > > > >In a message dated 07/07/2009 18:43:55 GMT Daylight > Time,  > >Arnold.Tibus@gmx.de > writes: > > >I have  the same problem with several GPS > antennas, a Quadrifilar from > >Raytheon,  > >Irvine 2640NW with mounting base, HP 58532A with > mounting base, > >HP  58504Ac. etc. Some complete boxes from HP do > contain an adapter. > >So this  thread is definitively a kind of > standard. The thread is fully > >cylindrical,  all the plumbers tubes do use > conical threads which are not > >compatible.  Very difficult to find proper > solution in the metrical Europe. > >If I would  find a source of that HP-adapters I > would buy 4 units. > >I did not check for  the correct naming of this > thread though. > > > >--------------- > >As commented previously, this is a common fitting and > fairly standard  for > >GPS antennas and some other antenna kit, especially in > a marine  environment. > > > >A variety of adaptors is available from marine > suppliers ranging from  > >expensive stainless steel fittings to much cheaper > plastic, they are also  > >regularly listed on Ebay. > > > >However, there doesn't seem to be anything readilly > available  which has a > >collar to sit over a plain pipe, which I suspect > might  meet David's needs. > >They are widely available with a flange fitting, for > mounting to flat  > >surfaces, or rail fittings to attach to horizontal deck > rails, but perhaps a  > >trawl through some of the marine suppliers might throw > up something else that  > >could do the job without the need for threading the end > of the pipe. > > > >regards > > > >Nigel > >GM8PZR > >_______________________________________________ > >time-nuts mailing list -- time-nuts@febo.com > >To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > >and follow the instructions there. > > > > -----Inline Attachment Follows----- > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there.
DC
David C. Partridge
Wed, Jul 8, 2009 8:10 AM
Perfect - now to find one!
D.
-----Original Message-----
From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] On
Behalf Of Robert Atkinson
Sent: 07 July 2009 21:14
To: Discussion of precise time and frequency measurement
Photo attached
Robert G8RPI
time-nuts@febo.com
this very useful adapter is what is needed and I am looking for as
well.
regards
Arnold
Time,
writes:
Raytheon,
mounting base,
contain an adapter.
would buy 4 units.
thread though.
fairly standard  for
mounting to flat
of the pipe.
regards
Nigel
GM8PZR
time-nuts mailing list -- time-nuts@febo.com To unsubscribe, go to
Perfect - now to find one! D. -----Original Message----- From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] On Behalf Of Robert Atkinson Sent: 07 July 2009 21:14 To: Discussion of precise time and frequency measurement Subject: Re: [time-nuts] 1" 14 tpi UNS die Try Shakespeare 4705 http://shakespeare-marine.com/mountshow.asp?findmount=4705 1" pipe slip-over to 1"-14tpi Photo attached Robert G8RPI --- On Tue, 7/7/09, Arnold Tibus <Arnold.Tibus@gmx.de> wrote: > From: Arnold Tibus <Arnold.Tibus@gmx.de> > Subject: Re: [time-nuts] 1" 14 tpi UNS die > To: "Discussion of precise time and frequency measurement" > <time-nuts@febo.com> > Date: Tuesday, 7 July, 2009, 7:10 PM > Nigel and the group, > > this very useful adapter is what is needed and I am looking for as > well. > > regards > Arnold > > On Tue, 7 Jul 2009 13:53:55 EDT, GandalfG8@aol.com > wrote: > > > > >In a message dated 07/07/2009 18:43:55 GMT Daylight > Time, > >Arnold.Tibus@gmx.de > writes: > > >I have  the same problem with several GPS > antennas, a Quadrifilar from > >Raytheon, > >Irvine 2640NW with mounting base, HP 58532A with > mounting base, > >HP  58504Ac. etc. Some complete boxes from HP do > contain an adapter. > >So this  thread is definitively a kind of > standard. The thread is fully > >cylindrical,  all the plumbers tubes do use > conical threads which are not > >compatible.  Very difficult to find proper > solution in the metrical Europe. > >If I would  find a source of that HP-adapters I > would buy 4 units. > >I did not check for  the correct naming of this > thread though. > > > >--------------- > >As commented previously, this is a common fitting and > fairly standard  for > >GPS antennas and some other antenna kit, especially in > a marine  environment. > > > >A variety of adaptors is available from marine > suppliers ranging from > >expensive stainless steel fittings to much cheaper > plastic, they are also > >regularly listed on Ebay. > > > >However, there doesn't seem to be anything readilly > available  which has a > >collar to sit over a plain pipe, which I suspect > might  meet David's needs. > >They are widely available with a flange fitting, for > mounting to flat > >surfaces, or rail fittings to attach to horizontal deck > rails, but perhaps a > >trawl through some of the marine suppliers might throw > up something else that > >could do the job without the need for threading the end > of the pipe. > > > >regards > > > >Nigel > >GM8PZR > >_______________________________________________ > >time-nuts mailing list -- time-nuts@febo.com To unsubscribe, go to > >https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > >and follow the instructions there. > > > > -----Inline Attachment Follows----- > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there.
