View all threadsOn 09/06/2016 09:09 PM, 徐海东 wrote:
Hi Mleech,
We set master clock rate of USRP B210 to 12.8MHz,
usrp->set_master_clock_rate(12.8e6);
But we got the following warnings:
UHD Warning:
The total sum of rates (12.800000 MSps on 1 channels) exceeds the
maximum capacity of the connection.
This can cause overflows (O).
UHD Warning:
This can cause underruns (U).
What's wrong with it?
Nornally you should have to set the master clock rate yourself. When you
set the sample-rate, UHD will pick a good clock-rate for you.
In this case, you're likely on a USB-2.0 port, and over USB-2.0, you can
only get about 8Msps with full-size samples over the wire.
BR
Haidong Xu
------------------ Original ------------------
*Date: * Wed, Sep 7, 2016 00:48 AM
*To: * "徐海东"haidong.xu@wico.sh;
*Cc: * "usrp-users"usrp-users@lists.ettus.com; "徐景"
jing.xu@wico.sh; "舒睿俊"ruijun.shu@wico.sh; "王新宇"
xinyu.wang@wico.sh; "刘立刚"ligang.liu@wico.sh;
*Subject: * Re: [USRP-users] Does USRP B210 supports 12.8M HZ sample
rates?
Yes it does.
On 2016-09-06 05:43, 徐海东 via USRP-users wrote:
HI lists,
Does USRP B210 supports 12.8M HZ sample rates?
Waiting for reply.
BR.
Haidong Xu
USRP-users mailing list
USRP-users@lists.ettus.com mailto:USRP-users@lists.ettus.com
b
