DR
David Reagan
Mon, Mar 15, 2021 8:03 PM
Hey everyone,
During the town hall I asked about implementing a way to sync settings
between different instances of TB.
I just read through the old bug report, and I'm not sure that's the best
place to continue the discussion. That bug report
(https://bugzilla.mozilla.org/show_bug.cgi?id=446444) seems very focused
on using the Firefox Sync method. A couple other methods came up in the
town hall discussion.
Would it be better to have a discussion about the pros and cons of the
different sync methods here (maildev)? Or maybe a new bug report? Or on
discourse.mozilla.org?
Specifically, the pros and cons of using: Firefox Sync (or some kind of
server based system), an integrated peer-to-peer daemon, or just a solid
manual export/import tool.
Thanks again for talking the idea over.
(Oh, and I said FF Sync's docs were bad in the town hall chat, that is
no longer the case. :D https://github.com/mozilla-services/syncserver)
Hey everyone,
- David Reagan
T
Tanstaafl
Tue, Mar 16, 2021 7:50 PM
Hey David,
If I'm not mistaken, this is something that the new JMAP protocol could
implement quite easily. I know it is designed to be able to save
Contacts and Calendars to the JMAP server, so if not immediately, could
likely easily be extended to do so.
On 3/15/2021 4:03 PM, David Reagan wrote
Hey everyone,
Maildev mailing list -- maildev@lists.thunderbird.net
To unsubscribe send an email to maildev-leave@lists.thunderbird.net
Hey David,
> Hey everyone,
> - David Reagan
> _______________________________________________
MM
Magnus Melin
Tue, Mar 16, 2021 7:56 PM
Firefox put many many, many, man years of work into Firefox sync. If we
want a sync solution, certainly it would make sense to use that same
code. That's why it's been the focus of the discussion: if you want
something else, you'd have to put up a good plan, and have a really
good argument why spending resources on that alternative approach would
make sense.
-Magnus
On 2021-03-15 22:03, David Reagan wrote:
Hey everyone,
best place to continue the discussion. That bug report
focused on using the Firefox Sync method. A couple other methods came
up in the town hall discussion.
on discourse.mozilla.org?
of server based system), an integrated peer-to-peer daemon, or just a
solid manual export/import tool.
something else, you'd have to put up a good plan, and have a *really*
make sense.
-Magnus
> Hey everyone,
> - David Reagan
T
Tanstaafl
Tue, Mar 16, 2021 8:09 PM
I strongly disagree.
Why intentionally do anything that ties TB even further to the Mozilla
code base?
We have resources now. We should be doing everything possible to gain
independence from Mozilla, this would do exactly the opposite.
Implement JMAP, then implement a sync protocol/system on top of it for
syncing settings, that is not reliant on Mozilla, or any other protocol
or service, one that 'just works' with any JMAP server (build it and
they will come). Timo has already plainly stated that a) he is
interested in adding JMAP support to dovecot, but b) it is not a high
priority for him because there are no clients out there that could use
it. If TB supported it, that would eliminate that 'excuse' - not that he
is using it as an excuse, it is just the reality - but a reality that
you, the TB Council/Devs, can change.
TB could do something really amazing here... take a leap of faith... be
the first...
Hell, what I would do if I were on the Board is start talks with
Fastmail to build some kind of partnership where TB makes it easy for
people to create Fastmail accounts, free at first (maybe these could be
either @fastmail or @thunderbird.net addresses), but with some paid
tiers, the revenues of which are shared between Fastmail and TB. Paid
tiers could provide any number of extras/goodies, from more storage, to
unlimited storage, multiple email addresses, and even bring your own
domain, all of which are able to take full advantage of the goodness of
JMAP.
I do not want to store my stuff on anything of Mozilla's.
Charles
make sense.
-Magnus
Hey everyone,
code base?
the first...
JMAP.
Charles
> make sense.
> -Magnus
>> Hey everyone,
>> - David Reagan
MM
Magnus Melin
Tue, Mar 16, 2021 8:22 PM
Using what's most suitable is a per-requisite for success.
The Firefox Sync code is open source, and can even be run independently,
not that it probably would make any sense. You're free to run a sync
server and store your stuff there.
Our resources are not at all abundant. To recreate sync properly you'd
have to put all the resources onto only that. Seems rather pointless
if you ask me.
JMAP is a completely different discussion. All mails, calendars and
address books can already be stored on the servers with the solutions we
have. This discussion was about sync of account prefs and such.
-Magnus
code base?
protocol or service, one that 'just works' with any JMAP server (build
it and they will come). Timo has already plainly stated that a) he is
he is using it as an excuse, it is just the reality - but a reality
that you, the TB Council/Devs, can change.
be the first...
be either @fastmail or @thunderbird.net addresses), but with some paid
to unlimited storage, multiple email addresses, and even bring your
own domain, all of which are able to take full advantage of the
goodness of JMAP.
Charles
make sense.
-Magnus
Hey everyone,
no longer the case. :Dhttps://github.com/mozilla-services/syncserver)
Maildev mailing list --maildev@lists.thunderbird.net
To unsubscribe send an email tomaildev-leave@lists.thunderbird.net
have to put *all* the resources onto only that. Seems rather pointless
if you ask me.
-Magnus
> code base?
> be the first...
> goodness of JMAP.
> Charles
>> make sense.
>> -Magnus
>>> Hey everyone,
>>> - David Reagan
DR
David Reagan
Thu, Mar 18, 2021 2:08 AM
Looks like the discussion is happening here. Ok. :)
Option number one is something based on Firefox sync.
It's not my favorite method.
I actually avoided Firefox sync for years. I only started using it when
Xmarks bit the dust. I strongly believe that I should be able to control
my own data, and I don't like trusting anyone else with it unless I have
to. As in I run my own email server and avoid third-party services as
much as I can.
When I first heard you could host your own Firefox sync server, I looked
into it, and promptly ran into a wall of no docs, and not enough time to
figure it out from the code. It looks like that issue may be fixed. So
that's definitely on my todo list to look into again.
So the cons (imo):
- Adding another third party having access to my data, or having to
host yet another tool for myself.
o This would be especially worrisome since I'd really have to
evaluate the security of FF sync. I've avoided that by not
syncing passwords in FF...
- Needing to send my data out of my LAN in order for it to sync.
o Related, not being able to sync without general internet access.
Yes, for me it is rare, but for someone out on the seas, or
somewhere with slow internet? Having to sync via the Internet
could be frustrating.
- TB would need to use Mozilla's servers, or host their own, for those
users who aren't willing to put the effort into being secure I am.
The pros:
- Code for syncing already exists.
- TB already has work done to make it work.
- We'd get working sync faster.
Ultimately, I'll be fine with syncing via a self hosted FF sync server.
If I couldn't host it myself easily, then I wouldn't use it.
Option number two would be some kind of peer-to-peer sync tool built
into TB.
This is my preferred method. I avoid Dropbox by using Syncthing, and it
is really nice not having to worry about some third party putting limits
on what I can do. And while people can figure out that I use Syncthing,
they don't know what I actually use it for.
The cons:
- There likely isn't any code for syncing peer-to-peer that TB could
use right away.
- Additional attack surface for compromises.
- Ongoing maintenance.
The pros:
TB won't need to host any new infrastructure, depending on how the
service works.
No third parties involved in handling my data.
TB won't have to worry about what people are using their servers for.
o This point would be enough to convince me. Having to worry that
someone is using my servers for criminal acts and run my stuff
with that in mind would not be easy. Or cheap.
Only need a LAN to get your data synced. So people with bad internet
won't be left out.
Can be built into TB, and only TB, so less work ensuring things work
with a third party tool.
Option number three would be a settings export and import tool.
Something simple that just outputs all the settings as a text file, then
you can copy that file where ever you need it, and import the settings
there.
The cons:
- No automatic syncs.
- Would overwrite all your local settings, or else TB would have to
make a much more difficult to code export/import wizard with
granular controls.
The pros:
- Might be much much simpler to implement.
- It would be possible to sync via syncthing/dropbox/etc.
- Depending on the format, might be able to template the config via
config management tools like Ansible.
So, here's a question, would the extension api allow an addon to perform
the peer-to-peer sync method? Last time I looked into writing extensions
was back when TB was just moving away from the XUL stuff to the new way.
And I haven't had time to dig back into that since.
Hope this helps further the discussion in a positive way. I've been
using TB since it was Netscape Mail. Only took a few years break before
coming back when I got tired of gmail being bad, and there not being any
other mature cross platform mail client. So I definitely want to see TB
keep growing.
independently, not that it probably would make any sense. You're free
to run a sync server and store your stuff there.
if you ask me.
we have. This discussion was about sync of account prefs and such.
-Magnus
Mozilla code base?
for syncing settings, that is not reliant on Mozilla, or any other
(build it and they will come). Timo has already plainly stated that
a) he is interested in adding JMAP support to dovecot, but b) it is
not a high priority for him because there are no clients out there
that could use it. If TB supported it, that would eliminate that
'excuse' - not that he is using it as an excuse, it is just the
reality - but a reality that you, the TB Council/Devs, can change.
be the first...
paid tiers, the revenues of which are shared between Fastmail and TB.
Paid tiers could provide any number of extras/goodies, from more
storage, to unlimited storage, multiple email addresses, and even
bring your own domain, all of which are able to take full advantage
of the goodness of JMAP.
Charles
make sense.
-Magnus
Hey everyone,
*Option number one* is something based on Firefox sync.
much as I can.
So the cons (imo):
* Adding another third party having access to my data, or having to
* Needing to send my data out of my LAN in order for it to sync.
* TB would need to use Mozilla's servers, or host their own, for those
The pros:
* Code for syncing already exists.
* TB already has work done to make it work.
* We'd get working sync faster.
*Option number two* would be some kind of peer-to-peer sync tool built
into TB.
The cons:
* There likely isn't any code for syncing peer-to-peer that TB could
use right away.
* Additional attack surface for compromises.
* Ongoing maintenance.
The pros:
* TB won't need to host any new infrastructure, depending on how the
service works.
* No third parties involved in handling my data.
* TB won't have to worry about what people are using their servers for.
* Only need a LAN to get your data synced. So people with bad internet
won't be left out.
* Can be built into TB, and only TB, so less work ensuring things work
*Option number three* would be a settings export and import tool.
there.
The cons:
* No automatic syncs.
* Would overwrite all your local settings, or else TB would have to
granular controls.
The pros:
* Might be much much simpler to implement.
* It would be possible to sync via syncthing/dropbox/etc.
* Depending on the format, might be able to template the config via
keep growing.
- David
> if you ask me.
> -Magnus
>> Mozilla code base?
>> be the first...
>> Charles
>>> make sense.
>>> -Magnus
>>>> Hey everyone,
>>>> - David Reagan
