Hey,
I think this below error is a link error:
Undefined reference to 'pjsua_invite'.
I run pjproject-1.3 with GNU compiler. I checked all the libraries, but
still I get this error.
How to solve it?
Any help!
Thanks!
Can you post some more information? A copy & paste of (1) the command
you run that generates the error, (2) the last, say, 50 lines of
output (more if you think it'll help) will help greatly! Also, what
architecture are you building on? Are you cross-compiling?
John G
On Thu, Sep 10, 2009 at 3:44 PM, Rachel Baskaran
rachelbaskaran@gmail.com wrote:
Hey,
How to solve it?
Any help!
Thanks!
Visit our blog: http://blog.pjsip.org
pjsip mailing list
pjsip@lists.pjsip.org
http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org
The script I run:( I highlighted the command where it shows the error )
#include <pjsua-lib/pjsua.h>
#include "getopt.h"
#include <stdlib.h>
#define THIS_FILE "rach.c"
#define SIP_DOMAIN "example.com"
#define SIP_USER "rachel"
#define SIP_PASSWD "secret"
static pjsip_inv_session *inv_session;
/* Notify UI when invite state has changed */
void pjsua_ui_inv_on_state_changed(pjsip_inv_session *inv, pjsip_event *e)
const char *state_names[] =
"NULL", "CALLING",
"INCOMING","EARLY","CONNECTING","CONFIRMED","DISCONNECTED","TERMINATED"};
PJ_UNUSED_ARG(e);
PJ_LOG(3,(THIS_FILE, "Invite session state changed to %s",
state_names[inv->state]));
if(inv->state == PJSIP_INV_STATE_DISCONNECTED) {
if(inv == inv_session)
inv_session = NULL;
else
inv_session = inv;
static void ui_help(void)
puts("");
puts("Console keys:");
puts("m Make a call/another call");
puts("a Answer incoming call");
puts("h Hangup current call");
puts("q Quit");
puts("");
fflush(stdout);
static pj_bool_t input(const char *title,char *buf, pj_size_t len)
char *p;
printf("%s (empty to cancel):", title);
fflush(stdout);
fgets(buf, len, stdin);
/* Remove newlines */
for(p=buf; ;++p)
if(*p =='\r' || *p =='\n') *p='\0';
else if(!*p)
break;
if(!*buf)
return PJ_FALSE;
return PJ_TRUE;
static void error_exit(const char *title, pj_status_t status)
pjsua_perror(THIS_FILE, title, status);
pjsua_destroy();
exit(1);
static void ui_console_main(void)
char buf[128];
pjsip_inv_session *inv;
//ui_help();
for(;;)
ui_help();
fgets(buf, sizeof(buf), stdin);
switch (buf[0]) {
case 'm':
if(inv_session != NULL) {
puts("Can not make call while another one is in progress");
fflush(stdout);
continue;
#if 1
/* Make call!: */
if(!input("Enter URL to call", buf, sizeof(buf)))
continue;
pjsua_invite(buf, &inv);
#else
pjsua_invite("sip:localhost:5061", &inv);
#endif
break;
case 'a':
if(inv_session == NULL || inv_session->role != PJSIP_ROLE_UAS ||
inv_session->state >= PJSIP_INV_STATE_CONNECTING)
puts("No pending incoming call");
fflush(stdout);
continue;
else
pj_status_t status;
pjsip_tx_data *tdata;
if(!input("Answer with code (100-699)", buf, sizeof(buf)))
continue;
status = pjsip_inv_answer(inv_session, atoi(buf) ,NULL,NULL, &tdata);
if(status == PJ_SUCCESS)
status = pjsip_inv_send_msg(inv_session, tdata);
if(status != PJ_SUCCESS)
error_exit("Unable to create/send response", status);
break;
case 'h':
if(inv_session == NULL) {
puts("No current call");
fflush(stdout);
continue;
else
pj_status_t status;
status = pjsip_inv_end_session(inv_session, PJSIP_SC_DECLINE, NULL, &tdata);
if(status != PJ_SUCCESS) {
error_exit("Failed to create end session message", status);
continue;
error_exit("Failed to send end session message", status);
continue;
break;
case 'q':
goto on_exit;
on_exit:
All I want my script to do is call the specified URL in* else* part( when
they run the script ) or when I press 'm' call the URL I enter. This just
the part of code. It registers to example.com( since it's test after few
mins it says timeout )
The only line on my shell prompt is:
output/rach-i686-pc-mingw32/rach.o:rach.c(.text+0x4cf): Undefined reference
to 'pjsua_invite'.
All I did when I downloaded the source from pjsip.org, is installed GNU
compiler( Mingw, msys ) and in shell prompt gave the below command:
cd C:/pjproject-1.3
./configure
./make dep && make clean && make
To run the pjsua:
cd pjproject-1.3/pjsip-apps/bin
./pjsua-i686-pc-mingw32
and that ran the pjsua_app.
Since I need a script to suit my requirement I went to write my own.
It would be great if you'll help me out.
Thanks!
On Thu, Sep 10, 2009 at 10:55 AM, John Graham <
John G
Hey,
How to solve it?
Any help!
Thanks!
pjsip mailing list
pjsip mailing list
What's the command-line when you compile? Are you compiling with -Wall
and -Werror?
Grepping through my include/ and lib/ directories for pjproject-1.3, I
can't find a function in any header file or object in any of the
libraries called pjsua_invite - if you compiled without -Werror, the
compiler probably only spat out a warning of an implicit declaration
and left the error for the linker to find. Try recompiling with
-Werror or just search for warnings to this effect.
I've not used past versions of this library - could this be a function
you're using from an old API?
John G
On Thu, Sep 10, 2009 at 4:16 PM, Rachel Baskaran
#include "getopt.h"
#include <stdlib.h>
"NULL", "CALLING",
PJ_UNUSED_ARG(e);
inv_session = NULL;
else
inv_session = inv;
puts("");
puts("q Quit");
puts("");
fflush(stdout);
char *p;
fflush(stdout);
for(p=buf; ;++p)
else if(!*p)
break;
if(!*buf)
return PJ_FALSE;
return PJ_TRUE;
pjsua_destroy();
exit(1);
char buf[128];
//ui_help();
for(;;)
ui_help();
switch (buf[0]) {
case 'm':
fflush(stdout);
continue;
#if 1
/* Make call!: */
continue;
#else
#endif
break;
case 'a':
fflush(stdout);
continue;
else
pj_status_t status;
continue;
break;
case 'h':
fflush(stdout);
continue;
else
pj_status_t status;
continue;
continue;
break;
case 'q':
goto on_exit;
on_exit:
All I want my script to do is call the specified URL in else part( when they
run the script ) or when I press 'm' call the URL I enter. This just the
part of code. It registers to example.com( since it's test after few mins it
says timeout )
to 'pjsua_invite'.
cd C:/pjproject-1.3
./configure
To run the pjsua:
Thanks!
John G
Hey,
How to solve it?
Any help!
Thanks!
pjsip mailing list
pjsip mailing list
pjsip mailing list
The way I compile my script:
cd C:/pjproject-1.3
make
If successful, it places the executable in
(pjsip-apps/bin/rach/i686-pc-mingw32)
as rach.exe and when I run the exe it registers blah blah...
I'm not aware about the command to compile with -Wall and -Werror?
How I give the command after cd C:/pjproject-1.3? And if the warning or
error still exists how to solve it?
Thanks!
On Thu, Sep 10, 2009 at 11:31 AM, John Graham <
and -Werror?
John G
#include "getopt.h"
#include <stdlib.h>
*e)
"NULL", "CALLING",
PJ_UNUSED_ARG(e);
inv_session = NULL;
else
inv_session = inv;
puts("");
puts("q Quit");
puts("");
fflush(stdout);
char *p;
fflush(stdout);
for(p=buf; ;++p)
else if(!*p)
break;
if(!*buf)
return PJ_FALSE;
return PJ_TRUE;
pjsua_destroy();
exit(1);
char buf[128];
//ui_help();
for(;;)
ui_help();
switch (buf[0]) {
case 'm':
fflush(stdout);
continue;
#if 1
/* Make call!: */
continue;
#else
#endif
break;
case 'a':
fflush(stdout);
continue;
else
pj_status_t status;
continue;
break;
case 'h':
fflush(stdout);
continue;
else
pj_status_t status;
&tdata);
continue;
continue;
break;
case 'q':
goto on_exit;
on_exit:
they
mins it
says timeout )
reference
to 'pjsua_invite'.
cd C:/pjproject-1.3
./configure
To run the pjsua:
Thanks!
John G
Hey,
but
How to solve it?
Any help!
Thanks!
pjsip mailing list
pjsip mailing list
pjsip mailing list
pjsip mailing list
Try running:
make CFLAGS='-Wall -Werror'
Remember to resave your source file (or run "touch path/to/file.c" or
whatever) to ensure make thinks it should rebuild it.
But like I said, I can't see pjsua_invite() defined anywhere - where
are you getting that from?
John G
On Thu, Sep 10, 2009 at 4:57 PM, Rachel Baskaran
cd C:/pjproject-1.3
make
Thanks!
I found it when I goggled. It was script (main.c) written by 2003-2006
Benny Prijono.
Maybe that's why we couldn't find definition, can I replace it with any
other syntax?
I compile as you have told and post it here.
Rachel
On Thu, Sep 10, 2009 at 12:08 PM, John Graham <
Try running:
John G
cd C:/pjproject-1.3
make
Thanks!
pjsip mailing list
Alright this time my error:
cd C:/pjproject-1.3
../src/rach/rach.c:In function 'ui_console_main'
../src/rach/rach.c:117:warning :implicit declaration of function
'pjsua_invite'
Is there any way to just change the call part to work in the script I
attached, coz I have to make this working.
Rachel
On Thu, Sep 10, 2009 at 12:12 PM, Rachel Baskaran
Benny Prijono.
other syntax?
Rachel
Try running:
John G
cd C:/pjproject-1.3
make
Thanks!
pjsip mailing list
You could copy the current code that function called (one version
(don't know if it's the latest) is in
http://svn.pjsip.org/repos/pjproject/tags/0.5.0-before-conf/pjsip/src/pjsua/pjsua_inv.c)
or search through the library to find a suitable function/set of
functions.
John G
On Thu, Sep 10, 2009 at 5:34 PM, Rachel Baskaran
cd C:/pjproject-1.3
'pjsua_invite'
Rachel
Oh now It gives me this error:
make[2]: Entering dir '/c/pjproject-1.3/pjsip-apps/build'
make[2]:'../bin/pjsua-i686-pc-mingw32' is up to date
make[2]: leaving
make -f Samples.mak
make[2]: Nothing to be done for 'all'
make[2]: Leaving dir '/c/pjproject-1.3/pjsip-apps/build'
I have my folder rach in pjsip-apps/src/rach.
Samples.mak(pjsip-apps/build)
include ../../build/common.mak
export _CFLAGS := $(PJ_CFLAGS) $(CFLAGS)
export _CXXFLAGS:= $(PJ_CXXFLAGS)
export _LDFLAGS := $(PJ_LDFLAGS) $(PJ_LDLIBS) $(LDFLAGS)
SRCDIR := ../src/rach
OBJDIR := ./output/rach-$(TARGET_NAME)
BINDIR := ../bin/rach/$(TARGET_NAME)
rach := simple_pjsua
rach
EXES := $(foreach file, $(rach), $(BINDIR)/$(file)$(HOST_EXE))
Previously it was working but now it doesn't . what am I missing?
I'll check out the code.
Rachel
On Thu, Sep 10, 2009 at 1:21 PM, John Graham <johngavingraham@googlemail.com
functions.
John G
cd C:/pjproject-1.3
'pjsua_invite'
Rachel
pjsip mailing list
