trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
TWL: Re: Spurs
P
plkruse@iu.net
Thu, Dec 9, 1999 9:02 PM
At 06:29 PM 12/8/99 -0500, "Rick Kennerly" nh2f@abs.net wrote:
We are pretty clogged up with crab pots on the Chesapeake but I've resisted
Spurs, preferring careful navigation and attention to boat handling.
After all, what you are doing when you cut a line is dropping a perpetual
killing machine to the bottom--crabs die, attracts other crabs to the pot,
which die, which attracts other crabs.  Same for lobsters.  We can make all
kinds of arguments about whether the crabber should this or shouldn't that,
but we're in it for the recreation, he's trying to feed mouths.  And we're
the one who ultimately drop these killing machines to the bottom.
Thanks for the different point of view, Rick.  It seems to be a well
balanced one.
This area here is also pretty "clogged" with crab pots; yet, our whole
family has been boating here for three decades without even one of us ever
picking up a crab pot.  Frankly, they are not that hard to miss; so long as
you keep a careful watch for them.
As for being a "perpetual killing machine," however; I don't think you have
much to worry about.  I've pulled a lot of abandoned crab pots out of our
local waters over the years; and I've seen hundreds of others while diving.
Never once have I ever seen a crab (dead or alive) in one of them.
Naturally, my observations are limited to Blue Crabs only, and then only
with the type of trap commonly used in our area.  I cannot say if the same
thing is true of other species or other trap types; but at least here it
does not seem to be a concern.
I've never had spurs on a boat; but they do seem to be a good idea.  We will
probably put them onto Doulos I, which is being set up as a commercial
troller/trapper.  We won't be running any of those shallow water traps that
you are concerned about; but rather we are exploring some deep water
trapping technologies.  You won't have to worry about hitting our traps; but
if I snag my own line on my propeller shaft, I think that I would want the
spurs.  The traps are expensive enough that if I do cut my own line, that
I'll certainly put the effort into recovering the trap.  :-)
BTW:  If fish traps are being used in your area, they will continue to catch
fish forever.  They are no longer used down here, but I cannot say for sure
where else they might still be used.
Paul and Cindy Kruse      ::  KJV Joh 14:27 Peace I leave with you,
165 South Kenneth Court    ::  my peace I give unto you:
Merritt Island, FL  32952  ::  not as the world giveth, give I unto you.
E-mail:  plkruse@iu.net    ::  Let not your heart be troubled,
407-453-6206              ::  neither let it be afraid.
At 06:29 PM 12/8/99 -0500, "Rick Kennerly" <nh2f@abs.net> wrote: >We are pretty clogged up with crab pots on the Chesapeake but I've resisted >Spurs, preferring careful navigation and attention to boat handling. > >After all, what you are doing when you cut a line is dropping a perpetual >killing machine to the bottom--crabs die, attracts other crabs to the pot, >which die, which attracts other crabs. Same for lobsters. We can make all >kinds of arguments about whether the crabber should this or shouldn't that, >but we're in it for the recreation, he's trying to feed mouths. And we're >the one who ultimately drop these killing machines to the bottom. Thanks for the different point of view, Rick. It seems to be a well balanced one. This area here is also pretty "clogged" with crab pots; yet, our whole family has been boating here for three decades without even one of us ever picking up a crab pot. Frankly, they are not that hard to miss; so long as you keep a careful watch for them. As for being a "perpetual killing machine," however; I don't think you have much to worry about. I've pulled a lot of abandoned crab pots out of our local waters over the years; and I've seen hundreds of others while diving. Never once have I ever seen a crab (dead or alive) in one of them. Naturally, my observations are limited to Blue Crabs only, and then only with the type of trap commonly used in our area. I cannot say if the same thing is true of other species or other trap types; but at least here it does not seem to be a concern. I've never had spurs on a boat; but they do seem to be a good idea. We will probably put them onto Doulos I, which is being set up as a commercial troller/trapper. We won't be running any of those shallow water traps that you are concerned about; but rather we are exploring some deep water trapping technologies. You won't have to worry about hitting our traps; but if I snag my own line on my propeller shaft, I think that I would want the spurs. The traps are expensive enough that if I do cut my own line, that I'll certainly put the effort into recovering the trap. :-) BTW: If fish traps are being used in your area, they will continue to catch fish forever. They are no longer used down here, but I cannot say for sure where else they might still be used. +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ :: Paul and Cindy Kruse :: KJV Joh 14:27 Peace I leave with you, 165 South Kenneth Court :: my peace I give unto you: Merritt Island, FL 32952 :: not as the world giveth, give I unto you. E-mail: plkruse@iu.net :: Let not your heart be troubled, 407-453-6206 :: neither let it be afraid. :: +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
N
nh2f@abs.net
Fri, Dec 10, 1999 9:34 AM
=  I cannot say if the same
=thing is true of other species or other trap types; but at least here it
=does not seem to be a concern.
Depends on state law and local custom.  Some areas require a light twine be
used on one side of the trap.  Then if the trap is lost, the twine rots out,
allowing one side of the trap to fall open.  I think Maine has something
similar for lobster pots.  I've pulled up obviously lost or abandoned pots
here on the Chesapeake and found them teeming with crabs.
Rick
= I cannot say if the same =thing is true of other species or other trap types; but at least here it =does not seem to be a concern. = Depends on state law and local custom. Some areas require a light twine be used on one side of the trap. Then if the trap is lost, the twine rots out, allowing one side of the trap to fall open. I think Maine has something similar for lobster pots. I've pulled up obviously lost or abandoned pots here on the Chesapeake and found them teeming with crabs. Rick
