I purchased my first Archilles in 1981. The transom finally rotted out. I
now am enjoying my second one (w/fiberglass transom). I opted for a soft
bottom because it stands up better than a RIB. I use it for beachcombing,
exploring, etc. I've had it on a lot of beaches with mussels, barnacles,
sharp rocks, etc. The trick is to get a "really good" quality inflatable.
The cheaper ones will shred on the beaches here. Mine is hypalon and rated
for 30 HP. I try to anchor out if I can because it's so heavy to drag and I
travel by myself most of the time. I suppose it all depends on how it is
used. My original one was towed behind a 26' Bayliner. AT times I was sure
it was in the air more than the water. I then had it on its side on the
swim platform. Never used davits of any kind and had no problem BUt I did
have to take the outboard off all the time. I now have my Willard and keep
the dinghy on top w/a 25 HP Yamaha on it.
Nick Fabrello
MV Petite Michelle
40' Willard PH
Ketchikan, AK. 99901
To: E16@telus.net
Cc: trawler-world-list@samurai.com
Subject: TWL: Dinghy
Date: Monday, June 26, 2000 5:29 AM
Should it be a RIB or hard shell?
Rib is far superior in the PNW (rocks and barnacles when you go ashore).
Hard dinghy has less stablity, but does row easier. The dinghy will be
your
station waggon, so you want speed--at least 8 hp, pref 9.9 or 15.
If a
