This very issue really bugs me (lightly loaded generator for charging or coffee/tv/blender/microwave). I am installing/upgrading my house battery/inverter system, but the challenge of recharging when on the hook (no propulsion engine use) for an extended anchorage (like this past weekend at Cape Lookout) is still there. I now use a small old 1000 watt gas portable Honda ($150 used) to run my 40 amp charger (~6 amps wide open at 120vac) and fridge (~200 watts). Runs ~4 hours on .8 gals. A little noisy, watch for CO, real peace of mind as backup. If it falls overboard or dies, I will cry but not die! I run the $10k 8kw when I cook on range, run A/C, make hot water, which is not often.
Downside? I look like a blow-boater!!
Ideal would be a small, inexpensive, installed 1200 watt diesel 12vdc genset. No charger loss and speed would match load. Note I said inexpensive. Air cooling would simplify greatly. Anybody know of a good one? I am thinking about developing one.
Regards, Jim
Expect typos - sent from my iPhone
On Jul 19, 2011, at 12:00 PM, trawlers-request@lists.trawlering.com wrote:
by bringing the
battery back to a complete full charge - not an easy thing to do at
anchor unless one wants to run a lightly loaded generator for seemingly
endless hours.
Regards, Jim
> by bringing the
> endless hours.
